[POOL] APL Week 13 Results
David A Stevens
dstevens at CBI.com
Thu Mar 31 07:47:19 CDT 2016
Tuesday will be the last night of this season. I thought it went by very
fast.
We will begin the three week playoff on Tuesday (April 12). As a
reminder, the playoffs are a race to three wins. Once a team has won
three matches, the week is finished. Because there will probably be fewer
matches played during the night, we will only use Table 5 as needed. We
officially have all five tables from 6-10pm, so if a table finishes early
you can play for fun. The brackets will be sent out after the results
next week. I mention the playoffs now, in case teams want to make plans
while you are together on Tuesday.
The results and stats for Week 13 are attached in the pdf files.
Here are the standings after Week 12. I see we have many teams within
fives matches of each other. A lot could happen this week!
Here is the schedule for next week.
There are several people in contention for top spot on the Performance
Ranking list. We will have to see how that finishes.
Dean is back, so let him or I know if you have any questions or comments.
Best regards,
David A Stevens
Civil-Structural Engineer (PSE)
Steel Plate Structures
Tel: +1 815 439 6095
Fax: +1 815 439 6492
dstevens at CBI.com
CB&I
14105 S. Route 59
Plainfield, IL 60544-898
United States
www.CBI.com
This e-mail and any attached files may contain CB&I (or its affiliates) confidential and privileged information. This information is protected by law and/or agreements between CB&I (or its affiliates) and either you, your employer or any contract provider with which you or your employer are associated. If you are not an intended recipient, please contact the sender by reply e-mail and delete all copies of this e-mail; further, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0001.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0005.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0006.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0007.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0008.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0009.gif>
Name: APL Results (Spring 2016) W13.pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0002.obj>
Name: APL Stat Results (Spring 2016) W13.pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160331/f6d72c71/attachment-0003.obj>
More information about the mcs-pool
