[MPICH] ROMIO MPI_FILE_WRITE ALL
    Stephen Scott
    stephen.scott at imperial.ac.uk
    Tue Jun 28 15:16:31 CDT 2005
Dear list again,
I may have found the problem.  If I change 'USE mpi' to 'INCLUDE
'mpif.h' the program appears to run and compile without errors.  Does
anyone have an explanation for this?
Cheers,
Steve
On 28 Jun 2005, at 19:52, Stephen Scott wrote:
> Dear list,
> I have a question/problem related to the use of MPI_FILE_WRITE_ALL
> from the ROMIO package.  I want to write a distributed 4D fortran
> array to file using the ROMIO library.  The array is divided along the
> third dimension.   A section of the code is listed below.
> The purpose of the subroutine is to write the 4D fluid_uk(:,:,:,:)
> distributed array to file on node 0.  However, I get a compile time
> error for the call to MPI_FILE_WRITE_ALL  - 'There is no matching
> specific subroutine for this generic subroutine call.
> [MPI_FILE_WRITE_ALL]'
> I presumed that MPI_FILE_WRITE_ALL would accept an array of any
> dimension but it appears I am wrong.  I would be most grateful for any
> feedback or suggestions for the list!
> Thanks in advance!
> Steve
> mpich-1.2.6
> intel compilers 8.0
> Red Hat Enterprise Linux WS release 3 (Taroon Update 1)
> SUBROUTINE fluid_restart_write(time,ierr)
>    USE precision
>    USE fluid_arrays,    ONLY : fluid_uk
>    USE domain_params,   ONLY : ni,nj,nk
>    USE mpi
>    IMPLICIT NONE
>    INTEGER,INTENT(INOUT)           :: ierr
>    INTEGER,INTENT(IN)              :: time
>    INTEGER                         :: myrank
>    INTEGER                         :: nprocs
>    INTEGER*8                       :: disp=0
>    CHARACTER(len=100)              :: tstep
>    CHARACTER(len=10)               :: execute_date
>    CHARACTER(len=10)               :: execute_time
>    INTEGER,PARAMETER               :: MASTER = 0
>    INTEGER                         :: gsizes(4)
>    INTEGER                         :: distribs(4)
>    INTEGER                         :: dargs(4)
>    INTEGER                         :: psizes(4)
>    INTEGER                         :: local_size
>    INTEGER                         :: PANDORA_RESTART_TYPE
>    INTEGER                         :: PANDORA_RESTART_FILE
>    INTEGER                         :: PANDORA_COMM
>    INTEGER                         :: status(MPI_STATUS_SIZE)
>    CALL MPI_COMM_RANK(MPI_COMM_WORLD,myrank,ierr)
>    CALL MPI_COMM_SIZE(MPI_COMM_WORLD,nprocs,ierr)
>    gsizes   = (/ni,nj,nk,3/)
>    distribs = MPI_DISTRIBUTE_BLOCK
>    dargs    = MPI_DISTRIBUTE_DFLT_DARG
>    psizes   = (/1,1,nprocs,1/)
>    CALL
> MPI_TYPE_CREATE_DARRAY(nprocs,myrank,4,gsizes,distribs,dargs,psizes, &
> MPI_ORDER_FORTRAN,MPI_DOUBLE_COMPLEX,PANDORA_RESTART_TYPE,ierr)
>    CALL MPI_TYPE_COMMIT(PANDORA_RESTART_TYPE,ierr)
>    ! fname_frestart defined earlier in module
>    CALL
> MPI_FILE_OPEN(MPI_COMM_WORLD,fname_frestart,MPI_MODE_WRONLY+MPI_MODE_CR
> EATE, &
>                       MPI_INFO_NULL,PANDORA_RESTART_FILE,ierr)
>    CALL
> MPI_FILE_SET_VIEW(PANDORA_RESTART_FILE,disp,MPI_DOUBLE_COMPLEX,PANDORA_
> RESTART_TYPE, &
>                           "native",MPI_INFO_NULL,ierr)
>    ! fluid_uk(ni,nj,nk/nprocs,3)
>    local_size = ni*nj*(nk/nprocs)*3
>    CALL
> MPI_FILE_WRITE_ALL(PANDORA_RESTART_FILE,fluid_uk,local_size,MPI_DOUBLE_
> COMPLEX,status,ierr)
>    CALL MPI_FILE_CLOSE(PANDORA_RESTART_FILE,ierr)
> END SUBROUTINE
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20050628/3bb508f9/attachment.bin>
