[mpich-discuss] [mpich2-announce] Announcing the availability of MPICH2-1.1a2
Dave Goodell goodell at mcs.anl.gov
Fri Dec 5 15:48:05 CST 2008
On Dec 4, 2008, at 6:12 PM, Dave Goodell wrote:
> On Nov 25, 2008, at 2:18 PM, Joe Ratterman wrote:
>> 3)
>> I noticed that we got a hang because the build didn't pick up or
>> custom CS_ENTER/EXIT macros.  It looks like the "threaded" branch
>> code for the macros is in this alpha release?  I added some code to
>> use MPID_DEFINES_MPID_CS to once-again allow a device to use custom
>> macros.  Unlike my "work" in the threaded branch, it is much more
>> exacting.  I will send these changes as a (git) patch in case you
>> are interested.  It can usually be applied using "patch -p1".
> I'll see if I can get this applied within the coming week.  Thanks
> for the patch.
I've applied this as r3636.  This is fine enough for now.  I'm not
sure if MPID_CS macros make very much sense in their current
incarnation going forwards.  Now that we are using finer grained
critical sections the MPID_CS interface will either need to be updated
or removed.
-Dave
