[MPICH] SSM channel on Solaris 64bit
Rajeev Thakur thakur at mcs.anl.gov
Wed Apr 25 08:51:08 CDT 2007
ssm used to work on Solaris earlier, but not currently. That is why the line
"Please volunteer to fix this code" got added to the error message :-). I
will update the release notes.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of James S Perrin
> Sent: Wednesday, April 25, 2007 5:10 AM
> To: mpich
> Subject: [MPICH] SSM channel on Solaris 64bit
> Hi,
> 	I trying to configure MPICH2 1.0.5p4 on Solaris 9 with
> the Sun Studio
> 11 compilers. I wish to use the ch3:ssm channel. From the
> release notes:
> "The ssm channel uses special interprocess locks (often
> assembly) that
> may not work with some compilers or machine architectures.
> ... It also
> works in Windows and Solaris environments."
> I'm presuming this means if using gcc (the default) under
> Solaris as I
> got the following error:
> configure: error: Use of inline process locks is not
> supported.  Please
> configure: error: Configure of src/mpid/common/locks failed!
> I had set the following env and run configure as:
> CC=cc
> CXX=CC
> CFLAGS=-xarch=v9 -xcode=pic32 -xs -O -xmemalign=8s
> CXXFLAGS=-xarch=v9 -xcode=pic32 -xs -O -xmemalign=8s
> ./configure --with-mpe --with-pm=mpd --with-device=ch3:ssm
> --with-thread-package=pthreads --disable-f77 --disable-f90
> I just needs my suspicions confirmed.
> Regards
> James
> James S. Perrin,                  | email:
> james.perrin at manchester.ac.uk
> Manchester Visualization Centre,  | web:   www.mc.manchester.ac.uk
> Kilburn Building, The University, | tel:   +44 161 275 6945
> Manchester, England. M13 9PL.     | fax:   +44 161 275 0637
> "The test of intellect is the refusal to belabour the obvious"
> - Alfred Bester
