[MOAB-dev] OBB ray firing questions
Tim Tautges ttautges at divergent3d.com
Thu Dec 15 11:48:46 CST 2022
Sounds good, looking forward to it.
- tim
Tim Tautges
Technical Fellow, Divergent3D
Sent: Wednesday, December 14, 2022 8:24 PM
To: Tim Tautges <ttautges at divergent3d.com>; moab-dev at mcs.anl.gov <moab-dev at mcs.anl.gov>
Cc: Shriwise, Patrick C <pshriwise at anl.gov>
Subject: Re: OBB ray firing questions
You don't often get email from paul.wilson at wisc.edu. Learn why this is important<https://aka.ms/LearnAboutSenderIdentification>
Caution: This email originated from outside of the organization. Do not click links, open attachments, or respond unless you recognize the sender’s email address and know the content is safe and legitimate.
Hi Tim,
This is probably a question that Patrick or I are probably best to respond to.  That said, I’ll need to take some time with the code to remind myself how it all works.
Paul
Paul P.H. Wilson (he/him/his)
Grainger Professor of Nuclear Engineering
Chair, Department of Engineering Physics
o: 608-263-0807, c: 608-469-9615
paul.wilson at wisc.edu<mailto:paul.wilson at wisc.edu>
153 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
Zoom Meeting Room: https://uwmadison.zoom.us/j/6082630807
Zoom Phone Access: +1-929-205-6099, Access code: 6082630807
Computational Nuclear Engineering Research Group<http://cnerg.engr.wisc.edu>
From: moab-dev <moab-dev-bounces at mcs.anl.gov> on behalf of Tim Tautges <ttautges at divergent3d.com>
Date: Monday, December 12, 2022 at 18:19
To: moab-dev at mcs.anl.gov <moab-dev at mcs.anl.gov>
Subject: [MOAB-dev] OBB ray firing questions
Hi all,
  I'm attempting to use OrientedBoxTreeTool to do some ray tracing on a shell of triangles. I'm observing two problems:
  *   When I call OBTT::ray_intersect_triangles, the results come back but are not sorted by distance. Is there some reason they're not?
  *   If I try calling OBTT::ray_intersect_sets, with the variant that does not take an IntRegCtxt argument, the code asserts in RayIntesectsSets::leaf with lastSet == 0, implying that there's some function that should be called before this.
Am I using this tool wrongly? Note, for the first bug above, I tried running obb_test on that same file with the offending ray start/direction, and got the same (unsorted) results.
- tim
