[MPICH] running an MPI prog
Rajeev Thakur thakur at mcs.anl.gov
Fri Jul 27 12:30:15 CDT 2007
Yes, you need to use the exact same MPI implementation for compiling and
running.
Your cpi example also shows the same problem. Each process thinks it is in
own world, not a world of 3 processes.
Rajeev
> -----Original Message-----
> From: Mark.Donohue at avtechgroup.com
> [mailto:Mark.Donohue at avtechgroup.com]
> Sent: Friday, July 27, 2007 11:07 AM
> To: thakur at mcs.anl.gov
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] running an MPI prog
> Hello Rajeev.  Good question as I didn't compile the MPI
> program myself.
> But you're probably onto something as I am using MPICH2-1.0.5
> and I have
> a strong hunch the code was compiled with MPICH1.  That's a
> show-stopper
> huh?  Would your suggestion be to install the same version of MPICH1
> that compiled the code?  Thanks again!
> -mark
> From: Rajeev Thakur [mailto:thakur at mcs.anl.gov]
> Sent: Thursday, July 26, 2007 9:55 PM
> To: Mark Donohue
> Make sure you are compiling and running your program with mpif90 and
> mpiexec from the same MPI implementation. Give the full path
> to mpiexec
> if needed.
> Rajeev
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Anthony Chan
> > Sent: Thursday, July 26, 2007 7:29 PM
> > To: Mark.Donohue at avtechgroup.com
> > Subject: Re: [MPICH] running an MPI prog
> > Can you run a simple MPI program like cpi in
> > <mpich2-build-dir>/examples ?
> > cd <mpich2-build-dir>/examples
> > <mpich2-build-dir>/bin/mpiexec -n 4 cpi
> > A.Chan
> > On Thu, 26 Jul 2007 Mark.Donohue at avtechgroup.com wrote:
> > > Hi yall.  Please help a simpleton with some basic MPICH
> > knowledge.  I am
> > > trying to run an MPI version of a CFD program that I use
> > regularly.  I
> > > installed MPICH2 on our Linux cluster, but when I try and
> > run, I get the
> > > error at the bottom.  I split my computational domain into two
> > > partitions, and the program complains that the number of
> > partitions (2)
> > > doesn't equal the number of processors.  Huh?  Is there a
> way to fix
> > > this?  I realize that this error is coming from my MPI code
> > and not from
> > > MPICH itself, but I was hoping to gain some insight into
> why this is
> > > happening.  For some reason I thought specifying "-n 2"
> > meant that it
> > > will begin running with two processors.  All the
> documentation I've
> > > found hasn't been able to answer this for me.  Thanks a bunch!
> > > -Mark
> > > Aero1% mpiexec -l -machinefile myhosts -n 2 usm3d_52p.mpip4
> > > Baseline_Elev
> > > 0: ** WARNING: fp stack is not empty
> > > 0: ** after call to etime in routine usm52p
> > > 0:
> > > 0: ** popping the fp stack and continuing...
> > > 1: ** WARNING: fp stack is not empty
> > > 1: ** after call to etime in routine usm52p
> > > 1:
> > > 1: ** popping the fp stack and continuing...
> > > 1: FORTRAN STOP
> > > 1:  the MPI has been initialized on            1  processors
> > > 1:   no. of partitions != no. of processors
> > > 0: FORTRAN STOP
> > > 0:  the MPI has been initialized on            1  processors
> > > 0:   no. of partitions != no. of processors
