[MPICH] Binding and instance of the MPI program to a particular processor
Diego M. Vadell dvadell at linuxclusters.com.ar
Thu Jun 21 20:57:49 CDT 2007
Hi William,
   I cant find the reference, and probably there isn't one. I think I
got confused with the improvements in that area of linux 2.6's
scheduler vs. linux 2.4's. Looks like I wrote
without thinking twice.
   Thanks for your answer
 -- Diego.
P.S.: Sorry to everybody for wasting your time.
On Thu, 21 Jun 2007 11:20:53 -0500
William Gropp <gropp at mcs.anl.gov> wrote:
> That's a good point.  I'd like to see the reference, because I don't
> see how the scheduler can be sure that the data in cache won't be
> needed in the near future (after all, the compiler often can't
> predict this).  That is, it doesn't matter if the data is out of the
> cache; for performance on many scientific workloads, it is essential
> to reuse data that is already in cache, and if the data must be
> reloaded, performance will plummet.
> Bill
> On Jun 21, 2007, at 10:49 AM, Diego M. Vadell wrote:
> > Hi,
> >     Is there any proof (e.g. benchmark) that binding a process to a
> > processor/core is better than letting the scheduler work things out? I
> > remember reading - sorry for the lack of reference - that linux's
> > scheduler
> > knows about the cache when scheduling so when the processes bounce
> > from
> > processor to processor, it is because the process' data is already
> > out of the
> > cache (and there is really no gain in keeping the process in the same
> > processor, esp. when that processor is busy with another process).
> > Thanks in advance,
> >  -- Diego.
> > El Jueves, 21 de Junio de 2007 12:27, Darius Buntinas escribió:
> >> In linux there's a command called numactl which can be used to
> >> execute a
> >> process and bind it to a physical processor.  Unfortunately, it looks
> >> like pbind can only bind a process once it has already been
> >> started.  If
> >> you can find a command on sun similar to numactl on linux you can do
> >> something like what I do with numactl.
> >> With numactl one can do something like this to bind each process to a
> >> different processor:
> >> mpiexec -n 1 numactl --physcpubind=0 -- myapp myapparg : -n 1 numactl
> >> --physcpubind=1 -- myapp myapparg : -n 1 numactl --physcpubind=2 --
> >> myapp myapparg
> >> etc.
> >> Of course that's messy, so a more general solution would be to
> >> write a
> >> script called, e.g. execbind, to do that:
> >> numactl --physcpubind=`expr $PMI_RANK % $PROCS_PER_NODE` -- $@
> >> Where $PROCS_PER_NODE is the number of processors on each node of
> >> your
> >> cluster, and $PMI_RANK is set by mpiexec.
> >> Then, if you wanted to start 16 processes on a cluster of machines
> >> with
> >> 4 cores each, you could simply do:
> >> mpiexec -n 16 -env PROCS_PER_NODE 4 execbind myapp myapparg
> >> Darius
> >> Christina Patrick wrote:
> >>> Is it possible for me to modify the Python script (mpiexec) in
> >>> such a
> >>> way that I use the pbind command to bind each instance of the
> >>> executing
> >>> program to a different processor? I would like to give that a shot.
> >>> Warm Regards,
> >>> Christina.
> >>> On 6/20/07, *Rajeev Thakur* <thakur at mcs.anl.gov
> >>> <mailto:thakur at mcs.anl.gov>> wrote:
> >>>     MPICH2 leaves the scheduling of processes to the OS. If the
> >>> OS has
> >>>     some way
> >>>     to bind processes to processors, you could try using it.
> >>>     Rajeev
> >>>> -----Original Message-----
> >>>> From: owner-mpich-discuss at mcs.anl.gov
> >>>     <mailto:owner-mpich-discuss at mcs.anl.gov>
> >>>> [mailto:owner-mpich-discuss at mcs.anl.gov
> >>>     <mailto:owner-mpich-discuss at mcs.anl.gov>] On Behalf Of
> >>>> Christina Patrick
> >>>> Sent: Wednesday, June 20, 2007 4:12 PM
> >>>> To: mpich-discuss-digest at mcs.anl.gov
> >>>     <mailto:mpich-discuss-digest at mcs.anl.gov>
> >>>> Subject: [MPICH] Binding and instance of the MPI program to a
> >>>> Hi everybody,
> >>>> I am having a 8 processor Solaris 9 machine and I want to
> >>>> execute an MPI program on it. The problem is that the tasks
> >>>> created by mpiexec keep migrating on the different
> >>>> processors. Since it is only one machine, there is only one
> >>>> instance of the mpdboot daemon running on the machine. Hence
> >>>> when I execute the below command on the machine with 8
> >>>> processors, I get an output that says:
> >>>> (For example, if the MPI program name is "finalized")
> >>>> # mpiexec -n 8 ./finalized
> >>>> 0:  No Errors
> >>>> When I examined the system using the "prstat" command, I
> >>>> observed that the tasks are migrating between the different
> >>>> processors.
> >>>> Is there any why in which I could bind each instance of the
> >>>> MPI program to a different processor.
> >>>> Your suggesstions and help is appreciated,
> >>>> Thanks,
> >>>> Christina.
