[MOAB-dev] MOAB check for *x86* failed.
Nightly Test kraftche at cae.wisc.edu
Fri Jul 10 02:01:13 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/x86/mhdf'
/bin/sh ../libtool --tag=CC   --mode=compile cc -I../../src/mhdf/include  -I. -I../../src/mhdf -I..  -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -g -m32 -MT tags.lo -MD -MP -MF .deps/tags.Tpo -c -o tags.lo `test -f 'src/tags.c' || echo '../../src/mhdf/'`src/tags.c
 cc -I../../src/mhdf/include -I. -I../../src/mhdf -I.. -I/opt/netcdf-3.6.1-32-c2/include -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -g -m32 -MT tags.lo -MD -MP -MF .deps/tags.Tpo -c ../../src/mhdf/src/tags.c -o tags.o
../../src/mhdf/src/tags.c: In function ‘get_attrib_array_length_handle’:
../../src/mhdf/src/tags.c:759: error: ‘perm’ undeclared (first use in this function)
../../src/mhdf/src/tags.c:759: error: (Each undeclared identifier is reported only once
../../src/mhdf/src/tags.c:759: error: for each function it appears in.)
../../src/mhdf/src/tags.c: In function ‘mhdf_getTagInfo’:
../../src/mhdf/src/tags.c:991: error: ‘perm’ undeclared (first use in this function)
make[1]: *** [tags.lo] Error 1
make[1]: Leaving directory `/home/jason/moab/test/x86/mhdf'
make: *** [check-recursive] Error 1
