[MPICH] Name Publishing
Rajeev Thakur thakur at mcs.anl.gov
Sun Aug 14 18:24:55 CDT 2005
I can run these programs with our latest source in CVS without any problem.
Which version of MPICH2 are you using? Try version 1.0.2 if you are using an
older version. (I didn't check whether this works with 1.0.2).
Are you running the server in the background? If so, you need to do
mpiexec -n 1 server < /dev/null &
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> lunasole at interfree.it
> Sent: Tuesday, August 02, 2005 2:20 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Name Publishing
> Hi
> I impemented a simple application Client/Server using Name Publishing.
> I launched Server with mpiexec command. The Server associated
> a port name with a private name "SERVER".  After I
> launched client on another machine. It looked the port name
> up by passing name "SERVER" to MPI_Lookup_name.
> with LAM I have no problem for this implementation.
> with MPICH2 i have the following error message on client side:
>         ercole Name_Server]$ mpiexec -n 1 -path
> sample_MPICH2_MPI/MPI-2/Name_Server/ client
>         Port_name= port#32867$description#ercole$rank 0 in
> job 1  ercole_32771   causedcollective abort of all ranks
> exit status of rank 0: killed by signal 9
> What is the problem?
> Thank's.
>    Rosalia Salvatore
> Client and Server implementation:
> //SERVER
> #include <stdio.h>
> #include <mpi.h>
> #define NUM_LOOP 200
> #define MAX_DATA 200
> #define TIMER_ELAPSED \
>  ( ( tv2.tv_usec - tv1.tv_usec ) \
>   + ( ( tv2.tv_sec - tv1.tv_sec) * 1.E6 ) )
> int main (int argc, char* argv[])
>  int rank, size,again,i;
>  static int count=0;
>  MPI_Comm client;
>  MPI_Status status;
>  char port_name[MPI_MAX_PORT_NAME];
>  double buf[MAX_DATA];
>  int time[NUM_LOOP];
>  MPI_Init(&argc,&argv); /* Initialize MPI */
>  MPI_Comm_rank(MPI_COMM_WORLD, &rank); /* Get rank */
>  MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the LAM
> universe */
>  if (size != 1)
>   printf("Error");
>   return -1;
>  //printf("CIAO\n");
>  MPI_Open_port (MPI_INFO_NULL,port_name);
>  printf("port_name= %s\n", port_name);
>  MPI_Publish_name("SERVER",MPI_INFO_NULL,port_name);
>  printf("waiting...\n");
>  while(1)
>   MPI_Comm_accept (port_name, MPI_INFO_NULL, 0,
> MPI_COMM_WORLD, &client);
>   again=1;
>   while (again == 1)
>    printf("\nReceive\n");
> MPI_Recv(buf,MAX_DATA,MPI_DOUBLE,MPI_ANY_SOURCE,MPI_ANY_TAG,
> client, &status);
>    MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, 2, client);
>    printf("MPI_TAG =%d\n ", status.MPI_TAG);
>    switch(status.MPI_TAG)
>     case 0:
>      MPI_Comm_free(&client);
>      MPI_Close_port(port_name);
>      MPI_Finalize();
>      return 0;
>     case 1:
> 					MPI_Comm_disconnect(&client);
> 					again =0;
> 					break;
> 				case 2:
> 					//for (i=0;i<MAX_DATA;i++)
> 					printf("buf[%d]= %f",1,buf[1]);
> 					//}//end for
> 					break;
> 				default:
>      MPI_Abort (MPI_COMM_WORLD,1);
>      break;
>    } //end of switch
>   } //end while again
> } //infinity
> // CLIENT
> #include <stdio.h>
> #include <mpi.h>
> #include <sys/time.h>
> #define LOOP 10000
>  int rank, size,i, tag=0, done=1;
>  MPI_Comm server;
>  MPI_Status status;
>  double var=0.0;
>    int time[LOOP];
>  struct timeval tv1, tv2;
>  FILE *fp;
>  long max=0, min=20000000;
>  //MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the
> LAM universe */
>  MPI_Lookup_name("SERVER", MPI_INFO_NULL, port_name);
>  printf("\nMPI_Lookup_name Port_name= %s", port_name);
>  MPI_Comm_connect (port_name, MPI_INFO_NULL,0,
> MPI_COMM_WORLD, &server);
>   buf[i]= i*2.0;
>   //printf("buf[%d]= %f\t",i,buf[i]);
>  tag=2;
>  for(i=0;i<LOOP;i++)
>   gettimeofday(&tv1, NULL);
>   MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, tag, server);
> server, &status);
>   gettimeofday(&tv2, NULL);
>   time[i]=(int)TIMER_ELAPSED;
>   printf("\nsend and receive con buf[%d]= %f\n",1,buf[1]);
>   printf("Client Tempo[%d]= %d\n",i, time[i]);
>  } //end for
>  tag=1;
> 	printf("\nSend con tag 1\n");
> 	MPI_Comm_disconnect(&server);
> 	MPI_Finalize();
> 	/* *************** TIME RESULTS ***************** */
> 	fp= fopen("Results.txt","w");
> 	for(i=0;i<LOOP;i++)
> 		fprintf(fp,"%d    %ld \n", i+1 ,time[i]);
> 		var=var+time[i];
> 		if(time[i]<min) min=time[i];
>     		if(time[i]>max) max=time[i];
> 	var=var/LOOP-1;
> 	printf("Tempo del client %d = %f usec\n",rank,var);
>  fprintf(fp,"LATENCY TIME MIN = %ld microsec\n", min);
>  fprintf(fp,"LATENCY TIME MAX = %ld microsec\n", max);
>  fprintf(fp,"LATENCY TIME AVERAGE = %f microsec\n", var);
>  fclose (fp);
>  return 0;
> Visita http://domini.interfree.it, il sito di Interfree dove trovare
> soluzioni semplici e complete che soddisfano le tue esigenze
> in Internet,
> ecco due esempi di offerte:
> -  Registrazione Dominio: un dominio con 1 MB di spazio disco
> +  2 caselle
>    email a soli 18,59 euro
> -  MioDominio: un dominio con 20 MB di spazio disco + 5 caselle email
>    a soli 51,13 euro
> Vieni a trovarci!
> Lo Staff di Interfree
