[MOAB-dev] r3676 - in MOAB/trunk: . config doc examples examples/simple itaps itaps/igeom itaps/imesh src src/io src/io/mhdf src/moab src/oldinc src/parallel test test/dual test/h5file test/io test/obb test/oldinc test/parallel test/perf tools tools/dagmc tools/mbcoupler tools/mbperf tools/mbzoltan tools/mcnpmit
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Fri Mar 19 11:56:45 CDT 2010
Author: kraftche
Date: 2010-03-19 11:56:45 -0500 (Fri, 19 Mar 2010)
New Revision: 3676
Modified:
   MOAB/trunk/
   MOAB/trunk/config/
   MOAB/trunk/doc/
   MOAB/trunk/examples/
   MOAB/trunk/examples/simple/
   MOAB/trunk/itaps/
   MOAB/trunk/itaps/igeom/
   MOAB/trunk/itaps/imesh/
   MOAB/trunk/src/
   MOAB/trunk/src/io/
   MOAB/trunk/src/io/mhdf/
   MOAB/trunk/src/moab/
   MOAB/trunk/src/oldinc/
   MOAB/trunk/src/parallel/
   MOAB/trunk/test/
   MOAB/trunk/test/dual/
   MOAB/trunk/test/h5file/
   MOAB/trunk/test/io/
   MOAB/trunk/test/obb/
   MOAB/trunk/test/oldinc/
   MOAB/trunk/test/parallel/
   MOAB/trunk/test/perf/
   MOAB/trunk/tools/
   MOAB/trunk/tools/dagmc/
   MOAB/trunk/tools/mbcoupler/
   MOAB/trunk/tools/mbperf/
   MOAB/trunk/tools/mbzoltan/
   MOAB/trunk/tools/mcnpmit/
Log:
update subversion ignore rules
Property changes on: MOAB/trunk
___________________________________________________________________
Modified: svn:ignore
   - include
config.status
config.log
config.guess
testdir.h
install-sh
MBConfig.h
Makefile
configure
config.sub
bin
autom4te.cache
missing
moab.make
ltmain.sh
share
MBEntityHandle.h
lib
aclocal.m4
Makefile.in
depcomp
config.h
.deps
config.h.in
libtool
.libs
stamp-h1
stamp-h2
   + configure
libtool
aclocal.m4
config.log
config.h
config.h.in
config.status
autom4te.cache
Makefile.in
Makefile
moab.make
moab.config
stamp-*
Property changes on: MOAB/trunk/config
Added: svn:ignore
   + depcomp
config.guess
config.sub
ltmain.sh
missing
install-sh
Property changes on: MOAB/trunk/doc
   - Makefile
Makefile.in
.deps
.libs
   + Makefile
Makefile.in
user.dox
html
Property changes on: MOAB/trunk/examples
Added: svn:ignore
   + Makefile.in
Makefile
.deps
examples.make
FileRead
GetEntities
GeomSetHierarchy
SkinMesh
SetsNTags
SurfArea
Property changes on: MOAB/trunk/examples/simple
Added: svn:ignore
   + makefile
Property changes on: MOAB/trunk/itaps
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
Property changes on: MOAB/trunk/itaps/igeom
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
iGeom-Defs.inc
iGeom_protos.h
testgeom
Property changes on: MOAB/trunk/itaps/imesh
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
iMesh_extensions_protos.h
iMeshP_protos.h
iMesh-Defs.inc
iMesh_protos.h
testc_cbind
partest
Property changes on: MOAB/trunk/src
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
stamp-*
MBCN_protos.h
FCDefs.h
MOAB_FCDefs.h
Property changes on: MOAB/trunk/src/io
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
stamp-*
Property changes on: MOAB/trunk/src/io/mhdf
Added: svn:ignore
   + Makefile.in
Makefile
.deps
h5minfo
Property changes on: MOAB/trunk/src/moab
Added: svn:ignore
   + Version.h
EntityHandle.hpp
stamp-*
Property changes on: MOAB/trunk/src/oldinc
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
stamp-*
Property changes on: MOAB/trunk/src/parallel
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
stamp-*
moab_mpi_config.h
Property changes on: MOAB/trunk/test
   - Makefile
Makefile.in
.deps
.libs
   + Makefile
Makefile.in
.deps
.libs
seq_man_test
mesh_set_test
tag_test
mbcn_test
xform_test
bsp_tree_test
kd_tree_tool
kd_tree_test
test_adj
homxform_test
obb_test
adaptive_kd_tree_tests
scdseq_test
geom_util_test
var_len_test
file_options_test
kd_tree_time
bsp_tree_poly_test
var_len_test_no_template
moab_test
merge_test.ncdf
cell1.gen
cell2.gen
mb_write.g
mb_write2.g
tet_mid_face_nodes.g
hex_mid_volume_nodes.g
mb_big_test.g
tri_mid_edge_face_nodes.g
hex_mid_edge_face_vol_nodes.g
mb_stress_out.g
hex_mid_edge_nodes.g
tet_mid_edge_nodes.g
tet_mid_edge_face_nodes.g
Property changes on: MOAB/trunk/test/dual
   - Makefile
Makefile.in
.deps
.libs
   + Makefile
Makefile.in
.deps
.libs
dual_test
Property changes on: MOAB/trunk/test/h5file
   - Makefile
Makefile.in
.deps
.libs
   + Makefile
Makefile.in
.deps
.libs
h5varlen
h5partial
h5legacy
h5sets_test
h5test
h5regression
Property changes on: MOAB/trunk/test/io
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
tqdcfr
gmsh_test
nastran_test
stl_test
vtk_test
exodus_test
cub_file_test
Property changes on: MOAB/trunk/test/obb
   - Makefile
Makefile.in
.deps
.libs
   + Makefile
Makefile.in
.deps
.libs
obb_time
obb_test
obb_tree_tool
Property changes on: MOAB/trunk/test/oldinc
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
test_oldinc
Property changes on: MOAB/trunk/test/parallel
Added: svn:ignore
   + Makefile
Makefile.in
.deps
.libs
mbparallelcomm_test
mhdf_parallel
parallel_hdf5_test
parallel_write_test
uber_parallel_test
scdtest
pcomm_unit
pcomm_serial
parallel_unit_tests
tmp?.h5m
mhdf_ll.h5m
Property changes on: MOAB/trunk/test/perf
   - Makefile.in
   + Makefile
Makefile.in
.deps
.libs
point_in_elem
perf
seqperf
adj_time
Property changes on: MOAB/trunk/tools
   - Makefile
Makefile.in
.deps
.libs
   + mbdepth
mbsize
mbtagprop
mbgsets
hexmodops
spheredecomp
mbskin
mbsurfplot
mbconvert
Makefile
Makefile.in
.deps
.libs
Property changes on: MOAB/trunk/tools/dagmc
   - dagmc.make
cgm2moab
Makefile
Makefile.in
.deps
.libs
   + dagmc.make
cgm2moab
Makefile
Makefile.in
.deps
.libs
quads_to_tris
ray_fire_test
pt_vol_test
test_geom
update_coords
Property changes on: MOAB/trunk/tools/mbcoupler
   - Makefile.in
   + Makefile
Makefile.in
.deps
.libs
stamp-*
elem_util_test
findpt_test
mbcoupler_test
Property changes on: MOAB/trunk/tools/mbperf
   - Makefile
Makefile.in
.deps
.libs
   + Makefile
Makefile.in
.deps
.libs
stamp-*
mbperf_iMesh
mbperf
Property changes on: MOAB/trunk/tools/mbzoltan
   - Makefile
Makefile.in
.deps
.libs
Config.moab
   + Makefile
Makefile.in
.deps
.libs
Config.moab
mbzoltan
Property changes on: MOAB/trunk/tools/mcnpmit
   - Makefile.in
   + Makefile
Makefile.in
.deps
.libs
stamp-*
mcnpmit
