FW: [MPICH] Error compiling c++ programs with mpiCC
Rajeev Thakur thakur at mcs.anl.gov
Mon Jun 18 11:07:22 CDT 2007
-----Original Message-----
From: Oliver Fortmeier [mailto:fortmeier at sc.rwth-aachen.de]
Sent: Monday, June 18, 2007 11:04 AM
To: owner-mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] Error compiling c++ programs with mpiCC
I had the same problem, when I compiled the mpi header file with high
warning status (-W -Wall -pedantic).
If you are using the gcc Compiler (as it looks like), you can create
your own mpi-headerfile:
file: mpi.h
#pragma GCC system_header  // Suppress warnings from mpi.h
#include <mpi.h>
If you include this file with the gcc-Compiler, all warnings are
suppressed and the errors do not occur any more.
Best,
Oliver
Anna Mereu wrote:
> Hi, i'm trying to compile c++ program including mpi++.h files with the
> mpiCC complier. The errors are the following:
> /usr/local/mpich-g2-cpp/include/mpi2c++/comm.h:106: warning: 'class
> MPI::Comm' has virtual functions but non-virtual destructor
> /usr/local/mpich-g2-cpp/include/mpi2c++/intracomm.h:30: warning: 'class
> MPI::Intracomm' has virtual functions but non-virtual destructor
> /usr/local/mpich-g2-cpp/include/mpi2c++/topology.h:31: warning: 'class
> MPI::Cartcomm' has virtual functions but non-virtual destructor
> /usr/local/mpich-g2-cpp/include/mpi2c++/topology.h:112: warning: 'class
> MPI::Graphcomm' has virtual functions but non-virtual destructor
> /usr/local/mpich-g2-cpp/include/mpi2c++/intercomm.h:31: warning: 'class
> MPI::Intercomm' has virtual functions but non-virtual destructor
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_alg
obase.h:
> In function 'MPI2CPP_BOOL_T std::lexicographical_compare(const unsigned
> char*, const unsigned char*, const unsigned char*, const unsigned char*)':
obase.h:887:
> error: cannot convert 'bool' to 'MPI2CPP_BOOL_T' in return
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/char_tr
aits.h:
> In static member function 'static MPI2CPP_BOOL_T
> std::char_traits<char>::eq(const char&, const char&)':
aits.h:245:
aits.h:
> std::char_traits<char>::lt(const char&, const char&)':
aits.h:249:
aits.h:
> std::char_traits<char>::eq_int_type(const int&, const int&)':
aits.h:287:
aits.h:
> std::char_traits<wchar_t>::eq(const wchar_t&, const wchar_t&)':
aits.h:315:
aits.h:
> std::char_traits<wchar_t>::lt(const wchar_t&, const wchar_t&)':
aits.h:319:
aits.h:
> std::char_traits<wchar_t>::eq_int_type(const wint_t&, const wint_t&)':
aits.h:353:
> /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:
> At global scope:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:380:
> error: cannot convert 'bool' to 'const MPI2CPP_BOOL_T' in initialization
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:533:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1006:
> error: invalid conversion from 'int' to 'MPI2CPP_BOOL_T'
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1007:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1023:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1063:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1064:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1080:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1120:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1121:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits:1138:
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/locale_
classes.h:
> In member function 'MPI2CPP_BOOL_T std::locale::operator!=(const
> std::locale&) const':
classes.h:242:
classes.h:
> std::locale::_Impl::_M_check_same_name()':
classes.h:540:
> error: cannot convert 'bool' to 'MPI2CPP_BOOL_T' in assignment
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-g
nu/bits/ctype_inline.h:
> In member function 'MPI2CPP_BOOL_T std::ctype<char>::is(short unsigned
> int, char) const':
nu/bits/ctype_inline.h:40:
> /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/typeinfo:
> In member function 'MPI2CPP_BOOL_T std::type_info::before(const
> std::type_info&) const':
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/typeinfo:106
> In member function 'MPI2CPP_BOOL_T std::type_info::operator==(const
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/typeinfo:108
> In member function 'MPI2CPP_BOOL_T std::type_info::operator!=(const
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/typeinfo:111
facets.tcc:
> In function 'MPI2CPP_BOOL_T std::__verify_grouping(const char*, size_t,
> const std::string&)':
facets.tcc:2473:
facets.tcc:2475:
facets.tcc:2480:
obase.h:
> std::lexicographical_compare(_InputIterator1, _InputIterator1,
> _InputIterator2, _InputIterator2) [with _InputIterator1 = const signed
> char*, _InputIterator2 = const signed char*]':
obase.h:901:
> instantiated from here
obase.h:835:
> make: *** [confronto.o] Error 1
> How can i fix them??
> Thank you very much for the help
> Anna
  Oliver Fortmeier                      fortmeier at sc.rwth-aachen.de
  Institute for Scientific Computing    phone: +49 241 80 24918
  RWTH Aachen University                fax:   +49 241 80 6 24918
