[POOL] APL Week 8 Results and Week 9 Schedule
David A Stevens
dstevens at CBI.com
Thu Feb 25 07:34:41 CST 2016
Here are the results from Week 8 (Feb 23). We played 18 matches Tuesday,
so we have two makeups from this week.
Here are the rankings. The teams tied for 5th are sorted by team number,
so there is no significance to the order. (I sorted them in reverse order
this week because most everything sorts starting with A or 1. "Stevens"
is not last in every line, but I am usually stuck with what's left.) Note:
Teams 2, 3, 4, & 7 each have one outstanding match.
Here is the schedule for next week.
I'm not sure how soon the website will be updated.
Best regards,
David A Stevens
Civil-Structural Engineer (PSE)
Steel Plate Structures
Tel: +1 815 439 6095
Fax: +1 815 439 6492
dstevens at CBI.com
CB&I
14105 S. Route 59
Plainfield, IL 60544-898
United States
www.CBI.com
This e-mail and any attached files may contain CB&I (or its affiliates) confidential and privileged information. This information is protected by law and/or agreements between CB&I (or its affiliates) and either you, your employer or any contract provider with which you or your employer are associated. If you are not an intended recipient, please contact the sender by reply e-mail and delete all copies of this e-mail; further, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0001.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0005.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0006.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0007.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0008.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0009.gif>
Name: APL Results (Spring 2016) W8.pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0002.obj>
Name: APL Stat Results (Spring 2016) W8.pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160225/dfcf4c58/attachment-0003.obj>
More information about the mcs-pool
