[MPICH] debug flag
Wei-keng Liao wkliao at ece.northwestern.edu
Sat May 26 21:47:37 CDT 2007
The machine is a Cray XT3, 4. The batch is PBS and the command to launch
an MPI job is "yod" as described in the user guide.
I tried to replace yod with mpich mpdboot and mpiexec, etc. I also used
the PBS environment variable PBS_NODEFILE in mpdboot, but the node file
does not contain the hostnames of nodes allocated by the PBS. It actually
always contains just one yod node, no matter how many nodes I request in
PBS script.
Any idea of how to do it?
Wei-keng
On Sat, 26 May 2007, Rajeev Thakur wrote:
> Are you sure you can't run your own MPICH2 on the machine? It is just a
> user-level library. Once the scheduler assigns you a set of nodes, you can
> run mpd and your own mpiexec.
> Rajeev
