[MPICH] slow IOR when using fileview
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Jul 3 16:06:36 CDT 2007
I come up with a very simple solution for checking this contiguous
buftype, non-contiguous filetype, but the "intersection" is contiguous.
In file ad_write_str.c, line 265, insert the followings:
     if (file_ptr_type == ADIO_INDIVIDUAL && buftype_is_contig &&
         bufsize + (offset - flat_file->indices[st_index]) <=
         flat_file->blocklens[st_index]) {
         ADIO_WriteContig(fd, buf, bufsize, MPI_BYTE, ADIO_EXPLICIT_OFFSET,
                          offset, status, error_code);
         return;
The first if condition "file_ptr_type == ADIO_INDIVIDUAL" is because I am
not sure if this is applicable to shared file pointers.
The second condition "buftype_is_contig" is to ensure buffer is
contiguous.
The third condition is to ensure the requesting data is within a single
block of flat_file, ie, the st_index block in flat_file.
I tested it with my testing code and it ran OK. Please let me know if this
can cause any problem that I did not think of. I hope it can be
incorporated into ROMIO in the future release.
Wei-keng
On Tue, 3 Jul 2007, Wei-keng Liao wrote:
> I checked the ROMIO source for this particular access pattern.
> At first, a few words about the access pattern.
> 1) MPI_Type_create_subarray() creates the file access regions like
>   file: |----------|----------|----------| .... |----------|
>             P0         P1          P2               P7
>   Each segment is of size 10MB.
> 2) There is no overlapped, interleaved, or non-contiguous access across
>   all processes. Every file access is a single contiguous write request.
> 3) Write buffer is also contiguous. The write amount is 10 MB, same across
>   all MPI processes.
> 4) The effect of using this file type should be the same as using
>   explicit file offset without file type.
> In ROMIO source file ad_write_coll.c, in function
> ADIOI_GEN_WriteStridedColl(), ADIOI_Datatype_iscontig() is called in line 141
> to check if the file type is contiguous and it returns 0. That means the file
> type is not contiguous. In general, this is true, since the file type is
> applied to the entire file space repeatedly. Therefore, in line 153,
> ADIO_WriteStrided() is called, instead of ADIO_WriteContig() in line 150. So,
> data sieving is performed by default in ADIO_WriteStrided() which chops the
> 10 MB write into 20 512KB chunks. For each chunk, a read-modify-write is
> carried out.
> In fact, this I/O pattern should trigger ADIO_WriteContig() for best result.
> I suggest one more test should be given here for checking if the intersection
> of the buffertype and filetype is contiguous. If yes,
> ADIO_WriteContig() is called. Here, the intersection operation will involve
> the current file position. I don't know how complicate can this
> implementation be.
> Wei-keng
> On Mon, 2 Jul 2007, Yu, Weikuan wrote:
>>> If the independent
>>> access is used instead, I don't know why each write is divided into 512 KB
>>> chunks and locking is ever needed to guaranteed the atomic access of the
>>> 10 MB contiguous file range. For this particular access pattern, ROMIO
>>> should not do read-modify-write at all.
>> 512KB is the default buffer size for data sieving. So with 512KB buffer
>> size, each process is only able to write out 512KB data in each call of
>> ADIOI_GEN_WriteStrided. For 10MB, this results in 20 iterations of
>> write_all(), 40 fcntl() total. crayPat indicates that fcntl() takes 88% of
>> the total Wall clock time with fileview, 0% w/o fileview.
>> --Weikuan
