[POOL] Fwd: Argonne Pool League PROPOSED CHANGES
Aaron Magill
amagill at the-magills.com
Tue Sep 4 22:55:37 CDT 2007
I'd vote against the changes myself -- almost all of these seem to
benefit the better players more and part of the reason I found playing
fun was that I thought we had a pretty good handicapping system that
didn't punish blind luck.
And if the length of the nights really is a problem, I guess I'd
slightly rather drop to 4 matches even at a greater cost than change the
handicapping.
I'll still try to come when I can if these go into effect, but I
honestly think it'll result in a bigger separation between the really
good players and the less talented -- of which I humbly consider myself ;-).
Aaron
Craig Stacey wrote:
> Send me your thoughts on the rule changes and proposals below. I'll
> respond to Kevin tomorrow. Note that if we reduce to 4 matches, league
> income will fall accordingly unless we raise the per match fee.
> As for the rule changes, I don't like any of them.
> Begin forwarded message:
>> All,
>> There are some issues pertaining to the upcoming season that need to
>> be considered before we start. Some rule changes have been proposed.
>> Also, finding a solution to the late, late matches is important.
>> There are a few ideas that have been put forward. I would like to
>> hear what everyone has to say about the matter. And, I think that the
>> teams should vote on each item proposed.
>> I would ask that if there is discussion for any issue, please REPLY
>> ALL to this message. For actual VOTING people can reply to everyone,
>> or to just me if they wish to keep their vote private.
>> First, the following rule changes have been proposed:
>> 1) Call-shot vs. slop-shot.
>> 2) Because of 1), there are called safeties.
>> 3) The table is always open after the break.
>> 4) 8-ball on the break is *not* a win.
>> 5) Scratching on the 8-ball is *not* a loss if the 8-ball is not
>> pocketed.
>> These are the rules from the World Pool-Billiard Association. The
>> main difference between WPA and what we currently use are as above.
>> (http://www.wpa-pool.com/index.asp?content=rules_8ball) It is also
>> proposed that we put these rules into effect for a period of time
>> (say, four weeks) to evaluate them before deciding if people like
>> them, or want to continue on with our current rules.
>> Second, a change in the matchup charge has been proposed:
>> Chart-4 up to 39 [same as before]
>> Chart-6 40-59
>> Chart-8 60-79
>> Chart-10 80-109
>> Chart-12 110-up
>> This will have the effect of reducing the number of games played per
>> match. It is thought that if we reduce the number of games per match
>> by approximately 2, this will save as much as 60 - 90 minutes in the
>> evening. This will mean that the matches will get over quicker and we
>> will not have to reduce their number.
>> Third, barring the idea previously proposed, it has been suggested
>> that we reduce the number of matches played in an evening from 5 to
>> 4. This will certainly cut short the evening, but it leaves a
>> situation where there is no clear cut winner for the evening.
>> Please feel free to comment upon any, or all, of these issues. We
>> have two weeks to get things in order. Please talk with your team
>> members and find out how they feel about this.
>> Thanks for your time,
>> Kevin
> Craig
> !DSPAM:46de22f5131331784619423!
More information about the mcs-pool
