[Darshan-users] DASK and darshan
Harms, Kevin harms at alcf.anl.gov
Tue Oct 13 18:53:08 CDT 2020
Razvan,
  It's be a couple of years since i used Dask, but you should be able to profile by setting LD_PRELOAD=/path/to/darshan/install/lib/libdarshan.so.
  Please note that Dask will start a process for each python instance so you will have a darshan log for each process. A few more caveats, if you're using remote processes, I'm not sure if the Dask servers will pass environment variables or not. I think Dask has other non-distributed schedulers that might work differently if running on a single node.
  Also note, by default Darshan assumes MPI and depends on it. If you're applications aren't using MPI, then make sure you configure darshan with the switch --without-mpi.
kevin
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Razvan Stefanescu <razvan.stefanescu at spire.com>
Sent: Tuesday, October 13, 2020 4:41 PM
To: darshan-users at lists.mcs.anl.gov
Subject: [Darshan-users] DASK and darshan
Hello All,
We need to profile some DASK parallel I/O application, and I wonder if you can provide an example on how to use darshan to perform such analysis. Your help is much appreciated.
Thank you,
Razvan
RAZVAN STEFANESCU
Head of Statistics and Machine Learning Branch
Senior Data Assimilation and Data Scientist
Spire Global, Inc.
1050 Walnut Street, Suite 402, Boulder, CO 80302 USA
+1-720-<tel:7206432245>643-2231
+1-850-443-1718<tel:4178491948>
More information about the Darshan-users mailing list
