[MPICH] configure broken in 1.0.5p4
Steve Kargl sgk at troutmask.apl.washington.edu
Tue Apr 3 17:31:35 CDT 2007
On Tue, Apr 03, 2007 at 04:19:14PM -0500, Darius Buntinas wrote:
> What operating system/distro are you using?
FreeBSD 6.2-stable.
> What version of bash do you have?
That's the problem.  I don't use bash and don't normally
have it installed on FreeBSD.  I had to retrieve bash,
via FreeBSD ports collection, install it, and then build
1.0.5p4.  FreeBSD's Bourne shell is based on ashe, and
AFAIK sh is targetted at posix compliance.
> Thanks,
> Darius
> Steve Kargl wrote:
> >After unpackage mpich2-1.0.5p4.tar.gz, I tried to configure
> >the software with the following command line.
> >./configure --with-device=ch3:nemesis --prefix=/usr/local --enable-fast
> >shich eventually dies with
> >RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
> >sourcing
> >/usr/tmp/mpich2-1.0.5p4/src/mpid/ch3/channels/nemesis/setup_channel
> >RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
> >eval: 1: Syntax error: word unexpected (expecting ")")
Steve
