[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
Jason Kraftcheck kraftche at cae.wisc.edu
Wed Mar 9 16:18:01 CST 2011
On 03/09/2011 04:17 PM, Tim Tautges wrote:
> This isn't not only possible, it's likely, given the wide use of GLOBAL_ID.
GLOBAL_ID is an integer tag, not a handle tag.
- jason
> - tim
> On 03/09/2011 04:13 PM, Jason Kraftcheck wrote:
>>> Also, what happens if/when a tag of
>>> handle type is set with both entity and entity set handles?
>> Well, ITAPS doesn't allow that.  If someone does it via MOAB (the MOAB
>> API
>> (either directly or indirectly via a file), then there isn't much we
>> can do.
>> - jason
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
