[MOAB-dev] r3175 - MOAB/trunk/mhdf/src
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Wed Sep 30 10:02:26 CDT 2009
Author: kraftche
Date: 2009-09-30 10:02:26 -0500 (Wed, 30 Sep 2009)
New Revision: 3175
Modified:
   MOAB/trunk/mhdf/src/file-desc.c
Log:
fix segfault when recovering from error
Modified: MOAB/trunk/mhdf/src/file-desc.c
--- MOAB/trunk/mhdf/src/file-desc.c	2009-09-29 18:31:24 UTC (rev 3174)
+++ MOAB/trunk/mhdf/src/file-desc.c	2009-09-30 15:02:26 UTC (rev 3175)
@@ -170,7 +170,7 @@
 static
-struct mhdf_FileDesc*
+struct mhdf_FileDesc*
 get_tag_desc( mhdf_FileHandle file_handle,
               struct mhdf_FileDesc* result,
               const char* name,
@@ -361,7 +361,7 @@
   struct mhdf_FileDesc* result;
   hid_t table_id;
-  int i, j, k, size, *indices, have;
+  int i, j, k, size, *indices, have, num_tag_names = 0;
   unsigned int ui;
   void* ptr;
   char **elem_handles = 0, **tag_names = 0;
@@ -458,12 +458,13 @@
     /* get tag list */
-  tag_names = mhdf_getTagNames( file_handle, &result->num_tag_desc, status );
+  tag_names = mhdf_getTagNames( file_handle, &num_tag_names, status );
   if (tag_names == NULL) {
     free( elem_handles );
     free( result );
     return NULL;
+  result->num_tag_desc = num_tag_names;
     /* allocate array of tag descriptors */
   size = result->num_tag_desc * sizeof(struct mhdf_TagDesc);
@@ -478,10 +479,10 @@
     /* Initialize each tag descriptor */
   for (i = 0; i < result->num_tag_desc; ++i) {
-    result = get_tag_desc( file_handle, result, tag_names[i], i, file_id_type, status );
+    result = get_tag_desc( file_handle, &result, tag_names[i], i, file_id_type, status );
     if (NULL == result) {
-      free_string_list( tag_names, result->num_tag_desc );
+      free_string_list( tag_names, num_tag_names );
       return NULL;
@@ -492,7 +493,7 @@
   array = mhdf_malloc( size, status );
   if (NULL == array) {
     free( result );
     return NULL;
