[MPICH] problem net_send: could not write to fd=5, errno = 32
Rajeev Thakur thakur at mcs.anl.gov
Mon Jan 15 13:54:29 CST 2007
This program will not run on more than 2 processes because there is only 1
send (from rank 0 to 1), while all other processes call Recv and expect a
message from rank 0.
Rajeev
  _____
From: Luiz Mendes [mailto:luizmendesw at gmail.com]
Sent: Monday, January 15, 2007 1:31 PM
Cc: thakur at mcs.anl.gov; Geoff Jacobs
Subject: Re: [MPICH] problem net_send: could not write to fd=5, errno = 32
Hi Geoff, Rajeev, Antony
Yes, i forgot to write.
But problems continuing to be the same with MPI_Finalize().
After, I was editing that code and i saw that if a process execute
MPI_Recv() that it wasnt destinated to itselft the problem arises.
well, i was thinking that if a process analize one MPI_Recv not destinated
to it, the process simply would ignore it, but this, until this moment, it
seems to be wrong.
thanks, sorry for foolish errors.
Luiz Mendes
2007/1/15, Rajeev Thakur <thakur at mcs.anl.gov>:
You need to add an MPI_Finalize.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Luiz Mendes
Sent: Monday, January 15, 2007 12:22 PM
Cc: Geoff Jacobs
Hi Geoff,
i dont know Geoff, the code is below:
#include "mpi.h"
#include <stdio.h>
#include <string.h>
int main(int argc, char* argv[])
    char mensagem[32];
    int numprocs, rank;
    MPI_Status stat;
    MPI_Init(&argc,&argv);
    MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
    MPI_Comm_rank(MPI_COMM_WORLD,&rank);
    if(rank==0)
        sprintf(mensagem, "Message Text");
        MPI_Send(mensagem, 32, MPI_CHAR, 1, 0, MPI_COMM_WORLD);
    else
        MPI_Recv(mensagem, 32, MPI_CHAR, 0, 0, MPI_COMM_WORLD, &stat);
when i run with mpirun -np 2 it works, and when i run with mpirun -np 3 i
doesnt run and relates the following message below
p2_23214:  p4_error: net_recv read:  probable EOF on socket: 1
bm_list_23184: (0.507200) wakeup_slave: unable to interrupt slave 0 pid
23183
rm_l_1_23213: (0.257494) net_send: could not write to fd=6, errno = 9
rm_l_1_23213:  p4_error: net_send write: -1
    p4_error: latest msg from perror: Bad file descriptor
rm_l_2_23236: (0.045590) net_send: could not write to fd=5, errno = 32
p2_23214: (2.046247) net_send: could not write to fd=5, errno = 32
What it could  be?
I installed MPICH 1.2.7p1 with mode p4 i think. I am trying to run it on two
PCS. I installed MPI in /usr/share/MPI-1 folder and share this one by NFS
server with another PC.
Well i was trying to run another standard example simpleio.c, and it doesnt
store things in other PC.
What is happening?
Luiz Mendes
2007/1/15, Geoff Jacobs <gdjacobs at gmail.com>:
Luiz Mendes wrote:
> HI all,
> i would like to know whats the reason for this error
> what should i do to correct this? I searched for this error in internet
> but i didnt find anything about.
> Its strange, because this error is caused by the increase of number of
> processes in the execution of mpi program.
> Could you help me?
> Thanks
> Luiz Mendes
Segfault?
Geoffrey D. Jacobs
Go to the Chinese Restaurant,
Order the Special
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070115/cceab17c/attachment.htm>
