[MPICH] MPI-IO, reading in c++ from fortran generated file
Rob Ross rross at mcs.anl.gov
Mon Apr 23 21:07:24 CDT 2007
Hi Russell,
Sure you can read them, it's just that MPI-IO doesn't have any mechanism
for *interpreting* whatever "stuff" fortran is putting in there.
Note that there is no standard for unformatted fortran files, so just
doing this in MPI-IO would be difficult, especially if one wanted to be
able to read an unformatted fortran file from another system/compiler
(which people would invariably try to do). Looks like your version of
fortran uses the "surround records with byte lengths" system, which is
where those 4s and 12s come from.
Rob
Russell L. Carter wrote:
> Now that I've looked into it, unformatted fortran files become
> even more complicated to deal with because of the record header/
> trailers when implementing collective IO.  Just in case I've
> missed something, is it true there is no way to read unformatted
> fortran files with MPI-IO?
> It's obvious once you think about it, but it would have been nice
> to have that pointed out in the "Using MPI-2" book.  (Maybe it is?)
> Thanks,
> Russell
