[mpich-discuss] (no subject) - mingw
Jayesh Krishna jayesh at mcs.anl.gov
Tue Dec 2 13:34:18 CST 2008
 You could try installing MPICH2 on windows (from the installer available
at
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=down
loads) and compile your code and link with the gcc libs (*.a) provided
with the installation (MPICH2\lib directory).
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of ting lei
Sent: Tuesday, December 02, 2008 1:31 PM
Subject: [mpich-discuss] (no subject)
This might be a newbie question.
I see in this thread that people can compile MPICH2 with MingW. I tried
that with MingW (gcc 4.3 and 3.4x) several times but
I was never able to get past the ./configure step.
"I have compiled a C executable using the MPICH2 Windows libraries and
MinGW."
Could someone please give me some pointers how to compile such an
executable?
More specifically, do I have to compile MPICH2 itself from source using
MinGW then use some program such as mpicc??
or should I just compile a regular c program and run it with mpiexec.exe ?
If I were to compile MPICH2 itself with MingW, what other packages do I
need except the latest version of MingW?
Many thanks for your help
Ting
--Original Message----
  This is a bug in the current state machine of SMPD. This should not
affect the execution of your MPI program (This error occurs when the
process manager tries to cleanup connections after the MPI program
finishes execution).
(PS: You can go ahead with your program development and ignore the
closesocket() errors for now. We will fix this bug soon.)
Jayesh
-----Original Message-----
<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss> ] On Behalf Of
Dmitri Chubarov
Sent: Tuesday, November 11, 2008 1:23 AM
To: someindianbloke at gmail.com
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] closesocket failed error when running an
MinGWcompiled executable.
Error 10093 is a winsock error code for "Successful WSAStartup not yet
performed". Do check if you get the same error on other machines to rule
out network misconfiguration in your Windows installation.
On Tue, Nov 11, 2008 at 7:02 AM, Chiraj <someindianbloke at gmail.com
<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss> > wrote:
> Hi,
> MinGW. I have tried running the executable using "mpiexec -localroot
> -localonly 2 main.exe 0.xml", but I get the following error:
> closesocket failed, sock 1284, error 10093
> Could some please tell me what this means I am doing wrong? I have
> tried searching everywhere on what this error means. I have registered
> my user credentials using wmpiregister and checked if I have started
> smpd as a windows service. I am running Windows Xp Professional SP3 on
> an Intel Pentium 4 base system.
> Chiraj
  _____
You live life online. So we put Windows on the web. Learn more
<http://clk.atdmt.com/MRT/go/127032869/direct/01/> about Windows Live
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081202/4f75bfbb/attachment.htm>
