[MPICH] Binding and instance of the MPI program to a particular processor
William Gropp gropp at mcs.anl.gov
Thu Jun 21 10:01:16 CDT 2007
There also appears to be a processor_bind routine that you can call.
You might try using that just after MPI_Init.  Let us know how that
works; we could add that to mpiexec.
Bill
On Jun 21, 2007, at 9:53 AM, Christina Patrick wrote:
> Is it possible for me to modify the Python script (mpiexec) in such
> a way that I use the pbind command to bind each instance of the
> executing program to a different processor? I would like to give
> that a shot.
> Warm Regards,
> Christina.
> On 6/20/07, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> MPICH2 leaves the scheduling of processes to the OS. If the OS has
> some way
> to bind processes to processors, you could try using it.
> Rajeev
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov ] On Behalf Of
> > Christina Patrick
> > Sent: Wednesday, June 20, 2007 4:12 PM
> > To: mpich-discuss-digest at mcs.anl.gov
> > Subject: [MPICH] Binding and instance of the MPI program to a
> > Hi everybody,
> > I am having a 8 processor Solaris 9 machine and I want to
> > execute an MPI program on it. The problem is that the tasks
> > created by mpiexec keep migrating on the different
> > processors. Since it is only one machine, there is only one
> > instance of the mpdboot daemon running on the machine. Hence
> > when I execute the below command on the machine with 8
> > processors, I get an output that says:
> > (For example, if the MPI program name is "finalized")
> > # mpiexec -n 8 ./finalized
> > 0:  No Errors
> > When I examined the system using the "prstat" command, I
> > observed that the tasks are migrating between the different
> > processors.
> > Is there any why in which I could bind each instance of the
> > MPI program to a different processor.
> > Your suggesstions and help is appreciated,
> > Thanks,
> > Christina.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070621/5b3dac4f/attachment.htm>
