[MPICH] MPI_Dimms_create() and square numbers
Andrea Di Blas andrea at soe.ucsc.edu
Mon Jul 16 17:59:04 CDT 2007
hi bill,
thank you very much for your reply. it did seem strange...
I'd be happy to know what you guys decide.
regards,
	andrea
Andrea  Di Blas                     UCSC
                   School of Engineering
Tel: (831) 459 4193  Fax: (831) 459 4829
On Sun, 15 Jul 2007, William Gropp wrote:
> Thanks for the example.  This isn't the intended default behavior;
> for systems with a particular underlying topology, there is a
> mechanism for that system to override the default Dims_create (e.g.,
> on a system with a mesh interconnect that might be a power of 2 in
> each direction).  We'll have a look at improving the default case.
> Bill
> On Jul 14, 2007, at 6:37 PM, Andrea Di Blas wrote:
> > hello,
> > I am wondering about the strategy implemented by MPI_Dimms_create() to
> > best balance the grid size in all dimensions.
> > for instance, when sizing a bidimensional cartesian communicator
> > with a
> > square number p of processes, without enforcing constraints,
> > sometimes the
> > two sizes are the sqrt(p) as (I would have) expected (e.g. with p =
> > 4 or p
> > = 16), while other times they are not (e.g. with p = 9 or p = 100).
> > the same behavior happenes with cubes.
> > I wonder if I am doing something wrong, or if it is intentional,
> > and if it
> > is so, why.  thanks in advance.
> > regards,
> > 	andrea
> > CODE: (for the cube case)
> > for(i = 2; i < 12; ++i)
> > {	grid_size[0] = grid_size[1] = 0; grid_size[2] = 0;
> > 	MPI_Dims_create(i*i*i, 3, grid_size);
> > 	printf("\nMPI_Dims_create(%4d, 3, grid_size) = %3d, %3d, %3d", i*i*i,
> > 			grid_size[0], grid_size[1], grid_size[2]);
> > OUTPUT: (for the square case)
> > MPI_Dims_create(  4, 2, grid_size) =  2, 2
> > MPI_Dims_create(  9, 2, grid_size) =  9, 1
> > MPI_Dims_create( 16, 2, grid_size) =  4, 4
> > MPI_Dims_create( 25, 2, grid_size) = 25, 1
> > MPI_Dims_create( 36, 2, grid_size) = 18, 2
> > MPI_Dims_create( 49, 2, grid_size) = 49, 1
> > MPI_Dims_create( 64, 2, grid_size) =  8, 8
> > MPI_Dims_create( 81, 2, grid_size) =  9, 9
> > MPI_Dims_create(100, 2, grid_size) = 50, 2
> > MPI_Dims_create(121, 2, grid_size) = 121, 1
> > OUTPUT: (for the cube case)
> > MPI_Dims_create(   8, 3, grid_size) =   4,   2,   1
> > MPI_Dims_create(  27, 3, grid_size) =   9,   3,   1
> > MPI_Dims_create(  64, 3, grid_size) =   4,   4,   4
> > MPI_Dims_create( 125, 3, grid_size) = 125,   1,   1
> > MPI_Dims_create( 216, 3, grid_size) = 108,   2,   1
> > MPI_Dims_create( 343, 3, grid_size) = 343,   1,   1
> > MPI_Dims_create( 512, 3, grid_size) =   8,   8,   8
> > MPI_Dims_create( 729, 3, grid_size) =   9,   9,   9
> > MPI_Dims_create(1000, 3, grid_size) = 500,   2,   1
> > MPI_Dims_create(1331, 3, grid_size) = 1331,   1,   1
> > Andrea  Di Blas                     UCSC
