[MOAB-dev] r3343 - in MOAB/trunk: . parallel test/h5file test/perf tools tools/dagmc tools/iMesh tools/mbcoupler tools/mcnpmit
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Fri Nov 13 15:00:42 CST 2009
Author: kraftche
Date: 2009-11-13 15:00:42 -0600 (Fri, 13 Nov 2009)
New Revision: 3343
Modified:
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/MBCore.hpp
   MOAB/trunk/MBInterface.hpp
   MOAB/trunk/MBReaderIface.hpp
   MOAB/trunk/MBTest.cpp
   MOAB/trunk/ReadABAQUS.cpp
   MOAB/trunk/ReadABAQUS.hpp
   MOAB/trunk/ReadCGM.cpp
   MOAB/trunk/ReadCGM.hpp
   MOAB/trunk/ReadGmsh.cpp
   MOAB/trunk/ReadGmsh.hpp
   MOAB/trunk/ReadHDF5.cpp
   MOAB/trunk/ReadHDF5.hpp
   MOAB/trunk/ReadIDEAS.cpp
   MOAB/trunk/ReadIDEAS.hpp
   MOAB/trunk/ReadMCNP5.cpp
   MOAB/trunk/ReadMCNP5.hpp
   MOAB/trunk/ReadNASTRAN.cpp
   MOAB/trunk/ReadNASTRAN.hpp
   MOAB/trunk/ReadNCDF.cpp
   MOAB/trunk/ReadNCDF.hpp
   MOAB/trunk/ReadSTL.cpp
   MOAB/trunk/ReadSTL.hpp
   MOAB/trunk/ReadSms.cpp
   MOAB/trunk/ReadSms.hpp
   MOAB/trunk/ReadTetGen.cpp
   MOAB/trunk/ReadTetGen.hpp
   MOAB/trunk/ReadVtk.cpp
   MOAB/trunk/ReadVtk.hpp
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/Tqdcfr.hpp
   MOAB/trunk/cub_file_test.cc
   MOAB/trunk/exodus_test.cc
   MOAB/trunk/gmsh_test.cc
   MOAB/trunk/kd_tree_test.cpp
   MOAB/trunk/nastran_test.cc
   MOAB/trunk/parallel/ReadParallel.cpp
   MOAB/trunk/parallel/ReadParallel.hpp
   MOAB/trunk/parallel/mbparallelcomm_test.cpp
   MOAB/trunk/parallel/parallel_hdf5_test.cc
   MOAB/trunk/parallel/parallel_unit_tests.cpp
   MOAB/trunk/parallel/pcomm_serial.cpp
   MOAB/trunk/parallel/uber_parallel_test.cpp
   MOAB/trunk/stl_test.cc
   MOAB/trunk/test/h5file/h5partial.cpp
   MOAB/trunk/test/h5file/h5sets_test.cpp
   MOAB/trunk/test/perf/adj_time.cpp
   MOAB/trunk/test/perf/point_in_elem.cpp
   MOAB/trunk/tools/convert.cpp
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/cub2h5m.cc
   MOAB/trunk/tools/dagmc/main.cc
   MOAB/trunk/tools/dagmc/quads_to_tris_driver.cpp
   MOAB/trunk/tools/dagmc/test_geom.cc
   MOAB/trunk/tools/depth.cpp
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
   MOAB/trunk/tools/mcnpmit/main.cpp
Log:
MBInterface API and behavior change.  Previously, MOAB would create a new
entity set for each call to MBInterface::load_file, containing all entities
read from the file.  It no longer does this (ever.)  Rather than passing
back the handle for the (no longer created) file set from
MBInterface::load_file, MBInterface::load_file is now passed a
'const MBEntityHandle*', which may be NULL.  If it is not NULL, then
it is assumed that the *caller* *allocated* a set, and the entities
read from the file will be added to the passed set.
Readers are no longer responsible for adding entities to the file set,
if there is one.  This was the case prior to this commit.  Clean up
the remaining places where readers add entities to the passed set anyway.
Update all readers such that file set is optional (even though readers
don't put entities in the set, some still attach meta-data to the set.)
Change ReadNASTRAN to use RangeMap rather than offsets with optional
lookup by tag value.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/MBCore.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -363,13 +363,12 @@
                                 const int* block_id_list,
                                 const int num_blocks )
-  MBEntityHandle file_set;
   const char* name = block_id_list ? MATERIAL_SET_TAG_NAME : 0;
-  return load_file( file_name, file_set, 0, name, block_id_list, num_blocks );
+  return load_file( file_name, 0, 0, name, block_id_list, num_blocks );
 MBErrorCode MBCore::load_file( const char* file_name,
-                               MBEntityHandle& file_set,
+                               const MBEntityHandle* file_set,
                                const char* options,
                                const char* set_tag_name,
                                const int* set_tag_vals,
@@ -424,7 +423,7 @@
 MBErrorCode MBCore::serial_load_file( const char* file_name,
                                       const FileOptions& opts,
                                       const MBReaderIface::IDTag* subsets,
                                       int num_sets,
@@ -441,10 +440,6 @@
   rval = get_entities_by_handle( 0, initial_ents );
   if (MB_SUCCESS != rval)
     return rval;
-  rval = create_meshset( MESHSET_SET, file_set );
-  if (MB_SUCCESS != rval)
-    return rval;
     // otherwise try using the file extension to select a reader
   MBReaderIface* reader = set->get_file_extension_reader( file_name );
@@ -475,11 +470,9 @@
   new_ents = subtract( new_ents, initial_ents );
   if (MB_SUCCESS != rval) {
     delete_entities( new_ents );
-    file_set = 0;
-  else {
-    new_ents.erase( file_set );
-    rval = add_entities( file_set, new_ents );
+  else if (file_set) {
+    rval = add_entities( *file_set, new_ents );
   return rval;
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/MBCore.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -96,7 +96,7 @@
   /**Load or import a file. */
   virtual MBErrorCode load_file( const char* file_name,
+                                 const MBEntityHandle* file_set = 0,
                                  const char* options = 0,
                                  const char* set_tag_name = 0,
                                  const int* set_tag_values = 0,
@@ -104,7 +104,7 @@
   MBErrorCode serial_load_file( const char* file_name,
                          const MBReaderIface::IDTag* subset_list = 0,
                          int subset_list_length = 0,
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/MBInterface.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -214,7 +214,7 @@
    *\param num_set_tag_values The length of set_tag_values.
Modified: MOAB/trunk/MBReaderIface.hpp
--- MOAB/trunk/MBReaderIface.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/MBReaderIface.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -49,11 +49,10 @@
      * Method all readers must provide to import a mesh.
      *\param file_name      The file to read.
-     *\param file_set       The entity set to which to add all entities read
-     *                      from the file.  If the reader returns anything
-     *                      other than MB_SUCCESS, it is the responsibility
-     *                      of the caller to delete this set and any contained
-     *                      entities that were read.
+     *\param file_set       Optional pointer to entity set representing
+     *                      file.  If this is not NULL, reader may optionally
+     *                      tag the pointed-to set with format-specific
+     *                      meta-data.
      *\param subset_list    An array of tag name and value sets specifying
      *                      the subset of the file to read.  If multiple
      *                      tags are specified, the sets that match all
@@ -64,7 +63,7 @@
      *\author Jason Kraftcheck
-                                   MBEntityHandle file_set,
                                    const IDTag* subset_list = 0,
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/MBTest.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -6794,18 +6794,17 @@
 const char* argv0 = 0;
 MBErrorCode mb_read_fail_test(MBInterface* mb)
-  MBEntityHandle set;
   MBErrorCode rval;
     // try reading a non-existant file
-  rval = mb->load_file( tmpnam(0), set );
+  rval = mb->load_file( tmpnam(0) );
   if (MB_FILE_DOES_NOT_EXIST != rval)
     return MB_FAILURE;
     // try reading an invalid file
   if (!argv0)  // not set by main, oops!
     return MB_FAILURE;
-  rval = mb->load_file( argv0, set );
+  rval = mb->load_file( argv0 );
   if (MB_SUCCESS == rval)
     return MB_FAILURE;
Modified: MOAB/trunk/ReadABAQUS.cpp
--- MOAB/trunk/ReadABAQUS.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadABAQUS.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -132,7 +132,7 @@
 MBErrorCode ReadABAQUS::load_file(const char *abaqus_file_name,
+				  const MBEntityHandle* file_set_ptr,
 				  const MBReaderIface::IDTag* subset_list,
 				  int subset_list_length,
@@ -148,6 +148,11 @@
   bool in_unsupported = false;
+  MBEntityHandle file_set;
+  status = mdbImpl->create_meshset( MESHSET_SET, file_set );
+  if (MB_SUCCESS != status)
+    return status;
   next_line_type = get_next_line_type();
   while (next_line_type != abq_eof)
@@ -254,8 +259,11 @@
-  return MB_SUCCESS;
+  if (file_set_ptr) {
+    status = mdbImpl->unite_meshset( *file_set_ptr, file_set );
+    MB_RETURN_IF_FAIL;
+  return mdbImpl->delete_entities( &file_set, 1 );
Modified: MOAB/trunk/ReadABAQUS.hpp
--- MOAB/trunk/ReadABAQUS.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadABAQUS.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -162,7 +162,7 @@
   //! load an ABAQUS file
   MBErrorCode load_file( const char *exodus_file_name,
Modified: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadCGM.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -112,7 +112,7 @@
 // copy geometry into mesh database
 MBErrorCode ReadCGM::load_file(const char *cgm_file_name,
@@ -146,8 +146,10 @@
     act_att = false;
   // tag the file_set with the faceting_tol
-  rval = mdbImpl->tag_set_data( faceting_tol_tag, &file_set, 1, &faceting_tol );
-  if(MB_SUCCESS != rval) return rval;
+  if (file_set) {
+    rval = mdbImpl->tag_set_data( faceting_tol_tag, file_set, 1, &faceting_tol );
+    if(MB_SUCCESS != rval) return rval;
   // CGM data
   std::map<RefEntity*,MBEntityHandle> entmap[5]; // one for each dim, and one for groups
@@ -201,9 +203,6 @@
       rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
         return rval;
-      rval = mdbImpl->add_entities( file_set, &handle, 1 );
       entmap[dim][ent] = handle;
@@ -298,9 +297,6 @@
     rval = mdbImpl->create_meshset( MESHSET_SET, h );
       return rval;
-    rval = mdbImpl->add_entities( file_set, &h, 1 );
     char namebuf[NAME_TAG_SIZE];
     memset( namebuf, '\0', NAME_TAG_SIZE );
Modified: MOAB/trunk/ReadCGM.hpp
--- MOAB/trunk/ReadCGM.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadCGM.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -56,7 +56,7 @@
     //  * MAX_FACET_EDGE_LENGTH=<real> (default: 0.0)
     //  * CGM_ATTRIBS=<yes|no>         (default: no)
   MBErrorCode load_file( const char *cgm_file_name,
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadGmsh.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -70,7 +70,7 @@
 MBErrorCode ReadGmsh::load_file( const char* filename,
-                                 MBEntityHandle,
+                                 const MBEntityHandle*,
                                  const FileOptions& ,
Modified: MOAB/trunk/ReadGmsh.hpp
--- MOAB/trunk/ReadGmsh.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadGmsh.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -40,7 +40,7 @@
   static MBReaderIface* factory( MBInterface* );
   MBErrorCode load_file( const char *file_name,
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadHDF5.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -317,7 +317,7 @@
 MBErrorCode ReadHDF5::load_file( const char* filename,
@@ -337,8 +337,8 @@
   if (MB_SUCCESS == rval && file_id_tag)
     rval = store_file_ids( *file_id_tag );
-  if (MB_SUCCESS == rval)
-    rval = read_qa( file_set );
+  if (MB_SUCCESS == rval && 0 != file_set)
+    rval = read_qa( *file_set );
   MBErrorCode rval2 = clean_up_read( opts );
   if (rval == MB_SUCCESS && rval2 != MB_SUCCESS)
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadHDF5.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -51,7 +51,7 @@
    * \param export_set_count Length of <code>export_sets</code> array.
   MBErrorCode load_file( const char* filename,
Modified: MOAB/trunk/ReadIDEAS.cpp
--- MOAB/trunk/ReadIDEAS.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadIDEAS.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -35,7 +35,7 @@
 MBErrorCode ReadIDEAS::load_file(const char* fname,
-                                 MBEntityHandle meshset,
+                                 const MBEntityHandle* ,
                                  const FileOptions& options,
Modified: MOAB/trunk/ReadIDEAS.hpp
--- MOAB/trunk/ReadIDEAS.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadIDEAS.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -21,7 +21,7 @@
   MBErrorCode load_file( const char* fname,
+			 const MBEntityHandle* meshset,
 			 const FileOptions&,
Modified: MOAB/trunk/ReadMCNP5.cpp
--- MOAB/trunk/ReadMCNP5.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadMCNP5.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -68,12 +68,12 @@
 // load the file as called by the MBInterface function
-MBErrorCode ReadMCNP5::load_file(const char        *filename,
-                                 MBEntityHandle    input_meshset,
-                                 const FileOptions &options,
-                                 const MBReaderIface::IDTag* subset_list,
-                                 int               subset_list_length,
-                                 const MBTag*      file_id_tag) {
+MBErrorCode ReadMCNP5::load_file(const char                 *filename,
+                                 const MBEntityHandle       *input_meshset,
+                                 const FileOptions          &options,
+                                 const MBReaderIface::IDTag *subset_list,
+                                 int                         subset_list_length,
+                                 const MBTag                *file_id_tag) {
   // at this time there is no support for reading a subset of the file
   if (subset_list && subset_list_length) {
     readMeshIface->report_error( "Reading subset of files not supported for meshtal." );
@@ -132,10 +132,10 @@
 // This actually reads the file. It creates the mesh elements unless
 // the file is being averaged with a pre-existing mesh.
-MBErrorCode ReadMCNP5::load_one_file(const char        *fname,
-                                     const bool        average ) {
+MBErrorCode ReadMCNP5::load_one_file(const char           *fname,
+                                     const bool           average ) {
   bool debug = false;
   if (debug) std::cout << "begin ReadMCNP5::load_one_file" << std::endl;
@@ -192,8 +192,8 @@
   // Everything stored in the file being read will be in the input_meshset.
   // if this is being saved in MOAB, set header tags
-  if (!average) {
-    result = set_header_tags( input_meshset,
+  if (!average && 0 != input_meshset) {
+    result = set_header_tags( *input_meshset,
                               date_and_time,
                               title,
                               nps,
Modified: MOAB/trunk/ReadMCNP5.hpp
--- MOAB/trunk/ReadMCNP5.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadMCNP5.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -54,7 +54,7 @@
@@ -99,10 +99,10 @@
   int nodeId, elemId;
   // reads the meshtal file
-  MBErrorCode load_one_file( const char        *fname,
-                             const bool        average );
+  MBErrorCode load_one_file( const char           *fname,
+                             const bool           average );
   MBErrorCode create_tags( MBTag &date_and_time_tag,
                            MBTag &title_tag,
Modified: MOAB/trunk/ReadNASTRAN.cpp
--- MOAB/trunk/ReadNASTRAN.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadNASTRAN.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -38,7 +38,7 @@
 // constructor
 ReadNASTRAN::ReadNASTRAN(MBInterface* impl)
-  : MBI(impl), fileIDTag(0) {
+  : MBI(impl) {
     assert(NULL != impl);
     void *ptr = 0;
     MBI->query_interface("MBReadUtilIface", &ptr);
@@ -66,7 +66,7 @@
 MBErrorCode ReadNASTRAN::load_file(const char                  *filename,
+                                   const MBEntityHandle        *,
@@ -76,23 +76,14 @@
     readMeshIface->report_error( "Reading subset of files not supported for NASTRAN." );
     return MB_UNSUPPORTED_OPERATION;
-  nodeId = elemId = 0;
-  fileIDTag = file_id_tag;
+  nodeIdMap.clear();
+  elemIdMap.clear();
   bool debug = false;
   if (debug) std::cout << "begin ReadNASTRAN::load_file" << std::endl;
   MBErrorCode result;
-  // create tags
-  MBTag id_tag, material_tag;
-  result = MBI->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
-                           MB_TYPE_INTEGER, id_tag, 0);
-  if(MB_SUCCESS!=result && MB_ALREADY_ALLOCATED!=result) return result;
-  result = MBI->tag_create(MATERIAL_SET_TAG_NAME, sizeof(int), MB_TAG_DENSE,
-                           MB_TYPE_INTEGER, material_tag, 0);
   // Count the entities of each type in the file. This is used to allocate the node array.
   int entity_count[MBMAXTYPE];
   for(int i=0; i<MBMAXTYPE; i++) entity_count[i] = 0;
@@ -131,13 +122,10 @@
       std::cout << "entity_count[" << i << "]=" << entity_count[i] << std::endl;
+  // Keep list of material sets
+  std::vector<MBRange> materials;
-  /* If we assume that the node ids are continuous, then the node ids can be
-     easily mapped to vertex handles. If they are not continuous then the node
-     ids themselves will need to be used to create connectivity. It is very
-     slow to find each node by its id because this is a tag call. */
-  bool node_ids_are_continuous = true;
   // Now that the number of vertices is known, create the vertices.
   MBEntityHandle start_vert = NULL;
   std::vector<double*> coord_arrays(3);
@@ -145,7 +133,7 @@
 					   start_vert, coord_arrays );
   if(MB_SUCCESS != result) return result;
   if(0 == start_vert) return MB_FAILURE; // check for NULL
-  int vert_index = 0;
+  int id, vert_index = 0;
   if(debug) std::cout << "allocated coord arrays" << std::endl;
   // Read the file again to create the entities.
@@ -169,17 +157,29 @@
     // Create the entity.
     if(MBVERTEX == type) {
-      result = read_node(tokens, id_tag, file_set, debug, coord_arrays,
-			 vert_index, start_vert, node_ids_are_continuous );
+      double* coords[3] = { coord_arrays[0] + vert_index,
+                            coord_arrays[1] + vert_index,
+                            coord_arrays[2] + vert_index };
+      result = read_node(tokens, debug, coords, id );
+      if (!nodeIdMap.insert( id, start_vert + vert_index, 1 ).second)
+        return MB_FAILURE; // duplicate IDs!
+      ++vert_index;
     } else {
-      result = read_element(tokens, id_tag, material_tag, type, file_set,
-			    debug, start_vert, node_ids_are_continuous );
+      result = read_element( tokens, materials, type, debug );
+  result = create_materials( materials );
+  if(MB_SUCCESS != result) return result;
+  result = assign_ids( file_id_tag );
   file.close();
   return MB_SUCCESS;
@@ -313,16 +313,12 @@
 /* It has been determined that this line is a vertex. Read the rest of
    the line and create the vertex. */
 MBErrorCode ReadNASTRAN::read_node( const std::vector<std::string> tokens,
-				      MBTag id_tag,
-				      const MBEntityHandle file_set,
-				      const bool debug,
-				      std::vector<double*> coord_arrays,
-				      int &vert_index,
-				      const MBEntityHandle start_vert,
-				      bool &node_ids_are_continuous ) {
+				    const bool debug,
+				    double* coords[3],
+                                    int& id ) {
   // read the node's id (unique)
   MBErrorCode result;
-  int id = atoi(tokens[1].c_str());
+  id = atoi(tokens[1].c_str());
   // read the node's coordinate system number
   // "0" or blank refers to the basic coordinate system.
@@ -334,32 +330,12 @@
   // read the coordinates
-  double coords[3];
   for(unsigned int i=0; i<3; i++) {
-    result = get_real( tokens[i+3], coords[i] );
+    result = get_real( tokens[i+3], *coords[i] );
     if(debug) std::cout << "read_node: coords[" << i << "]=" << coords[i] << std::endl;
-  // create the node
-  MBEntityHandle vert = start_vert+vert_index;
-  for(int i=0; i<3; i++) coord_arrays[i][vert_index] = coords[i];
-  vert_index++;
-  // check to see if the node ids are still continuous
-  if(id != vert_index) {
-    node_ids_are_continuous = false;
-    std::cout << "node ids are not continuous" << std::endl;
-  // tag with the global id from the NASTRAN file
-  result = MBI->tag_set_data( id_tag, &vert, 1, &id );
-  if(MB_SUCCESS != result) return result;
-  // add to the file set
-  result = MBI->add_entities( file_set, &vert, 1 );
   return MB_SUCCESS;
@@ -367,75 +343,114 @@
    line and create the element. Assume that all of the nodes have already
    been created. */
 MBErrorCode ReadNASTRAN::read_element( const std::vector<std::string> tokens,
-				       MBTag id_tag,
-				       MBTag material_tag,
+				       std::vector<MBRange> &materials,
 				       const MBEntityType element_type,
-				       const bool debug,
-				       const bool node_ids_are_continuous ) {
+				       const bool debug ) {
   // read the element's id (unique) and material set
   MBErrorCode result;
   int material = atoi(tokens[2].c_str());
+    // Resize materials list if necessary.  This code is somewhat complicated
+    // so as to avoid copying of MBRanges
+  if (material >= (int)materials.size()) {
+    if ((int)materials.capacity() < material)
+      materials.resize( material+1 );
+    else {
+      std::vector<MBRange> new_mat( material+1 );
+      for (size_t i = 0; i < materials.size(); ++i)
+        new_mat[i].swap( materials[i] );
+      materials.swap( new_mat );
   // the size of the connectivity array depends on the element type
   int n_conn = MBCN::VerticesPerEntity(element_type);
+  MBEntityHandle conn_verts[27];
+  assert(n_conn <= (int)(sizeof(conn_verts)/sizeof(MBEntityHandle)));
   // read the connected node ids from the file
-  int conn[n_conn];
   for(int i=0; i<n_conn; i++) {
-    conn[i] = atoi(tokens[3+i].c_str());
+    int n = atoi(tokens[3+i].c_str());
+    conn_verts[i] = nodeIdMap.find( n );
+    if (!conn_verts[i]) // invalid vertex id
-  /* Get the vertex handles with those node ids. If the nodes do not have
-     continuous ids we need to do a very slow tag search for global ids.
-     The cannonical numbering between NASTRAN and MOAB is the same for
-     tets and prisms. */
-  MBEntityHandle conn_verts[n_conn];
-  for(int i=0; i<n_conn; i++) {
-    if(node_ids_are_continuous) {
-      conn_verts[i] = start_vert + conn[i] -1;
-    } else {
-      void *vert_id_val[] = {&conn[i]};
-      MBRange vert;
-      result = MBI->get_entities_by_type_and_tag( file_set, MBVERTEX, &id_tag,
-						  vert_id_val, 1, vert );
-      if(1 != vert.size()) return MB_FAILURE; // only one vertex should have this global id
-      conn_verts[i] = vert.front();
-    if(debug) std::cout << "conn[" << i << "]=" << conn[i] << std::endl;
   // Create the element and set the global id from the NASTRAN file
   MBEntityHandle element;
   result = MBI->create_element( element_type, conn_verts, n_conn, element );
-  result = MBI->tag_set_data( id_tag, &element, 1, &id );
+  elemIdMap.insert( id, element, 1 );
+  materials[material].insert( element );
+  return MB_SUCCESS;
-  // Create the material set for the element if it does not already exist.
-  void *mat_val[] = {&material};
-  MBRange material_set;
-  result = MBI->get_entities_by_type_and_tag( file_set, MBENTITYSET, &material_tag,
-					      mat_val, 1, material_set );
-  if(0 == material_set.size()) {
-    MBEntityHandle new_material_set;
-    result = MBI->create_meshset( 0, new_material_set );
-    result = MBI->add_entities( file_set, &new_material_set, 1 );
-    result = MBI->tag_set_data( material_tag, &new_material_set, 1, &material );
-    material_set.insert( new_material_set );
-  } else if(1 < material_set.size()) {
-    return MB_MULTIPLE_ENTITIES_FOUND;
+MBErrorCode ReadNASTRAN::create_materials( const std::vector<MBRange>& materials )
+  MBErrorCode result;
+  MBTag material_tag;
+  result = MBI->tag_create(MATERIAL_SET_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+                           MB_TYPE_INTEGER, material_tag, 0);
+  if(MB_SUCCESS!=result && MB_ALREADY_ALLOCATED!=result) return result;
+  for (size_t i = 0; i < materials.size(); ++i) {
+    if (materials[i].empty())
+      continue;
+      // Merge with existing or create new?  Original code effectively
+      // created new by only merging with existing in current file set,
+      // so do the same here. - j.kraftcheck
+    MBEntityHandle handle;
+    result = MBI->create_meshset( MESHSET_SET, handle );
+    if (MB_SUCCESS != result)
+      return result;
+    result = MBI->add_entities( handle, materials[i] );
+      return result;
+    int id = i;
+    result = MBI->tag_set_data( material_tag, &handle, 1, &id );
+      return result;
-  result = MBI->add_entities( material_set.front(), &element, 1 );
+MBErrorCode ReadNASTRAN::assign_ids( const MBTag* file_id_tag )
+  // create tag
+  MBTag id_tag;
+  result = MBI->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+                           MB_TYPE_INTEGER, id_tag, 0);
+  RangeMap<int,MBEntityHandle>::iterator i;
+  std::vector<int> ids;
+  for (int t = 0; t < 2; ++t) {
+    RangeMap<int,MBEntityHandle>& fileIdMap = t ? elemIdMap : nodeIdMap;
+    for (i = fileIdMap.begin(); i != fileIdMap.end(); ++i) {
+      MBRange range( i->value, i->value + i->count - 1 );
+      result = readMeshIface->assign_ids( id_tag, range, i->begin );
+        return result;
+      if (file_id_tag && *file_id_tag != id_tag) {
+        result = readMeshIface->assign_ids( *file_id_tag, range, i->begin );
+          return result;
   return MB_SUCCESS;
Modified: MOAB/trunk/ReadNASTRAN.hpp
--- MOAB/trunk/ReadNASTRAN.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadNASTRAN.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -39,6 +39,7 @@
 #include "MBInterface.hpp"
 #include "MBReaderIface.hpp"
 #include "FileTokenizer.hpp"
+#include "RangeMap.hpp"
 class MBReadUtilIface;
@@ -50,7 +51,7 @@
   MBErrorCode load_file( const char                  *filename,
+                         const MBEntityHandle        *file_set,
                          const MBReaderIface::IDTag  *subset_list = 0,
@@ -65,7 +66,7 @@
 			       const char         *tag_name,
 			       const FileOptions  &opts,
 			       std::vector<int>   &tag_values_out,
-			       const IDTag        *subset_list,
+                               const IDTag        *subset_list,
 		      	       int                subset_list_length );
 protected:
@@ -76,10 +77,9 @@
   // MOAB Interface
   MBInterface* MBI;
+  RangeMap<int, MBEntityHandle> nodeIdMap, elemIdMap;
-  const MBTag* fileIDTag;
-  int nodeId, elemId;
   enum line_format { SMALL_FIELD,
                      LARGE_FIELD,
                      FREE_FIELD };
@@ -96,21 +96,17 @@
   MBErrorCode get_real( const std::string, double &real );
   MBErrorCode read_node(const std::vector<std::string> tokens,
-                        MBTag                id_tag,
                         const bool           debug,
-                        int                  &vert_index,
-                        bool                 &node_ids_are_continuous );
+                        double*              coord_arrays[3],
+                        int                  &node_id);
   MBErrorCode read_element(const std::vector<std::string> tokens,
-                           MBTag                id_tag,
-                           const MBEntityType   element_type,
-                           const bool           debug,
-                           const bool           node_ids_are_continuous );
+                           const MBEntityType             element_type,
+                           const bool                     debug );
+  MBErrorCode create_materials( const std::vector<MBRange> &materials );
+  MBErrorCode assign_ids( const MBTag* file_id_tag );
 #endif
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadNCDF.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -250,7 +250,7 @@
 MBErrorCode ReadNCDF::load_file(const char *exodus_file_name,
@@ -329,8 +329,10 @@
   if (MB_FAILURE == status) return status;
     // 8. Read qa records
-  status = read_qa_records(file_set);
-  if (MB_FAILURE == status) return status;
+  if (file_set) {
+    status = read_qa_records(*file_set);
+    if (MB_FAILURE == status) return status;
     // what about properties???
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadNCDF.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -70,7 +70,7 @@
     //! load an ExoII file
Modified: MOAB/trunk/ReadSTL.cpp
--- MOAB/trunk/ReadSTL.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadSTL.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -76,7 +76,7 @@
 // pure-virtual function implemented in subclasses to read
 // the data from the file.
 MBErrorCode ReadSTL::load_file( const char* filename,
@@ -145,18 +145,6 @@
                                            handle, coord_arrays );
     return result;
-    // Add vertices to entity set
-  MBRange range(handle, handle+vertex_map.size()-1);
-  result = mdbImpl->add_entities(file_set, range);
-  if (MB_SUCCESS != result)
-    return result;
-  if (file_id_tag) {
-    result = readMeshIface->assign_ids( *file_id_tag, range );
-      return result;
     // Copy vertex coordinates into entity sequence coordinate arrays
     // and copy handle into vertex_map.
@@ -181,19 +169,7 @@
                                              connectivity );
     return result;
-    // Add triangles to entity set
-  MBRange range2(handle, handle+triangles.size()-1);
-  result = mdbImpl->add_entities(file_set, range2);
-    return result;
-    result = readMeshIface->assign_ids( *file_id_tag, range2 );
-      return result;
     // Use vertex_map to reconver triangle connectivity from
     // vertex coordinates.
   MBEntityHandle *conn_sav = connectivity;
Modified: MOAB/trunk/ReadSTL.hpp
--- MOAB/trunk/ReadSTL.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadSTL.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -72,7 +72,7 @@
     //! Generic file loading code for both binary and ASCII readers.
     //! Calls reader-specific read_triangles function to do actual I/O.
Modified: MOAB/trunk/ReadSms.cpp
--- MOAB/trunk/ReadSms.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadSms.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -73,7 +73,7 @@
 MBErrorCode ReadSms::load_file( const char* filename,
-                                MBEntityHandle ,
Modified: MOAB/trunk/ReadSms.hpp
--- MOAB/trunk/ReadSms.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadSms.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -18,7 +18,7 @@
Modified: MOAB/trunk/ReadTetGen.cpp
--- MOAB/trunk/ReadTetGen.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadTetGen.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -74,7 +74,7 @@
 MBErrorCode ReadTetGen::load_file( const char* file_name_c,
@@ -138,23 +138,12 @@
   MBRange tets, tris, edges;
   std::vector<MBEntityHandle> nodes;
   rval = read_node_file( node_file, &attr_tags[0][0], &attr_idx[0][0], attr_tags[0].size(), nodes );
-    rval = mbIface->add_entities( file_set, &nodes[0], nodes.size() );
-  if (MB_SUCCESS == rval && ele_file.is_open()) {
+  if (MB_SUCCESS == rval && ele_file.is_open())
     rval = read_elem_file( MBTET, ele_file, nodes, tets );
-      rval = mbIface->add_entities( file_set, tets );
-  if (MB_SUCCESS == rval && face_file.is_open()) {
+  if (MB_SUCCESS == rval && face_file.is_open())
     rval = read_elem_file( MBTRI, face_file, nodes, tris );
-      rval = mbIface->add_entities( file_set, tris );
-  if (MB_SUCCESS == rval && edge_file.is_open()) {
+  if (MB_SUCCESS == rval && edge_file.is_open())
     rval = read_elem_file( MBEDGE, edge_file, nodes, edges );
-      rval = mbIface->add_entities( file_set, edges );
   if (file_id_tag && MB_SUCCESS == rval)
     rval = readTool->assign_ids( *file_id_tag, &nodes[0], nodes.size() );
Modified: MOAB/trunk/ReadTetGen.hpp
--- MOAB/trunk/ReadTetGen.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadTetGen.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -37,7 +37,7 @@
     //! load a file
                          const FileOptions&,
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadVtk.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -179,7 +179,7 @@
 MBErrorCode ReadVtk::load_file( const char *filename,
-                                MBEntityHandle ,
Modified: MOAB/trunk/ReadVtk.hpp
--- MOAB/trunk/ReadVtk.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/ReadVtk.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -33,7 +33,7 @@
     //! load a file
                          const FileOptions&,
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/Tqdcfr.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -202,7 +202,7 @@
 MBErrorCode Tqdcfr::load_file(const char *file_name,
@@ -2590,10 +2590,9 @@
   MBCore *my_impl = new MBCore();
   Tqdcfr *my_tqd = new Tqdcfr(my_impl);
   FileOptions opts(NULL);
-  MBErrorCode result = my_tqd->load_file(file, file_set, opts, 0, 0, 0);
+  MBErrorCode result = my_tqd->load_file(file, 0, opts, 0, 0, 0);
   if (MB_SUCCESS == result)
     std::cout << "Success." << std::endl;
@@ -2612,7 +2611,7 @@
   my_impl = new MBCore;
-  result = my_tqd->load_file(file, file_set, opts, 0, 0, 0);
+  result = my_tqd->load_file(file, 0, opts, 0, 0, 0);
@@ -2640,7 +2639,7 @@
   std::string options = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE";
   std::cout << "Testing parallel..." << std::endl;
-  result = my_impl->load_file(file, file_set,
+  result = my_impl->load_file(file, 0,
                               options.c_str());
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/Tqdcfr.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -293,7 +293,7 @@
     // read cub file
   MBErrorCode load_file(const char *file_name,
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/cub_file_test.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -171,13 +171,10 @@
 void read_file( MBInterface& moab, const char* input_file )
   MBErrorCode rval;
   Tqdcfr reader( &moab );
   FileOptions opts("");
-  rval = moab.create_meshset( MESHSET_SET, set );
+  rval = reader.load_file( input_file, 0, opts, 0, 0, 0 );
   CHECK_ERR(rval);
-  rval = reader.load_file( input_file, set, opts, 0, 0, 0 );
-  CHECK_ERR(rval);
 void test_vertices()
Modified: MOAB/trunk/exodus_test.cc
--- MOAB/trunk/exodus_test.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/exodus_test.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -181,13 +181,10 @@
   MBErrorCode rval;
   ReadNCDF reader( &moab );
   CHECK_ERR(rval);
-  CHECK_ERR(rval);
 void write_and_read( MBInterface& write_mb,
@@ -196,7 +193,6 @@
   const char* tmp_file = "exodus_test_tmp.g";
   MBErrorCode rval;
   ReadNCDF reader( &read_mb );
   WriteNCDF writer( &write_mb );
@@ -211,11 +207,7 @@
     remove(tmp_file);
   CHECK_ERR(rval);
-  rval = read_mb.create_meshset( MESHSET_SET, set );
-    remove(tmp_file);
-  CHECK_ERR(rval);
-  rval = reader.load_file( tmp_file, set, opts, 0, 0, 0 );
+  rval = reader.load_file( tmp_file, 0, opts, 0, 0, 0 );
   remove( tmp_file );
   CHECK_ERR(rval);
Modified: MOAB/trunk/gmsh_test.cc
--- MOAB/trunk/gmsh_test.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/gmsh_test.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -40,11 +40,9 @@
   MBErrorCode rval;
-  moab.create_meshset( MESHSET_SET, set );
   ReadGmsh reader( &moab );
   CHECK_ERR(rval);
Modified: MOAB/trunk/kd_tree_test.cpp
--- MOAB/trunk/kd_tree_test.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/kd_tree_test.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -116,23 +116,14 @@
   // write to file
-#if MB_VERSION_MAJOR <= 3
-  err = moab.write_mesh( "tree.h5m" );
-#else
   err = moab.write_file( "tree.h5m" );
-#endif
   assert(!err);
   // clear everything
   moab.delete_mesh();
   // read tree from file
-  err = moab.load_mesh( "tree.h5m" );
-#else
-  MBEntityHandle file;
-  err = moab.load_file( "tree.h5m", file );
-#endif
+  err = moab.load_file( "tree.h5m" );
   assert(!err);
   // get tag handle by name, because the handle may have changed
@@ -183,23 +174,14 @@
   // write to file
-#else
-#endif
   assert(!err);
   // clear everything
   moab.delete_mesh();
-#else
-#endif
   assert(!err);
   // check that tag doesn't exist
Modified: MOAB/trunk/nastran_test.cc
--- MOAB/trunk/nastran_test.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/nastran_test.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -40,11 +40,9 @@
   MBErrorCode rval;
   ReadNASTRAN reader( &moab );
   CHECK_ERR(rval);
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/ReadParallel.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -54,7 +54,7 @@
 MBErrorCode ReadParallel::load_file(const char **file_names,
                                     const int num_files,
@@ -222,7 +222,7 @@
                                     int parallel_mode,
                                     std::string &partition_tag_name,
                                     std::vector<int> &partition_tag_vals,
@@ -262,8 +262,10 @@
   act_times[0] = MPI_Wtime();
     // make a new set for the parallel read
   result = mbImpl->create_meshset(MESHSET_SET, file_set);
   if (MB_SUCCESS != result) return result;
   bool i_read = false;
   MBTag id_tag = 0;
   bool use_id_tag = false;
@@ -281,9 +283,11 @@
             if (debug)
               std::cout << "Reading file " << file_names[j] << std::endl;
-            MBEntityHandle new_file_set = 0;
+            MBEntityHandle new_file_set;
+            result = mbImpl->create_meshset(MESHSET_SET, new_file_set);
+            if (MB_SUCCESS != result) return result;
             tmp_result = impl->serial_load_file( file_names[j],
-                                                 new_file_set,
+                                                 &new_file_set,
                                                  opts,
                                                  subset_list,
                                                  subset_list_length,
@@ -356,7 +360,7 @@
           std::vector<MBReaderIface::IDTag> subset( subset_list,
                                                     subset_list + subset_list_length );
           subset.push_back( parts );
-          tmp_result = impl->serial_load_file( *file_names, file_set, opts,
+          tmp_result = impl->serial_load_file( *file_names, &file_set, opts,
                                                &subset[0], subset.size(), file_id_tag );
           if (MB_SUCCESS == tmp_result)
@@ -490,6 +494,13 @@
     std::cout << ")" << std::endl;
+  if (MB_SUCCESS == result && file_set_ptr) {
+    MBRange all_ents;
+    result = mbImpl->get_entities_by_handle(file_set, all_ents);
+    if (MB_SUCCESS == result)
+      result = mbImpl->add_entities(*file_set_ptr, all_ents);
   return result;
Modified: MOAB/trunk/parallel/ReadParallel.hpp
--- MOAB/trunk/parallel/ReadParallel.hpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/ReadParallel.hpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -18,7 +18,7 @@
     //! load a file
@@ -27,7 +27,7 @@
     //! load multiple files
   MBErrorCode load_file(const char **file_names,
@@ -35,7 +35,7 @@
                         int parallel_mode,
@@ -101,7 +101,7 @@
 inline MBErrorCode ReadParallel::load_file(const char *file_name,
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -337,7 +337,6 @@
   if (print_parallel)
     options << ";PRINT_PARALLEL";
-  std::vector<MBEntityHandle> filesets(filenames.size());
   std::vector<MBParallelComm*> pcs(filenames.size());
   std::vector<ReadParallel*> rps(filenames.size());
   MBErrorCode result;
@@ -347,7 +346,7 @@
       pcs[i] = new MBParallelComm(mbImpl);
       rps[i] = new ReadParallel(mbImpl, pcs[i]);
-      result = rps[i]->load_file(filenames[i].c_str(), filesets[i],
+      result = rps[i]->load_file(filenames[i].c_str(), 0,
                                  FileOptions(options.str().c_str()), 0, 0, 0);
         PRINT_LAST_ERROR;
@@ -368,7 +367,7 @@
   else {
-    result = mbImpl->load_file(filenames[0].c_str(), filesets[0],
+    result = mbImpl->load_file(filenames[0].c_str(), 0,
                                options.str().c_str());
     pcs[0] = MBParallelComm::get_pcomm(mbImpl, 0);
     assert(pcs[0]);
@@ -383,7 +382,10 @@
     // read the mesh
-  MBErrorCode result = mbImpl->load_file(filename, file_set, NULL);
+  MBErrorCode result = mbImpl->create_meshset( MESHSET_SET, file_set );
+  RRA("create_meshset failed.");
+  result = mbImpl->load_file(filename, &file_set, NULL);
   if (MB_SUCCESS != result) {
     std::cerr << "Reading file failed; message:" << std::endl;
     PRINT_LAST_ERROR;
Modified: MOAB/trunk/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/parallel/parallel_hdf5_test.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/parallel_hdf5_test.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -262,9 +262,8 @@
 void load_and_partition( MBInterface& moab, const char* filename, bool print )
   MBErrorCode rval;
-  rval = moab.load_file( filename, set,
+  rval = moab.load_file( filename, 0,
                          "PARALLEL=READ_DELETE;"
                          "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
                          "PARTITION_DISTRIBUTE;"
@@ -279,7 +278,6 @@
 void save_and_load_on_root( MBInterface& moab, const char* tmp_filename )
   MBErrorCode rval;
   int procnum;
   MPI_Comm_rank( MPI_COMM_WORLD, &procnum );
@@ -296,7 +294,7 @@
   moab.delete_mesh();
   if (procnum == 0) {
-    rval = moab.load_file( tmp_filename, set );
+    rval = moab.load_file( tmp_filename );
     if (!KeepTmpFiles)
       remove( tmp_filename );
     CHECK_ERR(rval);
@@ -438,8 +436,7 @@
   if (rank == 0) {
     MBCore moab2;
-    rval = moab2.load_file( InputFile, set );
+    rval = moab2.load_file( InputFile );
     CHECK_ERR(rval);
     check_identical_mesh( moab, moab2 );
@@ -484,8 +481,7 @@
   MBCore moab2_instance;
   MBInterface& moab2 = moab2_instance;
   CHECK_ERR(rval);
   MBTag mattag1, mattag2;
@@ -746,7 +742,6 @@
   MBCore moab;
   MBInterface &mb = moab;
   MBErrorCode rval;
     // if root processor, create hdf5 file for use in testing
   if (0 == rank)
@@ -757,7 +752,7 @@
   const char opt1[] = "PARALLEL=READ_PART;PARTITION=PARTITION";
   const char opt2[] = "PARALLEL=READ_PART;PARTITION=PARTITION;PARTITION_BY_RANK";
   const char* opt = numproc == 1 ? 0 : by_rank ? opt2 : opt1;
-  rval = mb.load_file( file_name, file_set, opt );
+  rval = mb.load_file( file_name, 0, opt );
   MPI_Barrier(MPI_COMM_WORLD); // make sure all procs complete before removing file
   if (0 == rank && !KeepTmpFiles) remove( file_name );
   CHECK_ERR(rval);
@@ -809,7 +804,6 @@
   MPI_Comm_size( MPI_COMM_WORLD, &numproc );
   MPI_Comm_rank( MPI_COMM_WORLD, &rank    );
   MBErrorCode rval;
   if (0 == rank)
@@ -827,7 +821,7 @@
   tmp_t    = clock();
   const char opt[] = "PARALLEL=READ_PART;PARTITION=PARTITION;PARTITION_BY_RANK";
   CHECK_ERR(rval);
   times[0] = MPI_Wtime() - times[0];
   times[1] = double(clock() - tmp_t) / CLOCKS_PER_SEC;
@@ -839,7 +833,7 @@
   times[2] = MPI_Wtime();
   tmp_t    = clock();
   const char opt2[] = "PARALLEL=READ_DELETE;PARTITION=PARTITION;PARTITION_BY_RANK";
-  rval = mb2.load_file( file_name, file_set, opt2 );
+  rval = mb2.load_file( file_name, 0, opt2 );
   CHECK_ERR(rval);
   times[2] = MPI_Wtime() - times[2];
   times[3] = double(clock() - tmp_t) / CLOCKS_PER_SEC;
@@ -851,7 +845,7 @@
   times[4] = MPI_Wtime();
   tmp_t    = clock();
   const char opt3[] = "PARALLEL=BCAST_DELETE;PARTITION=PARTITION;PARTITION_BY_RANK";
-  rval = mb3.load_file( file_name, file_set, opt3 );
+  rval = mb3.load_file( file_name, 0, opt3 );
   CHECK_ERR(rval);
   times[4] = MPI_Wtime() - times[4];
   times[5] = double(clock() - tmp_t) / CLOCKS_PER_SEC;
@@ -883,7 +877,6 @@
   MBCore moab;
   MBErrorCode rval;
   if (0 == rank)
@@ -893,7 +886,7 @@
     // do parallel read unless only one processor
   const char* opt = numproc == 1 ? 0 : opt1;
   CHECK_ERR(rval);
@@ -955,7 +948,6 @@
   MBCore moab;
   MBErrorCode rval;
   const int def_val = 0xdeadcad;
   const int global_val = -11;
@@ -967,7 +959,7 @@
   CHECK_ERR(rval);
@@ -1010,7 +1002,6 @@
   MBCore moab;
   MBErrorCode rval;
   if (0 == rank)
@@ -1020,7 +1011,7 @@
   CHECK_ERR(rval);
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -399,10 +399,9 @@
   MBCore mb_instance;
   MBInterface& moab = mb_instance;
   MBErrorCode rval;
   const char* geom_names[] = { "vertex", "curve", "surface", "volume", "unknown" };
@@ -650,7 +649,6 @@
   MBCore mb_instance;
   MBErrorCode rval;
   std::ostringstream file_opts;
   file_opts << "PARALLEL=READ_DELETE;"
@@ -662,7 +660,7 @@
             << bridge_dimension << '.'
             << num_layers;
-  rval = moab.load_file( filename, set, file_opts.str().c_str() );
+  rval = moab.load_file( filename, 0, file_opts.str().c_str() );
   CHKERR(rval);
   MBTag geom_tag, id_tag;
   rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, geom_tag ); CHKERR(rval);
@@ -773,8 +771,7 @@
     // read file in serial
   MBCore moab2;
-  MBEntityHandle set2;
-  rval = moab2.load_file( filename, set2 );
+  rval = moab2.load_file( filename );
   PCHECK(MB_SUCCESS == rval);
     // get the global IDs of teh entities we expect to be ghosted
@@ -842,9 +839,8 @@
   MBCore mb_instance;
   MBErrorCode rval;
@@ -935,9 +931,8 @@
   MBCore mb_instance;
   MBErrorCode rval;
Modified: MOAB/trunk/parallel/pcomm_serial.cpp
--- MOAB/trunk/parallel/pcomm_serial.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/pcomm_serial.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -59,8 +59,7 @@
   for (int i = 0; i < nprocs; i++) {
     ReadParallel rp(moab+i, pc[i]);
-    MBEntityHandle tmp_set = 0;
-    rval = rp.load_file(fnames, 1, tmp_set, ReadParallel::POPT_READ_DELETE,
+    rval = rp.load_file(fnames, 1, 0, ReadParallel::POPT_READ_DELETE,
                         ptag_name,
                         partition_tag_vals, partition_distrib, false, pa_vec,
                         fopts, NULL, 0, NULL, i, false, -1, -1, -1, -1, 0);
Modified: MOAB/trunk/parallel/uber_parallel_test.cpp
--- MOAB/trunk/parallel/uber_parallel_test.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/parallel/uber_parallel_test.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -125,9 +125,8 @@
   MBCore mb_instance;
   MBErrorCode rval;
-  rval = moab.load_file( filename, set, option);
+  rval = moab.load_file( filename, 0, option);
   CHKERR(rval);
   MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
Modified: MOAB/trunk/stl_test.cc
--- MOAB/trunk/stl_test.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/stl_test.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -59,11 +59,9 @@
 MBErrorCode read_file_( MBInterface& moab, const char* input_file, const char* options = "" )
   MBErrorCode rval;
   ReadSTL reader( &moab );
   FileOptions opts(options);
   return rval;
@@ -76,13 +74,11 @@
 void convert_file( const char* input_file, const char* output_file, const char* options )
   MBErrorCode rval;
   MBCore moab;
   FileOptions opts_reader("");
-  rval = reader.load_file( input_file, set, opts_reader, 0, 0, 0 );
+  rval = reader.load_file( input_file, 0, opts_reader, 0, 0, 0 );
   CHECK_ERR(rval);
   WriteSTL writer( &moab );
Modified: MOAB/trunk/test/h5file/h5partial.cpp
--- MOAB/trunk/test/h5file/h5partial.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/test/h5file/h5partial.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -227,7 +227,9 @@
   // now read back in only the empty set
   int id = non_existant ? 8 : 7;
-  rval = mb.load_file( TEST_FILE, file_set, READ_OPTS, ID_TAG_NAME, &id, 1 );
+  rval = mb.create_meshset( MESHSET_SET, file_set );
+  CHECK_ERR(rval);
+  rval = mb.load_file( TEST_FILE, &file_set, READ_OPTS, ID_TAG_NAME, &id, 1 );
   if (non_existant) {
     CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval );
     return;
@@ -306,8 +308,10 @@
   values.resize( num_read_sets );
   for (int i = 0; i < num_read_sets; ++i) values[i] = 2*(i+1);
-  rval = mb.load_file( TEST_FILE, file_set, READ_OPTS, ID_TAG_NAME, &values[0], num_read_sets );
   CHECK_ERR(rval);
+  rval = mb.load_file( TEST_FILE, &file_set, READ_OPTS, ID_TAG_NAME, &values[0], num_read_sets );
+  CHECK_ERR(rval);
   int count, expected = 0;
   rval = mb.get_number_entities_by_dimension( 0, 0, count );
@@ -556,8 +560,7 @@
   for (int id = 1; id <= NUM_SETS; ++id) {
     rval = mb.delete_mesh();
     CHECK_ERR(rval);
+    rval = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, &id, 1 );
     CHECK_ERR(rval);
     MBRange verts;
     rval = mb.get_entities_by_type( 0, MBVERTEX, verts );
@@ -576,8 +579,10 @@
   create_mesh( true, false, false, false );
   int ids[2] = { 2, 8 };
-  rval = mb.load_file( TEST_FILE, file_set, READ_OPTS, ID_TAG_NAME, ids, 2 );
   CHECK_ERR(rval);
+  rval = mb.load_file( TEST_FILE, &file_set, READ_OPTS, ID_TAG_NAME, ids, 2 );
+  CHECK_ERR(rval);
   MBRange sets;
   rval = mb.get_entities_by_type( 0, MBENTITYSET, sets );
@@ -641,8 +646,7 @@
   int ids[2] = { 1, 4 };
+  rval = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, ids, 2 );
   CHECK_ERR(rval);
   MBTag tag = check_tag( mb, CENTROID_NAME, MB_TAG_DENSE, MB_TYPE_DOUBLE, 3*sizeof(double) );
@@ -671,8 +675,7 @@
   CHECK_ERR(rval);
   MBTag tag = check_tag( mb, LOGICAL_NAME, MB_TAG_DENSE, MB_TYPE_OPAQUE, 2*sizeof(int) );
@@ -701,8 +704,7 @@
   const char tag_name[] = "VTX_ADJ";
   create_mesh( true, false, false, false, tag_name, var_len );
   int ids[2] = { 7, 10 };
   CHECK_ERR(rval);
   MBTag tag = check_tag( mb, tag_name, MB_TAG_DENSE, MB_TYPE_HANDLE,
@@ -754,8 +756,7 @@
   create_mesh( false, false, true, false );
   int id = 5;
   CHECK_ERR(rval);
   MBRange verts;
@@ -778,8 +779,7 @@
   create_mesh( false, false, false, true );
   int id = 1; // NOTE: this test will only succeed for ID == 1
   CHECK_ERR(rval);
   MBRange verts;
@@ -897,8 +897,7 @@
   CHECK_ERR(rval);
-  rval = mb.load_file( TEST_FILE, file, READ_OPTS, ID_TAG_NAME, ids, 1 );
+  rval = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, ids, 1 );
   CHECK_ERR(rval);
   MBRange rpoly;
@@ -966,8 +965,10 @@
     CHECK_ERR(rval);
+    rval = mb.create_meshset( MESHSET_SET, file );
+    CHECK_ERR(rval);
     int id = i+1;
-    rval = mb.load_file( TEST_FILE, file, READ_OPTS ";SETS=NONE", ID_TAG_NAME, &id, 1 );
+    rval = mb.load_file( TEST_FILE, &file, READ_OPTS ";SETS=NONE", ID_TAG_NAME, &id, 1 );
     CHECK_ERR(rval);
       // check that the total number of sets read is as expected
@@ -1146,8 +1147,11 @@
     CHECK_ERR(rval);
-    rval = mb.load_file( TEST_FILE, file, opt.c_str(), ID_TAG_NAME, test_ids+i, 1 );
     CHECK_ERR(rval);
+    rval = mb.load_file( TEST_FILE, 0, opt.c_str(), ID_TAG_NAME, test_ids+i, 1 );
+    CHECK_ERR(rval);
     rval = mb.tag_get_handle( ID_TAG_NAME, id_tag );
     CHECK_ERR(rval);
@@ -1216,7 +1220,8 @@
   const int read_id = 3;
   rval = mb.delete_mesh(); CHECK_ERR(rval);
-  rval = mb.load_file( TEST_FILE, file, opt.c_str(), ID_TAG_NAME, &read_id, 1 );
+  rval = mb.create_meshset( MESHSET_SET, file ); CHECK_ERR(rval);
+  rval = mb.load_file( TEST_FILE, &file, opt.c_str(), ID_TAG_NAME, &read_id, 1 );
   CHECK_ERR(rval);
     // get any sets that were read it
@@ -1292,10 +1297,9 @@
   MBInterface& mb = instance;
     // read some sets
   const int ids[] = { 1, 5, 9 };
   const int num_sets = sizeof(ids)/sizeof(int);
-  rval = mb.load_file( TEST_FILE, file, READ_OPTS, ID_TAG_NAME, ids, num_sets );
+  rval = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, ids, num_sets );
   CHECK_ERR(rval);
   MBTag id_tag;
@@ -1380,8 +1384,7 @@
     // read mesh
   CHECK_ERR(rval);
     // expect two hexes and two edges
@@ -1466,8 +1469,7 @@
     // read first set back in
   CHECK_ERR(rval);
     // check expected counts
Modified: MOAB/trunk/test/h5file/h5sets_test.cpp
--- MOAB/trunk/test/h5file/h5sets_test.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/test/h5file/h5sets_test.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -18,12 +18,14 @@
   MBErrorCode rval;
   rval = output.write_file( filename );
   CHECK_ERR(rval);
-  rval = input.load_file( filename, file );
+  if (input_set) {
+    rval = input.create_meshset( MESHSET_SET, *input_set );
+    CHECK_ERR(rval);
+  rval = input.load_file( filename, input_set );
   if (!keep_file)
     remove(filename);
   CHECK_ERR(rval);
-  if (input_set)
-    *input_set = file;
 void test_ranged_set_with_holes()
@@ -265,7 +267,7 @@
   // write file and read back in
   rval = mb.write_file( str.str().c_str(), 0, "BUFFER_SIZE=1024" ); CHECK_ERR(rval);
   mb.delete_mesh();
-  rval = mb.load_file( str.str().c_str(), root );
+  rval = mb.load_file( str.str().c_str() );
   if (!keep_file)
     remove( str.str().c_str() );
   CHECK_ERR(rval);
Modified: MOAB/trunk/test/perf/adj_time.cpp
--- MOAB/trunk/test/perf/adj_time.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/test/perf/adj_time.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -19,8 +19,7 @@
   MBInterface& mb = moab;
     // load test file
-  rval = mb.load_file( default_input_file, set );
+  rval = mb.load_file( default_input_file );
     std::cerr << default_input_file <<": failed to load file." << std::endl;
     return 1;
Modified: MOAB/trunk/test/perf/point_in_elem.cpp
--- MOAB/trunk/test/perf/point_in_elem.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/test/perf/point_in_elem.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -116,10 +116,9 @@
   MBCore moab;
   MBErrorCode rval;
   std::string init_msg, msg;
   mb.get_last_error( init_msg );
-  rval = mb.load_file( input_file, file_set );
+  rval = mb.load_file( input_file );
     std::cerr << input_file << " : failed to read file." << std::endl;
     mb.get_last_error( msg );
Modified: MOAB/trunk/tools/convert.cpp
--- MOAB/trunk/tools/convert.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/convert.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -271,8 +271,7 @@
     // Read the input file.
   reset_times();
-  MBEntityHandle read_meshset;
-  result = gMB->load_file( in, read_meshset, read_options.c_str() );
+  result = gMB->load_file( in, 0, read_options.c_str() );
     std::cerr << "Failed to load \"" << in << "\"." << std::endl;
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -887,7 +887,6 @@
 			     const double facet_tolerance)
   MBErrorCode rval;
     // override default value of facetingTolerance with passed value
   if (facet_tolerance > 0 )
@@ -901,7 +900,7 @@
   char options[120] = "CGM_ATTRIBS=yes;FACET_DISTANCE_TOLERANCE=";
   strcat(options,facetTolStr);
-  rval = MBI->load_file(cfile, file_set, options, NULL, 0, 0);
+  rval = MBI->load_file(cfile, 0, options, NULL, 0, 0);
     std::cerr << "Couldn't read file " << cfile << std::endl;
     return rval;
Modified: MOAB/trunk/tools/dagmc/cub2h5m.cc
--- MOAB/trunk/tools/dagmc/cub2h5m.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/dagmc/cub2h5m.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -113,16 +113,15 @@
     ReadNCDF my_ex_reader(my_impl);
     char options[120] = "tdata=coord,";
     strcat(options, time_step);
     strcat(options,",set");
     FileOptions opts(options)  ;
-    MBErrorCode result = my_tqd->load_file(input_name, file_set, opts, NULL, 0, 0);
+    MBErrorCode result = my_tqd->load_file(input_name, 0, opts, NULL, 0, 0);
     //opts = "tdata=coord, 100, sum, temp.exo";
-    result =  my_ex_reader.load_file(update_name, file_set, opts, NULL, 0 , 0);
+    result =  my_ex_reader.load_file(update_name, 0, opts, NULL, 0 , 0);
     // convert the quads to tris
     quads_to_tris( my_impl, file_set );
Modified: MOAB/trunk/tools/dagmc/main.cc
--- MOAB/trunk/tools/dagmc/main.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/dagmc/main.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -129,7 +129,6 @@
     // Intitalize MOAB
   MBCore moab;
   MBInterface* iface = &moab;
   MBErrorCode rval;
 // If CUB file, extract ACIS geometry
@@ -163,12 +162,12 @@
       exit(2);
-    rval = iface->load_file(temp_name,file_set,options,NULL,0,0);
+    rval = iface->load_file(temp_name,0,options,NULL,0,0);
     remove( temp_name );
     free( temp_name );
   else {
-    rval = iface->load_file(input_name,file_set,options,NULL,0,0);
+    rval = iface->load_file(input_name,0,options,NULL,0,0);
     std::cerr << "Failed to read '" << input_name << "' of type '" << file_type << "'" << std::endl;
Modified: MOAB/trunk/tools/dagmc/quads_to_tris_driver.cpp
--- MOAB/trunk/tools/dagmc/quads_to_tris_driver.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/dagmc/quads_to_tris_driver.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -22,11 +22,10 @@
   // load file from input argument
   MBErrorCode result;
   std::string filename = argv[1];
-  MBEntityHandle input_meshset;
-  result = MBI->load_file( filename.c_str(), input_meshset );
+  result = MBI->load_file( filename.c_str() );
     assert( MB_SUCCESS == result );
-  result = quads_to_tris( MBI, input_meshset );
+  result = quads_to_tris( MBI, 0 );
Modified: MOAB/trunk/tools/dagmc/test_geom.cc
--- MOAB/trunk/tools/dagmc/test_geom.cc	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/dagmc/test_geom.cc	2009-11-13 21:00:42 UTC (rev 3343)
@@ -174,8 +174,7 @@
   DagMC& dagmc = *DagMC::instance();
-  rval = dagmc.moab_instance()->load_file( filename, file_set );
+  rval = dagmc.moab_instance()->load_file( filename );
   //rval = dagmc.load_file( filename, 0 );
   remove( filename );
Modified: MOAB/trunk/tools/depth.cpp
--- MOAB/trunk/tools/depth.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/depth.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -77,7 +77,8 @@
   MBErrorCode rval;
-  rval = mb.load_file( input, file );
+  rval = mb.create_meshset( MESHSET_SET, file ); check(rval);
+  rval = mb.load_file( input, &file );
     std::cerr << "Failed to load file: " << input << std::endl;
     return FILE_IO_ERROR;
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -51,7 +51,7 @@
 MBErrorCode create_int_ents(MBInterface *instance,
                             MBRange &from_ents,
-                            MBEntityHandle in_set = 0);
+                            const MBEntityHandle* in_set = 0);
 #define CHECK_SIZE(array, allocated, size, type, retval)  \
   if (0 != allocated && NULL != array && allocated < (size)) {\
@@ -313,9 +313,16 @@
     eatwhitespace(tmp_options);
     std::string opts = ";"; opts += tmp_options;
+    MBRange orig_ents;
+    MBErrorCode result = MBI->get_entities_by_handle( 0, orig_ents );
+    if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
-    MBErrorCode result = MBI->load_file(tmp_filename.c_str(), file_set, opts.c_str());
+    const MBEntityHandle* file_set = 0;
+    if (handle != 0 /*root_set*/) {
+      file_set = reinterpret_cast<const MBEntityHandle*>(&handle);
+    result = MBI->load_file(tmp_filename.c_str(), file_set, opts.c_str());
       std::string msg("iMesh_load:ERROR loading a mesh, with error type: ");
@@ -324,19 +331,12 @@
-    if (handle) {
-      MBRange set_ents;
-      result = MBI->get_entities_by_handle(file_set, set_ents);
-      if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
-      result = MBI->add_entities(ENTITY_HANDLE(handle), set_ents);
       // create interior edges/faces if requested
     if (MBimesh->AdjTable[5] || MBimesh->AdjTable[10]) {
       MBRange set_ents;
-      result = MBI->get_entities_by_handle(file_set, set_ents, true);
+      result = MBI->get_entities_by_handle(0, set_ents);
+      set_ents = subtract( set_ents, orig_ents );
       result = create_int_ents(MBI, set_ents, file_set);
@@ -2956,7 +2956,7 @@
                             MBRange &from_ents,
-                            MBEntityHandle in_set)
+                            const MBEntityHandle* in_set)
   MBiMesh* mbimesh = dynamic_cast<MBiMesh*>(instance);
   assert(mbimesh->AdjTable[10] || mbimesh->AdjTable[5]);
@@ -2970,7 +2970,7 @@
     unsigned int old_size = from_ents.size();
     from_ents.merge(int_ents);
     if (old_size != from_ents.size() && in_set) {
-      result = instance->add_entities(in_set, int_ents);
+      result = instance->add_entities(*in_set, int_ents);
@@ -2983,7 +2983,7 @@
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -88,14 +88,12 @@
     // read in mesh(es)
   std::vector<MBParallelComm *> pcs(filenames.size());
   std::vector<ReadParallel *> rps(filenames.size());
   for (unsigned int i = 0; i < filenames.size(); i++) {
-    result = rps[i]->load_file(filenames[i], filesets[i],
-                               FileOptions(opts.c_str()), 0, 0, 0);
+    result = rps[i]->load_file(filenames[i], 0, FileOptions(opts.c_str()));
     PRINT_LAST_ERROR;
Modified: MOAB/trunk/tools/mcnpmit/main.cpp
--- MOAB/trunk/tools/mcnpmit/main.cpp	2009-11-12 22:25:37 UTC (rev 3342)
+++ MOAB/trunk/tools/mcnpmit/main.cpp	2009-11-13 21:00:42 UTC (rev 3343)
@@ -148,6 +148,8 @@
   else {
+    MBresult = MBI->create_meshset( MESHSET_SET, meshset );
+    assert( MB_SUCCESS == MBresult );
     MBresult = MBI->load_file( CAD_filename.c_str(), meshset );
