[MPICH] mpirun vs. mpiexec
Steve Young chemadm at hamilton.edu
Tue Jun 5 12:48:44 CDT 2007
I was contemplating switching over to the setup where each user starts
their own ring. I have an older cluster that I am planning on testing
this setup with. I am curious to know if there are
advantages/disadvantages over the two setups. Would I notice anything
different in terms of performance?
Anyhow, For now I'm looking at the mpiexec that you and Garrick
suggested. Thanks a bunch for the quick replies!
-Steve
On Tue, 2007-06-05 at 11:46 -0500, Anthony Chan wrote:
> On Tue, 5 Jun 2007, Steve Young wrote:
> > Hello,
> > 	I am trying to understand the differences of when to use mpirun vs.
> > using mpiexec.
> > Currently, we have a cluster (x86_64 with 38 nodes - 4cpu's per node)
> > that is set up with mpich2-1.0.5 and running a ring that is started
> > across all the nodes by root.
> > We are also using PBS (torque-2.0.0p7) to manage the resources.
> Have you tried to start the mpd ring as a regular user ?  i.e. do
> mpdboot in your pbs script ?  If you don't want to start mpd within
> the pbs script, you may want to consider using Pete Wyckoff's mpiexec
> from osc.edu with mpich2+torque.
> > Our main problem is with using the sander.MPI program from the Amber9
> > software. But I have been able to produce the same results using the
> > simple bounce program.
> > Now first I use mpirun and the program will run as expected:
> > mpirun -np 8 sander.MPI -O......
> > However, using mpirun the the program doesn't go to the proper nodes
> > that PBS allocates to the job. when I try to give mpirun the -
> > machinefile argument mpirun complains about this as it doesn't appear to
> > know about this one.
> In mpich2, mpirun points to mpiexec.  Anyway, you should use mpiexec that
> comes with the process manager.
> A.Chan
