[MPICH] Help With I/O
Erich Peterson erichpeterson at hotmail.com
Wed Apr 18 12:39:09 CDT 2007
Hi, the reasoning behind the if statements on the last process, is I might need to allocate 1 or 2 more elements to the last process it the vector_size / num_processes is not an even number. As far as debugging goes I have debugged it to the for loop, and everything seems fine until it. I think it has something to do with needing to have a lock on one or both of the file accesses. The problem is I have very limited knowledge of MPI-IO and was hoping someone who does could easily see what I am doing wrong with the I/O part. Thanks,Erich
From: matthew.chambers at vanderbilt.eduTo: mpich-discuss at mcs.anl.govSubject: Re: [MPICH] Help With I/ODate: Wed, 18 Apr 2007 09:39:50 -0500
Hi Erich,
Frankly the code leading up to that for loop is a bit scary.  I don’t really know anything about MPI I/O, but I can get you a few tips on your C++:
-          Unless you’re using a horribly out of date compiler like MSVC 6, you should use the standard header names <iostream>, <vector>, <ctime>, etc.
-          If you are using a horribly out of date compiler like MSVC 6, you should upgrade to the free MSVC++ 2005 Express Edition.
-          In this case it’s a cosmetic fix, but you should probably pass the vector<bool> parameter by reference instead of by value.
-          You seem to be doing some mind boggling casting in order to determine if num_elements_per_rank is too big to fit in an int (but only on your last process?).  You might get rid of that voodoo by using size_t (usually at least an unsigned 4 byte int) for your position indexes instead (vector<T>::size() returns vector<T>::size_type which usually boils down to size_t).
Beyond that, I would need to see some debug output from your for loop.  For example, what indexes are actually being passed to the I/O calls by each process?  Does MPI::File::Read_at() allocate memory for the “buf” variable you pass it?  If not, you haven’t allocated any memory for it and that would lead to a crash before you could say “new char.”
Good luck,
Matt Chambers
From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Erich PetersonSent: Wednesday, April 18, 2007 3:02 AMTo: mpich-discuss at mcs.anl.govSubject: [MPICH] Help With I/O
Hi all, I'm trying to write this little routine which is part of my graduate project. What I'm trying to do is pass a vector of bools in to the QueryData method. In that method I split the vector up into equal parts among the number of processes, have each process open a datafile which as 20 byte records (no new lines), read that record from the file if the vector they are checking has "true" (basically if vector[0] = true, it means grab the first record of the file), and lastly, it should output that record into a new file. I have been able to determine it is messing up on the for-loop. The error is: [Student at cluster1 erich_test_area]$ mpiexec -n 3 /mnt/pvfs2/acxiom/erich_test_area/RecordRetrievalterminate called after throwing an instance of 'MPI::Exception'terminate called after throwing an instance of 'MPI::Exception'terminate called after throwing an instance of 'MPI::Exception'rank 0 in job 1  cluster1_33602   caused collective abort of all ranks  exit status of rank 0: killed by signal 6 If someone could please tell me or edit the code if they see what is wrong. Thanks! Main.cpp:#include "RecordRetrieval.h"#include <vector.h>int main(){   vector<bool> vec;   vec.push_back(true);   vec.push_back(false);   vec.push_back(true);   vec.push_back(false);   vec.push_back(true);   vec.push_back(false);   RecordRetrieval rec;   rec.QueryData(vec, "test.dat");   return 0;}RecordRetrieval.cpp: #include "RecordRetrieval.h"#include "mpi.h"#include "time.h"#include "iostream.h"void RecordRetrieval::QueryData(vector<bool> unencoded_vector, char * filename){    int num_processes;    int num_vector_elements;    float num_elements_per_rank;    int local_start_position;    int local_end_position;    char * buf;    int my_rank;    MPI::File input_file;    MPI::Status input_file_status;    MPI::File output_file;    MPI::Status output_file_status;    //MPI::Offset filesize;    char output_filename[30];    size_t i;    struct tm tim;    time_t now;    now = time(NULL);    tim = *(localtime(&now));    i = strftime(output_filename, 30, "%m_%d_%Y_%H_%M_%S", &tim);    /* Let the system do what it needs to start up MPI */    MPI::Init();    /* Get my process rank */    my_rank = MPI::COMM_WORLD.Get_rank();    /* Find out how many processes are being used */    num_processes = MPI::COMM_WORLD.Get_size();    num_vector_elements = unencoded_vector.size();    num_elements_per_rank = num_vector_elements / num_processes;    local_start_position = my_rank * (int)num_elements_per_rank;    if(my_rank == num_processes - 1)    {        if(num_elements_per_rank * num_processes == (int)num_elements_per_rank * num_processes)        {            local_end_position = local_start_position + ((int)num_elements_per_rank - 1);        }        else        {            local_end_position = (local_start_position + (int)num_elements_per_rank - 1) +                (((int)num_elements_per_rank * num_processes) - ((int)num_elements_per_rank * num_processes));        }    }    else    {        local_end_position = local_start_position + ((int)num_elements_per_rank - 1);    }    input_file = MPI::File::Open(MPI::COMM_WORLD, filename, MPI::MODE_RDONLY,                    MPI::INFO_NULL);    output_file = MPI::File::Open(MPI::COMM_WORLD, output_filename, MPI::MODE_CREATE | MPI::MODE_WRONLY, MPI::INFO_NULL);    // filesize = input_file.Get_size();    for(int i = local_start_position; i < local_end_position + 1; i++)    {        if(unencoded_vector[i])        {            input_file.Read_at(i * 20, buf, 20, MPI_CHAR, input_file_status);            output_file.Write_shared(buf, 20, MPI_CHAR, output_file_status);        }    }    cout << "Error";    input_file.Close();    output_file.Close();                                               MPI::Finalize();}
Discover the new Windows Vista Learn more!
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070418/f70ab624/attachment.htm>
