[MPICH] slow IOR when using fileview
Wei-keng Liao wkliao at ece.northwestern.edu
Sun Jul 1 15:25:01 CDT 2007
I tried different datatype constructors. Compared to the case without
using MPI_File_setview(), the results are:
   MPI_Type_create_subarray()  ---- much slower
   MPI_Type_indexed()  ---- much slower
   MPI_Type_vector() with explicit offset in setview  ---- much slower
   MPI_Type_contiguous() with explicit offset in setview  ---- same
   MPI_BYTE with explicit offset in setview  ---- same
The MPICH is version 2-1.0.2. I cannot test newer versions on that
machine.
Wei-keng
On Sun, 1 Jul 2007, Rajeev Thakur wrote:
> Can you see what happens if you use type_indexed instead of type_subarray?
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Wei-keng Liao
>> Sent: Saturday, June 30, 2007 2:03 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [MPICH] slow IOR when using fileview
>> I am experiencing slow IOR performance on Cray XT3 when using
>> fileview
>> option. I extract the code into a simpler version (attached).
>> The code
>> compares two collective writes: MPI_File_write_all and
>> MPI_File_write_at_all. The former uses an MPI fileview and
>> the latter uses
>> explicit file offset. For both cases, each process writes 10 MB to a
>> shared file, contiguously, non-overlapping, non-interleaved.
>> On the Cray
>> XT3 with Lustre file system, the former is extremely slower than the
>> latter. Here is an output for using 8 processes:
>> 2: MPI_File_write_all() time = 4.72 sec
>> 3: MPI_File_write_all() time = 4.74 sec
>> 6: MPI_File_write_all() time = 4.77 sec
>> 1: MPI_File_write_all() time = 4.79 sec
>> 7: MPI_File_write_all() time = 4.81 sec
>> 0: MPI_File_write_all() time = 4.83 sec
>> 5: MPI_File_write_all() time = 4.85 sec
>> 4: MPI_File_write_all() time = 4.89 sec
>> 2: MPI_File_write_at_all() time = 0.02 sec
>> 1: MPI_File_write_at_all() time = 0.02 sec
>> 3: MPI_File_write_at_all() time = 0.02 sec
>> 0: MPI_File_write_at_all() time = 0.02 sec
>> 6: MPI_File_write_at_all() time = 0.02 sec
>> 4: MPI_File_write_at_all() time = 0.02 sec
>> 7: MPI_File_write_at_all() time = 0.02 sec
>> 5: MPI_File_write_at_all() time = 0.02 sec
>> I tried the same code on other machines and different file
>> systems (eg.
>> PVFS), and timings for both cases were very close to each
>> other. If anyone
>> has access to a Cray XT3 machine, could you please try it and
>> let me know?
>> Thanks.
>> Wei-keng
