[MPICH] Problem with mpiexec after creating a ring in Windows/Cygwin
Mauro Sgroi maurosgroi at yahoo.it
Wed Jul 11 09:57:12 CDT 2007
I solved my problems using the option -genvnone of
mpiexec.
Thanks a lot,
Mauro Sgroi.
--- Rajeev Thakur <thakur at mcs.anl.gov> ha scritto:
> The port you specified is for the MPD daemons to
> talk to each other. The MPI
> application processes talk to each other on ports
> returned by the operating
> system. These are ports in the ephemeral range.
> Rajeev
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf
> Of Mauro Sgroi
> > Sent: Thursday, July 05, 2007 8:08 AM
> > To: mpich-discuss-digest at mcs.anl.gov
> > Subject: [MPICH] Problem with mpiexec after
> creating a ring
> > in Windows/Cygwin
> > Dear all,
> > I'm new to MPICH2. I compiled the program Abinit
> using
> > the MPICH2 library. The compilation of MPICH2 was
> > fine. I created a ring between two Windows PC (XP
> and
> > Win 2000) having the Cygwin tools installed. I not
> > installed ssh, so I created the ring doing:
> > mpd --listenport=2500 & on the first PC
> > and
> > mpd --host=C0PC0167 --port=2500 --listenport=2501
> > Cheching the ring I get:
> > mpdtrace -l
> > C0PC0167_2500 (151.91.212.63)
> > C0PC0165_2501 (151.91.212.129)
> > Now I'm trying to launch my parallel code on the 2
> > monoprocessor PC:
> > mpiexec  -n 2 /usr/local/abinit/5.3/bin/abinip.exe
> > tparal_1.files
> > I get the error:
> > [unset]: Unable to get AF_INET socket
> > [unset]: Unable to connect to 151.91.212.129 on
> 1385
> > [unset]: aborting job:
> > Fatal error in MPI_Init: Other MPI error, error
> stack:
> > MPIR_Init_thread(247): Initialization failed
> > MPID_Init(71)........: channel initialization
> failed
> > MPID_Init(274).......: PMI_Init returned -1
> > mpiexec is accessing to the second PC on the wrong
> > port: 1385 instead of 2501.
> > I tried also to use a machinefile but with no good
> > results. How can I force mpiexec to look in the
> good
> > port?
> > Thanks a lot and best regards,
> > Mauro Sgroi.
> > Italy.
> >       ___________________________________
> > L'email della prossima generazione? Puoi averla
> con la nuova
> > Yahoo! Mail:
> http://it.docs.yahoo.com/nowyoucan.html
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
