[MPICH] understanding the signal numbers of the crashes
Kamaraju Kusumanchi kamaraju at gmail.com
Thu Jun 21 21:27:15 CDT 2007
On 6/21/07, Sam Miller <samm at sammiller.org> wrote:
> On Jun 21, 2007, at 8:38 PM, Kamaraju Kusumanchi wrote:
> Hi all
>    Is there any book/document/webpage which explains what different
> signal numbers mean? For example, when executing an MPI program I am
> getting an error as follows.
> exit status of rank 3: killed by signal 9
> From previous discussions on this list, I know that Signal 11 means
> segmentation fault. But what about signal 9? What about other signal
> numbers?
> I googled and got no hits. I also looked in the "mpich2 User's guide"
> version 1.0.5 which does not explain the signal codes. Any other
> pointers/suggestions?
> thanks
> raju
> signal 9 is SIGKILL, a signal you cannot ignore.
> info kill or kill -l should provide you with a list of all the signals.
> Regards,
Thank you very much for the reply. It helped.
raju
