[MOAB-dev] hdf5 file read
Jason Kraftcheck kraftche at cae.wisc.edu
Tue Nov 17 10:51:15 CST 2009
Lukasz Kaczmarczyk wrote:
> Hello
> I have problem with reading attached file in moab format. I created file with
> mbImpl->write_file(file, "MOAB" , "PARALLEL=WRITE_PART", &PostProcTrefftzMeshSet,1)
> Couple days ago, before svn update everything works ok. Can someone help me find the problem,
The bug is in MOAB's file reading code.  The file should be fine.  I've
checked in a fix for this bug.  I've also attached the patch.  Thanks for
finding this bug and my apologies for any inconvenience it has caused you.
- jason
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20091117/e51d0e10/attachment.bin>
