[MOAB-dev] MOAB v5.4.0 is now available
Vijay S. Mahadevan vijay.m at gmail.com
Sun Jul 24 15:24:09 CDT 2022
Dear MOAB users,
A major update to the MOAB library is now available. The tarball can
be downloaded from [1]. If you are working with release branches in
Bitbucket, please use the newly created "5.4.0" tag to get the latest
changes.
Some notable updates:
- Significant updates to the iMOAB API for Fortran compatibility based
on 2003 ISO_C_BINDING specifications. Support for F77 dropped.
- New Parallel SCRIP NetCDF file reader for climate meshes and data
- Several new compare tools for climate remap files
- Better configuration/installation mechanisms for PyMOAB
- Reduced memory allocation for vertex tags defined on sequences
(16*1024 instead of 512*1024)
- Fixed several compiler warnings, documentation, updated autotools
support (autoconf<=2.71), updated CMake/PyMOAB support, parallel build
with module dependency (iMOAB), Codacy issues
As always, please do let us know if there are any issues with the new release.
Best,
Vijay
[1] https://ftp.mcs.anl.gov/pub/fathom/moab-5.4.0.tar.gz
