[MPICH] VIsualization ??? FYI - mandel viewer - Just use MPI_Send/MPI_Recv
Jayesh Krishna jayesh at mcs.anl.gov
Tue Apr 24 15:29:24 CDT 2007
  Once you run your programs as shown below (using mpiexec and separating
different executables using ":") you can use any MPI function
(MPI_Send/MPI_Recv/MPI_Bcast etc) to exchange information across the
processes. You do not need to use MPI_Open_port()/MPI_Comm_accept() etc to
communicate across the MPI processes (the gui and process).
Jayesh
-----Original Message-----
Sent: Monday, April 23, 2007 3:11 PM
To: Jayesh Krishna
Subject: Re: [MPICH] VIsualization ??? FYI - mandel viewer
Jayesh:
I have looked at your code and it looks very similar.  I did add the
broadcast of the port_name from the root process to the other processes
and my visualization program could see it.  However, the MPI_Comm_accept
and MPI_Comm_connect pair do not seem to want to talk, even if I start
both programs with something like:
mpiexec -n 4 process : -localonly 1 gui
All the processes report 5 processes, and gui reports its number as 4.
I am about ready to try this with a Unix/Linux box to see if there is
something different (than the behavior on my Windows machines).
Ralph
Jayesh Krishna wrote:
> Hi,
>  I have attached the code for MandelViewer, which is a program similar to
> your requirements. The program opens a port and broadcasts this port
number
> to all visualizers in MPI_COMM_WORLD. The visualizers connect to this port
> and the program sends the appropriate information to the visualizer.
> Regards,
> Jayesh
> From: rppass at rppass.com [mailto:rppass at rppass.com]
> Sent: Tuesday, April 17, 2007 10:54 AM
> To: Jayesh Krishna
> Cc: rppass at rppass.com; 'Trach-Minh Tran'; mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] VIsualization ???
> Thanks you for your efforts.
> SO I take it that if I start the two jobs (computation and visualization)
> with the same mpiexec command, then I can publish names?
> To try to work around this, I start the computation and have it print out
> its port-name (looking like tag=0 port..........)  I then enter that
> port-name into the visualization program and try to connect to that
explicit
> port name.  This does not connect.  So I have two problems!  The first
being
> the name lookup and then the second, if I get the port-name from the name
> lookup, using it to connect (unless the format or structure of the
port-name
> from the name lookup is different than that returned by MPI_OPEN_PORT
> command.
> Ralph
>> Hi,
>>  MPICH2 on windows only supports the smpd process manager. I am
>> currently looking into the code to find out the extend of support
>> available in smpd process manager for publishing a name (You can
>> publish names across MPI processes run using the same mpiexec command
>> using smpd. MPD allows you to specify the machines in the MPD ring
>> during mpdboot time and the published name is published to all the
> machines in the MPD ring.).
>> (Note: There is a -sethosts option in smpd which could be of help. I
>> will dig into the code and let you know soon.)
>> Regards,
>> Jayesh
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
>> Sent: Tuesday, April 17, 2007 7:25 AM
>> To: Trach-Minh Tran
>> Cc: Ralph Pass; mpich-discuss at mcs.anl.gov
>> Naive me, I just got MPICH2 from the MPICH2 web site at Argonne.
>> I am running on Windows XP.
>> How do I tell the version of MPICH2 that I got?
>> Thank you,
>> Ralph Pass
>>> On 04/13/2007 09:26 PM, Ralph Pass wrote:
>>>> I am trying to get a separate process (visualizer) to connect to a
>>>> server for computation of results to be visualized).  I am tyring to
>>>> emulate the code in Using MPI-2 (I downloaded the version yesterday).
>>>> I try to publish the name of the computation program and then accept
>>>> a comm.
>>>> On the visualizer side I try to lookup the name.
>>>> I am using C++ on a Windows XP system.
>>>> I run the computation program (using mpiexec to start it) and it is
>>>> fat and dumb, awaiting a connection  and then a data transfer.
>>>> On the visualization side, when I try the lookup call [looks like:
>>>> MPI_Lookup_name("ImageProcessing", MPI_INFO_NULL, mMPIPortName);]
>>>> I get an error return: 536999969.  When I convert this to a string,
>>>> I
>>>> get:
>>>> Error message Invalid service name (see MPI_Publish_name), error stack:
>>>> MPID_NS_Lookup(70): Lookup failed for service name ImageProcessing
>>>> I start the computation with mpiexec -n 4 processing
>>>> and the visualizer with
>>>> mpiexec -localonly 1 visualizer
>>>> Any help or comments? (Like you need to start the two programs in
>>>> the same mpiexec command)
>>> Which mpiexec did you use? The publish_name/lookup_name does not work
>>> with the OSC's mpiexec. However with the MPICH2 MPD version, it does.
>>> After setting up the MPD with "mpdboot ...", I just run
>>> mpiexec -n 1 ./viz < /dev/null &
>>> mpiexec -n 4 ./comp
>>> Hope this help.
>>> -Minh.
> /* -*- Mode: C; c-basic-offset:4 ; -*- */
>  *  (C) 2001 by Argonne National Laboratory.
>  *      See COPYRIGHT in top-level directory.
> #include <stdio.h>
> #include <stdlib.h>
> #include <math.h>
> #include <string.h>
> #include "mpi.h"
> #ifdef HAVE_WINDOWS_H
> #include <process.h>
> #endif
> /* definitions */
> #define PROMPT 1
> #define USE_PPM /* define to output a color image, otherwise output is a
grayscale pgm image */
> #ifndef MIN
> #define MIN(x, y)	(((x) < (y))?(x):(y))
> #endif
> #ifndef MAX
> #define MAX(x, y)	(((x) > (y))?(x):(y))
> #endif
> #define NOVALUE 99999       /* indicates a parameter is as of yet
unspecified */
> #define MAX_ITERATIONS 10000 /* maximum 'depth' to look for mandelbrot
value */
> #define INFINITE_LIMIT 4.0  /* evalue when fractal is considered diverging
> #define MAX_X_VALUE 2.0     /* the highest x can go for the mandelbrot,
usually 1.0 */
> #define MIN_X_VALUE -2.0    /* the lowest x can go for the mandelbrot,
usually -1.0 */
> #define MAX_Y_VALUE 2.0     /* the highest y can go for the mandelbrot,
usually 1.0 */
> #define MIN_Y_VALUE -2.0    /* the lowest y can go for the mandelbrot,
usually -1.0 */
> #define IDEAL_ITERATIONS 100 /* my favorite 'depth' to default to */
> /* the ideal default x and y are currently the same as the max area */
> #define IDEAL_MAX_X_VALUE 1.0
> #define IDEAL_MIN_X_VALUE -1.0
> #define IDEAL_MAX_Y_VALUE 1.0
> #define IDEAL_MIN_Y_VALUE -1.0
> #define MAX_WIDTH 2048       /* maximum size of image, across, in pixels
> #define MAX_HEIGHT 2048      /* maximum size of image, down, in pixels */
> #define IDEAL_WIDTH 768       /* my favorite size of image, across, in
pixels */
> #define IDEAL_HEIGHT 768      /* my favorite size of image, down, in
pixels */
> #define RGBtocolor_t(r,g,b) ((color_t)(((unsigned char)(r)|((unsigned
short)((unsigned char)(g))<<8))|(((unsigned long)(unsigned char)(b))<<16)))
> #define getR(r) ((int)((r) & 0xFF))
> #define getG(g) ((int)((g>>8) & 0xFF))
> #define getB(b) ((int)((b>>16) & 0xFF))
> typedef int color_t;
> typedef struct complex_t
>   /* real + imaginary * sqrt(-1) i.e.   x + iy */
>   double real, imaginary;
> } complex_t;
> /* prototypes */
> void read_mand_args(int argc, char *argv[], int *o_max_iterations,
> 		    int *o_pixels_across, int *o_pixels_down,
> 		    double *o_x_min, double *o_x_max,
> 		    double *o_y_min, double *o_y_max, int *o_julia,
> 		    double *o_julia_real_x, double *o_julia_imaginary_y,
> 		    double *o_divergent_limit, int *o_alternate,
> 		    char *filename, int *num_colors, int *use_stdin,
> 		    int *save_image);
> void check_mand_params(int *m_max_iterations,
> 		       int *m_pixels_across, int *m_pixels_down,
> 		       double *m_x_min, double *m_x_max,
> 		       double *m_y_min, double *m_y_max,
> 		       double *m_divergent_limit);
> void check_julia_params(double *julia_x_constant, double
*julia_y_constant);
> int additive_mandelbrot_point(complex_t coord_point,
> 			    complex_t c_constant,
> 			    int Max_iterations, double divergent_limit);
> int subtractive_mandelbrot_point(complex_t coord_point,
> complex_t exponential_complex(complex_t in_complex);
> complex_t multiply_complex(complex_t in_one_complex, complex_t
in_two_complex);
> complex_t divide_complex(complex_t in_one_complex, complex_t
in_two_complex);
> complex_t inverse_complex(complex_t in_complex);
> complex_t add_complex(complex_t in_one_complex, complex_t in_two_complex);
> complex_t subtract_complex(complex_t in_one_complex, complex_t
in_two_complex);
> double absolute_complex(complex_t in_complex);
> void dumpimage(char *filename, int in_grid_array[], int in_pixels_across,
int in_pixels_down,
> 	  int in_max_pixel_value, char input_string[], int num_colors,
color_t colors[]);
> int single_mandelbrot_point(complex_t coord_point,
> color_t getColor(double fraction, double intensity);
> int Make_color_array(int num_colors, color_t colors[]);
> void output_data(int *in_grid_array, int coord[4], int *out_grid_array,
int width, int height);
> void PrintUsage(void);
> #ifdef USE_PPM
> const char *default_filename = "pmandel.ppm";
> #else
> const char *default_filename = "pmandel.pgm";
> #endif
> /* Solving the Mandelbrot set
>    Set a maximum number of iterations to calculate before forcing a
terminate
>    in the Mandelbrot loop.
> /* Command-line parameters are all optional, and include:
>    -xmin # -xmax #      Limits for the x-axis for calculating and plotting
>    -ymin # -ymax #      Limits for the y-axis for calculating and plotting
>    -xscale # -yscale #  output pixel width and height
>    -depth #             Number of iterations before we give up on a given
>                         point and move on to calculate the next
>    -diverge #           Criteria for assuming the calculation has been
>                         "solved"-- for each point z, when
>                              abs(z=z^2+c) > diverge_value
>    -julia        Plot a Julia set instead of a Mandelbrot set
>    -jx # -jy #   The Julia point that defines the set
>    -alternate #    Plot an alternate Mandelbrot equation (varient 1 or 2
so far)
> int myid;
> int use_stdin = 0;
> MPI_Comm comm;
> void swap(int *i, int *j)
>     int x;
>     x = *i;
>     *i = *j;
>     *j = x;
> int main(int argc, char *argv[])
>     complex_t coord_point, julia_constant;
>     double x_max, x_min, y_max, y_min, x_resolution, y_resolution;
>     double divergent_limit;
>     char file_message[160];
>     char filename[100];
>     int icount, imax_iterations;
>     int ipixels_across, ipixels_down;
>     int i, j, k, julia, alternate_equation;
>     int imin, imax, jmin, jmax;
>     int temp[5];
>     /* make an integer array of size [N x M] to hold answers. */
>     int *in_grid_array, *out_grid_array = NULL;
>     int numprocs;
>     int  namelen;
>     char processor_name[MPI_MAX_PROCESSOR_NAME];
>     int num_colors;
>     color_t *colors = NULL;
>     MPI_Status status;
>     int save_image = 0;
>     int result;
>     char mpi_port[MPI_MAX_PORT_NAME];
>     MPI_Info info;
>     MPI_Init(&argc, &argv);
>     MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
>     MPI_Comm_rank(MPI_COMM_WORLD, &myid);
>     MPI_Get_processor_name(processor_name, &namelen);
>     if (numprocs == 1)
> 	PrintUsage();
> 	MPI_Finalize();
> 	exit(0);
>     if (myid == 0)
> 	printf("Welcome to the Mandelbrot/Julia set explorer.\n");
> 	/* Get inputs-- region to view (must be within x/ymin to x/ymax,
make sure
> 	xmax>xmin and ymax>ymin) and resolution (number of pixels along an
edge,
> 	N x M, i.e. 256x256)
> 	read_mand_args(argc, argv, &imax_iterations, &ipixels_across,
&ipixels_down,
> 	    &x_min, &x_max, &y_min, &y_max, &julia, &julia_constant.real,
> 	    &julia_constant.imaginary, &divergent_limit,
> 	    &alternate_equation, filename, &num_colors, &use_stdin,
&save_image);
> 	check_mand_params(&imax_iterations, &ipixels_across, &ipixels_down,
> 	    &x_min, &x_max, &y_min, &y_max, &divergent_limit);
> 	if (julia == 1) /* we're doing a julia figure */
> 	    check_julia_params(&julia_constant.real,
&julia_constant.imaginary);
> 	MPI_Bcast(&use_stdin, 1, MPI_INT, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&num_colors, 1, MPI_INT, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&imax_iterations, 1, MPI_INT, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&ipixels_across, 1, MPI_INT, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&ipixels_down, 1, MPI_INT, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&divergent_limit, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&julia, 1, MPI_INT, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&julia_constant.real, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD);
> 	MPI_Bcast(&julia_constant.imaginary, 1, MPI_DOUBLE, 0,
MPI_COMM_WORLD);
> 	MPI_Bcast(&alternate_equation, 1, MPI_INT, 0, MPI_COMM_WORLD);
>     else
MPI_COMM_WORLD);
>     if (myid == 0)
> 	colors = malloc((num_colors+1)* sizeof(color_t));
> 	if (colors == NULL)
> 	    MPI_Abort(MPI_COMM_WORLD, -1);
> 	    exit(-1);
> 	Make_color_array(num_colors, colors);
> 	colors[num_colors] = 0; /* add one on the top to avoid edge errors
>     /* allocate memory */
>     if ( (in_grid_array = (int *)calloc(ipixels_across * ipixels_down,
sizeof(int))) == NULL)
> 	printf("Memory allocation failed for data array, aborting.\n");
> 	exit(-1);
>     if (myid == 0)
> 	int istep, jstep, cur_proc;
> 	int i1[400], i2[400], j1[400], j2[400];
> 	int ii, jj;
> 	char line[1024], *token;
> 	if ( (out_grid_array = (int *)calloc(ipixels_across * ipixels_down,
> 	    exit(-1);
> 	srand(getpid());
> 	if (!use_stdin)
> 	    result = MPI_Info_create(&info);
> 	    if (result != MPI_SUCCESS)
> 		printf("Unable to create an MPI_Info to be used in
MPI_Open_port.\n");
> 	    result = MPI_Open_port(/*info*/MPI_INFO_NULL, mpi_port);
> 		printf("MPI_Open_port failed, aborting.\n");
> 		exit(-1);
> 	    result = MPI_Bcast(mpi_port, MPI_MAX_PORT_NAME, MPI_CHAR, 0,
MPI_COMM_WORLD);
> 		printf("Unable to broadcast the port name to
COMM_WORLD.\n");
> 	    printf("%s listening on port:\n%s\n", processor_name, mpi_port);
> 	    fflush(stdout);
> 	    result = MPI_Comm_accept(mpi_port, info, 0, MPI_COMM_WORLD,
&comm);
> 		printf("MPI_Comm_accept failed, aborting.\n");
> 		exit(-1);
> 	    printf("accepted connection from visualization program.\n");
> 	    fflush(stdout);
> 	    printf("sending image size to visualizer.\n");
> 	    printf("sending pixels_across.\n");
> 	    fflush(stdout);
> 	    result = MPI_Send(&ipixels_across, 1, MPI_INT, 0, 0, comm);
> 		printf("Unable to send pixel width to visualizer,
aborting.\n");
> 	    printf("sending pixels_down.\n");
> 	    fflush(stdout);
> 	    result = MPI_Send(&ipixels_down, 1, MPI_INT, 0, 0, comm);
> 		printf("Unable to send pixel height to visualizer,
aborting.\n");
> 	    printf("sending num_colors.\n");
> 	    fflush(stdout);
> 	    result = MPI_Send(&num_colors, 1, MPI_INT, 0, 0, comm);
> 		printf("Unable to send num_colors to visualizer,
aborting.\n");
> 	    result = MPI_Send(&imax_iterations, 1, MPI_INT, 0, 0, comm);
> 		printf("Unable to send imax_iterations to visualizer,
aborting.\n");
> 	for (;;)
> 	    /* get x_min, x_max, y_min, and y_max */
> 	    if (use_stdin)
> 		printf("input xmin ymin xmax ymax max_iter, (0 0 0 0 0 to
quit):\n");fflush(stdout);
> 		fgets(line, 1024, stdin);
> 		/*printf("read <%s> from stdin\n", line);fflush(stdout);*/
> 		token = strtok(line, " \n");
> 		x_min = atof(token);
> 		token = strtok(NULL, " \n");
> 		y_min = atof(token);
> 		x_max = atof(token);
> 		y_max = atof(token);
> 		imax_iterations = atoi(token);
> 		/*sscanf(line, "%g %g %g %g", &x_min, &y_min, &x_max,
&y_max);*/
> 		/*scanf("%g %g %g %g", &x_min, &y_min, &x_max, &y_max);*/
> 	    else
> 		printf("reading xmin,ymin,xmax,ymax.\n");fflush(stdout);
> 		result = MPI_Recv(&x_min, 1, MPI_DOUBLE, 0, 0, comm,
&status);
> 		    printf("Unable to receive x_min from the visualizer,
aborting.\n");
> 		result = MPI_Recv(&y_min, 1, MPI_DOUBLE, 0, 0, comm,
&status);
> 		    printf("Unable to receive y_min from the visualizer,
aborting.\n");
> 		result = MPI_Recv(&x_max, 1, MPI_DOUBLE, 0, 0, comm,
&status);
> 		    printf("Unable to receive x_max from the visualizer,
aborting.\n");
> 		result = MPI_Recv(&y_max, 1, MPI_DOUBLE, 0, 0, comm,
&status);
> 		    printf("Unable to receive y_max from the visualizer,
aborting.\n");
> 		result = MPI_Recv(&imax_iterations, 1, MPI_INT, 0, 0, comm,
&status);
> 		    printf("Unable to receive imax_iterations from the
visualizer, aborting.\n");
> 	    printf("x0,y0 = (%f, %f) x1,y1 = (%f,%f) max_iter = %d\n",
x_min, y_min, x_max, y_max, imax_iterations);fflush(stdout);
> 	    /* break the work up into 400 pieces */
> 	    istep = ipixels_across / 20;
> 	    jstep = ipixels_down / 20;
> 	    if (istep < 1)
> 		istep = 1;
> 	    if (jstep < 1)
> 		jstep = 1;
> 	    k = 0;
> 	    for (i=0; i<20; i++)
> 		for (j=0; j<20; j++)
> 		    i1[k] = MIN(istep * i, ipixels_across - 1);
> 		    i2[k] = MIN((istep * (i+1)) - 1, ipixels_across - 1);
> 		    j1[k] = MIN(jstep * j, ipixels_down - 1);
> 		    j2[k] = MIN((jstep * (j+1)) - 1, ipixels_down - 1);
> 		    k++;
> 	    /* shuffle the work */
> 	    for (i=0; i<500; i++)
> 		ii = rand() % 400;
> 		jj = rand() % 400;
> 		swap(&i1[ii], &i1[jj]);
> 		swap(&i2[ii], &i2[jj]);
> 		swap(&j1[ii], &j1[jj]);
> 		swap(&j2[ii], &j2[jj]);
> 	    /*printf("bcasting the limits: (%f,%f)(%f,%f)\n", x_min, y_min,
x_max, y_max);fflush(stdout);*/
> 	    /* let everyone know the limits */
> 	    MPI_Bcast(&x_min, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD);
> 	    MPI_Bcast(&x_max, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD);
> 	    MPI_Bcast(&y_min, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD);
> 	    MPI_Bcast(&y_max, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD);
> 	    /* check for the end condition */
> 	    if (x_min == x_max && y_min == y_max)
> 		break;
> 	    /* send a piece of work to each worker (there must be more work
than workers) */
> 	    cur_proc = 1;
> 	    k = 0;
> 	    for (i=1; i<numprocs; i++)
> 		temp[0] = k+1;
> 		temp[1] = i1[k]; /* imin */
> 		temp[2] = i2[k]; /* imax */
> 		temp[3] = j1[k]; /* jmin */
> 		temp[4] = j2[k]; /* jmax */
> 		/*printf("sending work(%d) to %d\n", k+1,
cur_proc);fflush(stdout);*/
> 		MPI_Send(temp, 5, MPI_INT, cur_proc, 100, MPI_COMM_WORLD);
> 		cur_proc++;
> 		k++;
> 	    /* receive the results and hand out more work until the image is
complete */
> 	    while (k<400)
> 		MPI_Recv(temp, 5, MPI_INT, MPI_ANY_SOURCE, 200,
MPI_COMM_WORLD, &status);
> 		cur_proc = temp[0];
> 		MPI_Recv(in_grid_array, (temp[2] + 1 - temp[1]) * (temp[4] +
1 - temp[3]), MPI_INT, cur_proc, 201, MPI_COMM_WORLD, &status);
> 		/* draw data */
> 		output_data(in_grid_array, &temp[1], out_grid_array,
ipixels_across, ipixels_down);
> 		temp[0] = k+1;
> 		temp[1] = i1[k];
> 		temp[2] = i2[k];
> 		temp[3] = j1[k];
> 		temp[4] = j2[k];
> 		k++;
> 	    /* receive the last pieces of work */
> 	    /* and tell everyone to stop */
> 		cur_proc = temp[0];
> 		/* draw data */
> 		temp[0] = 0;
> 		temp[1] = 0;
> 		temp[2] = 0;
> 		temp[3] = 0;
> 		temp[4] = 0;
> 		/*printf("sending %d to tell %d to stop\n", temp[0],
> 	    /* tell the visualizer the image is done */
> 	    if (!use_stdin)
> 		temp[0] = 0;
> 		temp[1] = 0;
> 		temp[2] = 0;
> 		temp[3] = 0;
> 		result = MPI_Send(temp, 4, MPI_INT, 0, 0, comm);
> 		    printf("Unable to send a done command to the visualizer,
aborting.\n");
>     else
> 	if (!use_stdin)
MPI_Open_port.\n");
MPI_COMM_WORLD);
> 		printf("Unable to broadcast the port name on
COMM_WORLD.\n");
> 	    printf("%s listening on port: %s\n", processor_name, mpi_port);
> 	    fflush(stdout);
&comm);
> 		exit(-1);
> 	for (;;)
> 		break;
> 	    x_resolution = (x_max-x_min)/ ((double)ipixels_across);
> 	    y_resolution = (y_max-y_min)/ ((double)ipixels_down);
> 	    MPI_Recv(temp, 5, MPI_INT, 0, 100, MPI_COMM_WORLD, &status);
> 	    while (temp[0] != 0)
> 		imin = temp[1];
> 		imax = temp[2];
> 		jmin = temp[3];
> 		jmax = temp[4];
> 		k = 0;
> 		for (j=jmin; j<=jmax; ++j)
> 		    coord_point.imaginary = y_max - j*y_resolution; /* go
top to bottom */
> 		    for (i=imin; i<=imax; ++i)
> 			/* Call Mandelbrot routine for each code, fill array
with number of iterations. */
> 			coord_point.real = x_min + i*x_resolution; /* go
left to right */
> 			if (julia == 1)
> 			    /* doing Julia set */
> 			    /* julia eq:  z = z^2 + c, z_0 = grid
coordinate, c = constant */
> 			    icount = single_mandelbrot_point(coord_point,
julia_constant, imax_iterations, divergent_limit);
> 			else if (alternate_equation == 1)
> 			    /* doing experimental form 1 */
> 			    icount =
subtractive_mandelbrot_point(coord_point, julia_constant, imax_iterations,
divergent_limit);
> 			else if (alternate_equation == 2)
> 			    /* doing experimental form 2 */
> 			    icount = additive_mandelbrot_point(coord_point,
> 			else
> 			    /* default to doing Mandelbrot set */
> 			    /* mandelbrot eq: z = z^2 + c, z_0 = c, c = grid
coordinate */
coord_point, imax_iterations, divergent_limit);
> 			in_grid_array[k] = icount;
> 			++k;
> 		/* send the result to the root */
> 		temp[0] = myid;
> 		MPI_Send(temp, 5, MPI_INT, 0, 200, MPI_COMM_WORLD);
> 		MPI_Send(in_grid_array, (temp[2] + 1 - temp[1]) * (temp[4] +
1 - temp[3]), MPI_INT, 0, 201, MPI_COMM_WORLD);
> 		/* get the next piece of work */
>     if (myid == 0 && save_image)
> 	imax_iterations = 0;
> 	for (i=0; i<ipixels_across * ipixels_down; ++i)
> 	    /* look for "brightest" pixel value, for image use */
> 	    if (out_grid_array[i] > imax_iterations)
> 		imax_iterations = out_grid_array[i];
> 	if (julia == 0)
> 	    printf("Done calculating mandelbrot, now creating file\n");
> 	else
> 	    printf("Done calculating julia, now creating file\n");
> 	fflush(stdout);
> 	/* Print out the array in some appropriate form. */
> 	if (julia == 0)
> 	    /* it's a mandelbrot */
> 	    sprintf(file_message, "Mandelbrot over (%lf-%lf,%lf-%lf), size
%d x %d",
> 		x_min, x_max, y_min, y_max, ipixels_across, ipixels_down);
> 	else
> 	    /* it's a julia */
> 	    sprintf(file_message, "Julia over (%lf-%lf,%lf-%lf), size %d x
%d, center (%lf, %lf)",
> 		x_min, x_max, y_min, y_max, ipixels_across, ipixels_down,
> 		julia_constant.real, julia_constant.imaginary);
> 	dumpimage(filename, out_grid_array, ipixels_across, ipixels_down,
imax_iterations, file_message, num_colors, colors);
>     MPI_Comm_disconnect(&comm);
>     MPI_Finalize();
>     free(colors);
>     return 0;
> } /* end of main */
>     printf("usage: mpiexec -n x pmandel [options]\n");
>     printf("options:\n -xmin # -xmax #\n -ymin # -ymax #\n -depth #\n
-xscale # -yscale #\n -out filename\n -i\n");
>     printf("All options are optional.\n");
>     printf("-i will allow you to input the min/max parameters from stdin
and output the resulting image to a ppm file.");
>     printf("  Otherwise the root process will listen for a separate
visualizer program to connect to it.\n");
>     printf("The defaults are:\n xmin %f, xmax %f\n ymin %f, ymax %f\n
depth %d\n xscale %d, yscale %d\n %s\n",
> 	IDEAL_MIN_X_VALUE, IDEAL_MAX_X_VALUE, IDEAL_MIN_Y_VALUE,
IDEAL_MAX_Y_VALUE, IDEAL_ITERATIONS,
> 	IDEAL_WIDTH, IDEAL_HEIGHT, default_filename);
>     fflush(stdout);
>     /* fraction is a part of the rainbow (0.0 - 1.0) =
(Red-Yellow-Green-Cyan-Blue-Magenta-Red)
>     intensity (0.0 - 1.0) 0 = black, 1 = full color, 2 = white
>     double red, green, blue;
>     int r,g,b;
>     double dtemp;
>     fraction = fabs(modf(fraction, &dtemp));
>     if (intensity > 2.0)
> 	intensity = 2.0;
>     if (intensity < 0.0)
> 	intensity = 0.0;
>     dtemp = 1.0/6.0;
>     if (fraction < 1.0/6.0)
> 	red = 1.0;
> 	green = fraction / dtemp;
> 	blue = 0.0;
>     else
> 	if (fraction < 1.0/3.0)
> 	    red = 1.0 - ((fraction - dtemp) / dtemp);
> 	    green = 1.0;
> 	    blue = 0.0;
> 	else
> 	    if (fraction < 0.5)
> 		red = 0.0;
> 		green = 1.0;
> 		blue = (fraction - (dtemp*2.0)) / dtemp;
> 	    else
> 		if (fraction < 2.0/3.0)
> 		    red = 0.0;
> 		    green = 1.0 - ((fraction - (dtemp*3.0)) / dtemp);
> 		    blue = 1.0;
> 		else
> 		    if (fraction < 5.0/6.0)
> 			red = (fraction - (dtemp*4.0)) / dtemp;
> 			green = 0.0;
> 			blue = 1.0;
> 		    else
> 			red = 1.0;
> 			green = 0.0;
> 			blue = 1.0 - ((fraction - (dtemp*5.0)) / dtemp);
>     if (intensity > 1)
> 	intensity = intensity - 1.0;
> 	red = red + ((1.0 - red) * intensity);
> 	green = green + ((1.0 - green) * intensity);
> 	blue = blue + ((1.0 - blue) * intensity);
>     else
> 	red = red * intensity;
> 	green = green * intensity;
> 	blue = blue * intensity;
>     r = (int)(red * 255.0);
>     g = (int)(green * 255.0);
>     b = (int)(blue * 255.0);
>     return RGBtocolor_t(r,g,b);
>     double fraction, intensity;
>     int i;
>     intensity = 1.0;
>     for (i=0; i<num_colors; i++)
> 	fraction = (double)i / (double)num_colors;
> 	colors[i] = getColor(fraction, intensity);
>     return 0;
> void getRGB(color_t color, int *r, int *g, int *b)
>     *r = getR(color);
>     *g = getG(color);
>     *b = getB(color);
> 		    char *filename, int *o_num_colors, int *use_stdin,
> 		    int *save_image)
>     int i;
>     *o_julia_real_x = NOVALUE;
>     *o_julia_imaginary_y = NOVALUE;
>     /* set defaults */
>     *o_max_iterations = IDEAL_ITERATIONS;
>     *o_pixels_across = IDEAL_WIDTH;
>     *o_pixels_down = IDEAL_HEIGHT;
>     *o_x_min = IDEAL_MIN_X_VALUE;
>     *o_x_max = IDEAL_MAX_X_VALUE;
>     *o_y_min = IDEAL_MIN_Y_VALUE;
>     *o_y_max = IDEAL_MAX_Y_VALUE;
>     *o_divergent_limit = INFINITE_LIMIT;
>     strcpy(filename, default_filename);
>     *o_num_colors = IDEAL_ITERATIONS;
>     *use_stdin = 0; /* default is to listen for a controller */
>     *save_image = NOVALUE;
>     *o_julia = 0; /* default is "generate Mandelbrot" */
>     *o_alternate = 0; /* default is still "generate Mandelbrot" */
>     *o_divergent_limit = INFINITE_LIMIT; /* default total range is assumed
> 					 if not explicitly overwritten */
>     /* We just cycle through all given parameters, matching what we can.
>     Note that we force casting, because we expect that a nonsensical
>     value is better than a poorly formatted one (fewer crashes), and
>     we'll later sort out the good from the bad
>     for (i = 0; i < argc; ++i) /* grab command line arguments */
> 	if (strcmp(argv[i], "-xmin\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_x_min);
> 	else if (strcmp(argv[i], "-xmax\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_x_max);
> 	else if (strcmp(argv[i], "-ymin\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_y_min);
> 	else if (strcmp(argv[i], "-ymax\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_y_max);
> 	else if (strcmp(argv[i], "-depth\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%d", &*o_max_iterations);
> 	else if (strcmp(argv[i], "-xscale\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%d", &*o_pixels_across);
> 	else if (strcmp(argv[i], "-yscale\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%d", &*o_pixels_down);
> 	else if (strcmp(argv[i], "-diverge\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_divergent_limit);
> 	else if (strcmp(argv[i], "-jx\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_julia_real_x);
> 	else if (strcmp(argv[i], "-jy\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%lf", &*o_julia_imaginary_y);
> 	else if (strcmp(argv[i], "-alternate\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%d", &*o_alternate);
> 	else if (strcmp(argv[i], "-julia\0") == 0)
> 	    *o_julia = 1;
> 	else if (strcmp(argv[i], "-out\0") == 0 && argv[i+1] != NULL)
> 	    strcpy(filename, argv[i+1]);
> 	else if (strcmp(argv[i], "-colors\0") == 0 && argv[i+1] != NULL)
> 	    sscanf(argv[i+1], "%d", &*o_num_colors);
> 	else if (strcmp(argv[i], "-i\0") == 0)
> 	    *use_stdin = 1;
> 	else if (strcmp(argv[i], "-save\0") == 0)
> 	    *save_image = 1;
> 	else if (strcmp(argv[i], "-nosave\0") == 0)
> 	    *save_image = 0;
> 	else if (strcmp(argv[i], "-help\0") == 0)
> 	    PrintUsage();
> 	    MPI_Finalize();
> 	    exit(0);
> 	if (*save_image == NOVALUE)
> 	    if (*use_stdin == 1)
> 		*save_image = 1;
> 	    else
> 		*save_image = 0;
> #if 0
> 	if (myid == 0)
> 	    printf("Doing %d iterations over (%.2lf:%.2lf,%.2lf:%.2lf) on a
%d x %d grid\n",
> 		*o_max_iterations, *o_x_min,*o_x_max,*o_y_min,*o_y_max,
> 		*o_pixels_across, *o_pixels_down);
> #endif
>     /* Get first batch of limits */
> #if PROMPT
>     if (*m_x_min == NOVALUE || *m_x_max == NOVALUE)
> 	/* grab unspecified limits */
> 	printf("Enter lower and higher limits on x (within -1 to 1): ");
> 	scanf("%lf %lf", &*m_x_min, &*m_x_max);
>     if (*m_y_min == NOVALUE || *m_y_max == NOVALUE)
> 	printf("Enter lower and higher limits on y (within -1 to 1): ");
> 	scanf("%lf %lf", &*m_y_min, &*m_y_max);
> #endif
>     /* Verify limits are reasonable */
>     if (*m_x_min < MIN_X_VALUE || *m_x_min > *m_x_max)
> 	printf("Chosen lower x limit is too low, resetting to
%lf\n",MIN_X_VALUE);
> 	*m_x_min = MIN_X_VALUE;
>     if (*m_x_max > MAX_X_VALUE || *m_x_max <= *m_x_min)
> 	printf("Chosen upper x limit is too high, resetting to
%lf\n",MAX_X_VALUE);
> 	*m_x_max = MAX_X_VALUE;
>     if (*m_y_min < MIN_Y_VALUE || *m_y_min > *m_y_max)
> 	printf("Chosen lower y limit is too low, resetting to
%lf\n",MIN_Y_VALUE);
> 	*m_y_min = MIN_Y_VALUE;
>     if (*m_y_max > MAX_Y_VALUE || *m_y_max <= *m_y_min)
> 	printf("Chosen upper y limit is too high, resetting to
%lf\n",MAX_Y_VALUE);
> 	*m_y_max = MAX_Y_VALUE;
>     /* Get second set of limits */
> #if PROMPT
>     if (*m_max_iterations == NOVALUE)
> 	/* grab unspecified limit */
> 	printf("Enter max interations to do: ");
> 	scanf("%d",&*m_max_iterations);
> #endif
>     /* Verify second set of limits */
>     if (*m_max_iterations > MAX_ITERATIONS || *m_max_iterations < 0)
> 	printf("Warning, unreasonable number of iterations, setting to
%d\n", MAX_ITERATIONS);
> 	*m_max_iterations = MAX_ITERATIONS;
>     /* Get third set of limits */
> #if PROMPT
>     if (*m_pixels_across == NOVALUE || *m_pixels_down == NOVALUE)
> 	printf("Enter pixel size (horizonal by vertical, i.e. 256 256): ");
> 	scanf(" %d %d", &*m_pixels_across, &*m_pixels_down);
> #endif
>     /* Verify third set of limits */
>     if (*m_pixels_across > MAX_WIDTH)
> 	printf("Warning, image requested is too wide, setting to %d pixel
width\n", MAX_WIDTH);
> 	*m_pixels_across = MAX_WIDTH;
>     if (*m_pixels_down > MAX_HEIGHT)
> 	printf("Warning, image requested is too tall, setting to %d pixel
height\n", MAX_HEIGHT);
> 	*m_pixels_down = MAX_HEIGHT;
> #if 0
>     printf("%d iterations over (%.2lf:%.2lf,%.2lf:%.2lf), %d x %d grid,
diverge value %lf\n",
> 	*m_max_iterations, *m_x_min,*m_x_max,*m_y_min,*m_y_max,
> 	*m_pixels_across, *m_pixels_down, *m_divergent_limit);
> #endif
*julia_y_constant)
>     /* Hey, we're not stupid-- if they must Prompt, we will also be Noisy
> #if PROMPT
>     if (*julia_x_constant == NOVALUE || *julia_y_constant == NOVALUE)
> 	printf("Enter Coordinates for Julia expansion: ");
> 	scanf("%lf %lf", &*julia_x_constant, &*julia_y_constant);
> #endif
> #if 0
>     /* In theory, any point can be investigated, although it's not much
point
>     if it's outside of the area viewed.  But, hey, that's not our problem
>     printf("Exploring julia set around (%lf, %lf)\n", *julia_x_constant,
*julia_y_constant);
> #endif
> /* This is a Mandelbrot variant, solving the code for the equation:
> z = z(1-z)
> /* This routine takes a complex coordinate point (x+iy) and a value
stating
> what the upper limit to the number of iterations is.  It eventually
> returns an integer of how many counts the code iterated for within
> the given point/region until the exit condition ( abs(x+iy) > limit) was
met.
> This value is returned as an integer.
>     complex_t z_point, a_point; /* we need 2 pts to use in our calculation
>     int num_iterations;  /* a counter to track the number of iterations
done */
>     num_iterations = 0; /* zero our counter */
>     z_point = coord_point; /* initialize to the given start coordinate */
>     /* loop while the absolute value of the complex coordinate is < our
limit
>     (for a mandelbrot) or until we've done our specified maximum number of
>     iterations (both julia and mandelbrot) */
>     while (absolute_complex(z_point) < divergent_limit &&
> 	num_iterations < Max_iterations)
> 	/* z = z(1-z) */
> 	a_point.real = 1.0; a_point.imaginary = 0.0; /* make "1" */
> 	a_point = subtract_complex(a_point,z_point);
> 	z_point = multiply_complex(z_point,a_point);
> 	++num_iterations;
>     } /* done iterating for one point */
>     return num_iterations;
> z = z(z+c)
stating
met.
done */
limit
> 	/* z = z(z+C) */
> 	a_point = add_complex(z_point,coord_point);
> 	++num_iterations;
> z = z(z+1)
stating
met.
> int exponential_mandelbrot_point(complex_t coord_point,
done */
limit
> 	/* z = z(1-z) */
> 	++num_iterations;
> void complex_points_to_image(complex_t in_julia_coord_set[],
> 			     int in_julia_set_size,
> 			     int i_pixels_across,int i_pixels_down,
> 			     int *out_image_final, int *out_max_colors)
>     int i, i_temp_quantize;
>     double x_resolution_element, y_resolution_element, temp_quantize;
>     double x_max, x_min, y_max, y_min;
>     /* Convert the complex points into an image--
>     first, find the min and max for each axis. */
>     x_min = in_julia_coord_set[0].real;
>     x_max = x_min;
>     y_min = in_julia_coord_set[0].imaginary;
>     y_max = y_min;
>     for (i=0;i<in_julia_set_size;++i)
> 	if (in_julia_coord_set[i].real < x_min)
> 	    x_min = in_julia_coord_set[i].real;
> 	if (in_julia_coord_set[i].real > x_max)
> 	    x_max = in_julia_coord_set[i].real;
> 	if (in_julia_coord_set[i].imaginary < y_min)
> 	    y_min = in_julia_coord_set[i].imaginary;
> 	if (in_julia_coord_set[i].imaginary > y_max)
> 	    y_max = in_julia_coord_set[i].imaginary;
>     /* convert to fit image grid size: */
>     x_resolution_element =  (x_max - x_min)/(double)i_pixels_across;
>     y_resolution_element =  (y_max - y_min)/(double)i_pixels_down;
> #ifdef DEBUG
>     printf("%lf %lf\n",x_resolution_element, y_resolution_element);
> #endif
>     /* now we can put each point into a grid space, and up the count of
>     said grid.  Since calloc initialized it to zero, this is safe */
>     /* A point x,y goes to grid region i,j, where
>     xi =  (x-xmin)/x_resolution   (position relative to far left)
>     yj =  (ymax-y)/y_resolution   (position relative to top)
>     This gets mapped to our 1-d array as  xi + yj*i_pixels_across,
>     taken as an integer (rounding down) and checking array limits
>     for (i=0; i<in_julia_set_size; ++i)
> 	temp_quantize =
> 	    (in_julia_coord_set[i].real - x_min)/x_resolution_element +
> 	    (y_max -  in_julia_coord_set[i].imaginary)/y_resolution_element
> 	i_temp_quantize = (int)temp_quantize;
> 	if (i_temp_quantize > i_pixels_across*i_pixels_down)
> 	    i_temp_quantize = i_pixels_across*i_pixels_down;
> #ifdef DEBUG
> 	printf("%d %lf %lf %lf %lf %lf %lf %lf\n",
> 	    i_temp_quantize, temp_quantize, x_min, x_resolution_element,
> 	    in_julia_coord_set[i].real, y_max, y_resolution_element,
> 	    in_julia_coord_set[i].imaginary);
> #endif
> 	++out_image_final[i_temp_quantize];
>     /* find the highest value (most occupied bin) */
>     *out_max_colors = 0;
>     for (i=0;i<i_pixels_across*i_pixels_down;++i)
> 	if (out_image_final[i] > *out_max_colors)
> 	    *out_max_colors = out_image_final[i];
>     complex_t out_complex;
>     double e_to_x;
>     /* taking the exponential,   e^(x+iy) = e^xe^iy = e^x(cos(y)+isin(y)
>     e_to_x = exp(in_complex.real);
>     out_complex.real = e_to_x * cos(in_complex.imaginary);
>     out_complex.imaginary = e_to_x * sin(in_complex.imaginary);
>     return out_complex;
in_two_complex)
>     /* multiplying complex variables-- (x+iy) * (a+ib) = xa - yb + i(xb +
ya) */
>     out_complex.real = in_one_complex.real * in_two_complex.real -
> 	in_one_complex.imaginary * in_two_complex.imaginary;
>     out_complex.imaginary = in_one_complex.real * in_two_complex.imaginary
> 	in_one_complex.imaginary * in_two_complex.real;
>     return out_complex;
in_two_complex)
>     double divider;
>     /* dividing complex variables-- (x+iy)/(a+ib) = (xa - yb)/(a^2+b^2)
>     + i (y*a-x*b)/(a^2+b^2) */
>     divider = (in_two_complex.real*in_two_complex.real -
> 	in_two_complex.imaginary*in_two_complex.imaginary);
>     out_complex.real = (in_one_complex.real * in_two_complex.real -
> 	in_one_complex.imaginary * in_two_complex.imaginary) / divider;
>     out_complex.imaginary = (in_one_complex.imaginary *
> 	in_one_complex.real * in_two_complex.imaginary) / divider;
>     return out_complex;
>     double divider;
>     /* inverting a complex variable: 1/(x+iy) */
>     divider = (in_complex.real*in_complex.real -
> 	in_complex.imaginary*in_complex.imaginary);
>     out_complex.real = (in_complex.real - in_complex.imaginary) / divider;
>     out_complex.imaginary = (in_complex.real - in_complex.imaginary) /
divider;
>     return out_complex;
>     /* adding complex variables-- do by component */
>     out_complex.real = in_one_complex.real + in_two_complex.real;
>     out_complex.imaginary = in_one_complex.imaginary +
>     return out_complex;
in_two_complex)
>     /* subtracting complex variables-- do by component */
>     out_complex.real = in_one_complex.real - in_two_complex.real;
>     out_complex.imaginary = in_one_complex.imaginary -
>     return out_complex;
>     double out_double;
>     /* absolute value is (for x+yi)  sqrt( x^2 + y^2) */
>     out_double = sqrt(in_complex.real*in_complex.real +
>     return out_double;
stating
met.
>     complex_t z_point;  /* we need a point to use in our calculation */
done */
limit
> 	/* z = z*z + c */
> 	z_point = multiply_complex(z_point,z_point);
> 	z_point = add_complex(z_point,c_constant);
> 	++num_iterations;
>     int i, j, k;
>     int result;
>     k = 0;
>     for (j=coord[2]; j<=coord[3]; j++)
> 	for (i=coord[0]; i<=coord[1]; i++)
> 	    out_grid_array[(j * height) + i] = in_grid_array[k];
> 	    k++;
>     if (!use_stdin)
> 	result = MPI_Send(coord, 4, MPI_INT, 0, 0, comm);
> 	    printf("Unable to send coordinates to the visualizer,
aborting.\n");
> 	result = MPI_Send(in_grid_array, (coord[1] + 1 - coord[0]) *
(coord[3] + 1 - coord[2]), MPI_INT, 0, 0, comm);
> 	    printf("Unable to send coordinate data to the visualizer,
aborting.\n");
> /* Writes out a linear integer array of grayscale pixel values to a
> pgm-format file (with header).  The exact format details are given
> at the end of this routine in case you don't have the man pages
> installed locally.  Essentially, it's a 2-dimensional integer array
> of pixel grayscale values.  Very easy to manipulate externally.
> /* You need the following inputs:
> A linear integer array with the actual pixel values (read in as
> consecutive rows),
> The width and height of the grid, and
> The maximum pixel value (to set greyscale range).  We are assuming
> that the lowest value is "0".
int in_pixels_down,
color_t colors[])
>     FILE *ifp;
>     int i, j, k;
> #ifdef USE_PPM
>     int r, g, b;
> #endif
>     printf("%s\nwidth: %d\nheight: %d\ncolors: %d\nstr: %s\n",
> 	filename, in_pixels_across, in_pixels_down, num_colors,
input_string);
>     fflush(stdout);
>     if ( (ifp=fopen(filename, "w")) == NULL)
> 	printf("Error, could not open output file\n");
> 	exit(-1);
> #ifdef USE_PPM
>     fprintf(ifp, "P3\n");  /* specifies type of file, in this case ppm */
>     fprintf(ifp, "# %s\n", input_string);  /* an arbitrary file identifier
>     /* now give the file size in pixels by pixels */
>     fprintf(ifp, "%d %d\n", in_pixels_across, in_pixels_down);
>     /* give the max r,g,b level */
>     fprintf(ifp, "255\n");
>     k=0; /* counter for the linear array of the final image */
>     /* assumes first point is upper left corner (element 0 of array) */
>     if (in_max_pixel_value < 1)
> 	for (j=0; j<in_pixels_down; ++j) /* start at the top row and work
down */
> 	    for (i=0; i<in_pixels_across; ++i) /* go along the row */
> 		fprintf(ifp, "0 0 0 ");
> 	    fprintf(ifp, "\n"); /* done writing one row, begin next line */
>     else
down */
> 		getRGB(colors[(in_grid_array[k] * num_colors) /
in_max_pixel_value], &r, &g, &b);
> 		fprintf(ifp, "%d %d %d ", r, g, b); /* +1 since 0 = first
color */
> 		++k;
> #else
>     fprintf(ifp, "P2\n");  /* specifies type of file, in this case pgm */
>     /* gives max number of grayscale levels */
>     fprintf(ifp, "%d\n", in_max_pixel_value+1); /* plus 1 because 0=first
color */
>     for (j=0;j<in_pixels_down;++j) /* start at the top row and work down
> 	for (i=0;i<in_pixels_across;++i) /* go along the row */
> 	    fprintf(ifp, "%d ", in_grid_array[k]+1); /* +1 since 0 = first
color */
> 	    ++k;
> #endif
>     fclose(ifp);
