[mct-ann] Reinitializing the MCT github repository.
Robert Jacob
jacob at mcs.anl.gov
Mon Feb 17 18:57:20 CST 2014
This long-planned re-init of the MCT github repo will happen tomorrow
after 5pm CT. Again, let me know if this poses any difficulties.
Rob
On 8/19/13 6:18 PM, Robert Jacob wrote:
> Hello MCT users,
> If you have a copy of MCT checked out from github or git.mcs.anl.gov,
> this message is for you.
> The 2 git repositories are a little different. github only has the
> minimum code needed to build MCT. git.mcs has the full code including
> examples and is used for development.
> Maintaining both is a bit of a pain and I would like to move all
> development to github.
> This means the current repo at
> https://github.com/MCSclimate/MCT
> Will be deleted and then recreated with a more complete repository under
> the same URL.
> That will, I'm pretty sure, break any current github checkouts pointing
> to that repo if you have changes you want to check back in some day.
> Once this is done, if you checkout (using git or svn) MCT 2.8.1 or later
> from github, you'll get extra directories like "examples" and "testsystem".
> The repository at git.mcs.anl.gov will stay around for a while but will
> become read-only.
> Let me know if this poses any difficulties.
> Regards,
> Rob Jacob
> ______________________________________________
> MCT announcement mailing list.
> To unsubscribe, go to http://lists.mcs.anl.gov/mailman/listinfo/mct-ann
More information about the mct-ann
