[MPICH] running an MPI prog
Anthony Chan chan at mcs.anl.gov
Fri Jul 27 13:20:11 CDT 2007
You probably used mpiexec from other implementation.  Using mpiexec from
OpenMPI on a cpi exeutable compiled with MPICH2 produced the output that
you saw.
A.Chan
> ~/openmpi/install_123_gcc4/bin/mpiexec -n 3 cpi
Process 0 of 1 is on bblogin
pi is approximately 3.1415926544231341, Error is 0.0000000008333410
wall clock time = 0.000649
wall clock time = 0.000609
wall clock time = 0.000638
On Fri, 27 Jul 2007 Mark.Donohue at avtechgroup.com wrote:
> Hello Anthony.  Thank you.  It was brought to my attention that an MPI
> code must be run using exactly the same MPICH implementation that
> created it.
> -Mark
> PS.  If you have any input as far as what goes into the MPICH users
> manual, this would be good to add!
> -----Original Message-----
> From: Anthony Chan [mailto:chan at mcs.anl.gov]
> Sent: Friday, July 27, 2007 10:08 AM
> To: Mark Donohue
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] running an MPI prog
> Your cpi output suggests the 3 cpi processes are not talking to one
> another.  Here is the my cpi output:
> > ..../mpiexec -n 3 cpi
> Process 2 of 3 is on bblogin
> Process 0 of 3 is on bblogin
> Process 1 of 3 is on bblogin
> pi is approximately 3.1415926544231318, Error is 0.0000000008333387 wall
> clock time = 0.005751
> Try using mpdcheck to see if your network is setup correctly.
> A.Chan
> > Hey Anthony. Thanks for the reply.  Yeah this seems to run ok.  Here's
> > what I get (I only had three machines in the ring at that time).  Is
> > this what you would expect to see?
> > Aero1% mpiexec -n 3 cpi
> > Process 0 of 1 on Aero2
> > wall clock time = 0.000453 Process 0 of 1 on Aero1 pi is approximately
> > 3.1415926544231341, Error is 0.0000000008333410 wall clock time =
> > 0.000622 Process 0 of 1 on Aero3 pi is approximately
> > 0.000455
> > Sent: Thursday, July 26, 2007 6:29 PM
> > To: Mark Donohue
> > Subject: Re: [MPICH] running an MPI prog
> > Can you run a simple MPI program like cpi in
> > <mpich2-build-dir>/examples ?
> > cd <mpich2-build-dir>/examples
> > <mpich2-build-dir>/bin/mpiexec -n 4 cpi
> > A.Chan
> > On Thu, 26 Jul 2007 Mark.Donohue at avtechgroup.com wrote:
> > > Hi yall.  Please help a simpleton with some basic MPICH knowledge.
> > > I am trying to run an MPI version of a CFD program that I use
> regularly.
> > > I installed MPICH2 on our Linux cluster, but when I try and run, I
> > > get
> > > the error at the bottom.  I split my computational domain into two
> > > partitions, and the program complains that the number of partitions
> > > (2) doesn't equal the number of processors.  Huh?  Is there a way to
> > > fix this?  I realize that this error is coming from my MPI code and
> > > not from MPICH itself, but I was hoping to gain some insight into
> > > why this is happening.  For some reason I thought specifying "-n 2"
> > > meant that it will begin running with two processors.  All the
> > > documentation
> > > I've found hasn't been able to answer this for me.  Thanks a bunch!
> > > -Mark
> > > Aero1% mpiexec -l -machinefile myhosts -n 2 usm3d_52p.mpip4
> > > Baseline_Elev
> > > 0: ** WARNING: fp stack is not empty
> > > 0: ** after call to etime in routine usm52p
> > > 0:
> > > 0: ** popping the fp stack and continuing...
> > > 1: ** WARNING: fp stack is not empty
> > > 1: ** after call to etime in routine usm52p
> > > 1:
> > > 1: ** popping the fp stack and continuing...
> > > 1: FORTRAN STOP
> > > 1:  the MPI has been initialized on            1  processors
> > > 1:   no. of partitions != no. of processors
> > > 0: FORTRAN STOP
> > > 0:  the MPI has been initialized on            1  processors
> > > 0:   no. of partitions != no. of processors
