[POOL] Week 8 Corrected Results
David A Stevens
dstevens at CBI.com
Sat Feb 27 16:07:22 CST 2016
A data entry error was noticed in the results sent out a couple of days
ago. I have corrected the error in the results attached below. This is a
big part of emailing the results every week. It is fun to know what
happened, especially for those that weren't there that week, but it is
also an opportunity for everyone to confirm their results. It is always
easier to check/correct things before the next week's scoresheets are
printed, so emailing us with any questions is encouraged. (FWIW - When
questioned, the records haven't always been wrong, but we are always happy
to check.) Match 3-5 was the corrected match.
The cat did claw my leg and try to jump into my lap at one point, so I am
going to blame the cat.
At the bottom of the results input table, we have a summary for checking
purposes. We have not been printing it because it makes the page pretty
long. I included it this time. Let us know if you would like to see it
in the future.
Corrected Results, Stats, and Standings:
Best regards,
David A Stevens
Civil-Structural Engineer (PSE)
Steel Plate Structures
Tel: +1 815 439 6095
Fax: +1 815 439 6492
dstevens at CBI.com
CB&I
14105 S. Route 59
Plainfield, IL 60544-898
United States
www.CBI.com
This e-mail and any attached files may contain CB&I (or its affiliates) confidential and privileged information. This information is protected by law and/or agreements between CB&I (or its affiliates) and either you, your employer or any contract provider with which you or your employer are associated. If you are not an intended recipient, please contact the sender by reply e-mail and delete all copies of this e-mail; further, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0001.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0004.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0005.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0006.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0007.gif>
Name: APL Results (Spring 2016) W8.pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0002.obj>
Name: APL Stat Results (Spring 2016) W8.pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160227/038254f4/attachment-0003.obj>
More information about the mcs-pool
