[Darshan-users] Profiling Python C/C++ extensions with Darshan
Phil Carns carns at mcs.anl.gov
Mon Mar 6 12:39:18 CST 2017
Excellent- thank you for following-up with your solution!
-Phil
On 02/27/2017 06:50 PM, Ivan Raikov wrote:
> The Blue Waters support staff worked out a solution, so I am posting
> it here for the sake of posterity.
> The following environment variable settings are necessary to work
> around the socket error on MPI startup:
> export PMI_NO_FORK=1
> export PMI_NO_PREINITIALIZE=1
> #both hdf5 and darshan are needed.
> export LD_PRELOAD=/sw/xe/darshan/2.3.0/darshan-2.3.0_cle52/lib/libdarshan.so:/opt/cray/hdf5-parallel/1.8.16/GNU/4.9/lib/libhdf5_parallel_gnu_49.so.10
> aprun ...
> On Mon, Feb 27, 2017 at 11:09 AM, Ivan Raikov <ivan.g.raikov at gmail.com> wrote:
>> Hello,
>> I have a Python extension written in C++ which calls the HDF library,
>> and I would like to use Darshan to profile an MPI-based Python
>> application which invokes that extension. However, compiling the
>> extension and running the application on Blue Waters (Cray-based
>> system) with Darshan 2.3 results in no profile data being generated.
>> Using LD_PRELOAD to load Darshan dynamically results in some kind of
>> socket error when (I think) the MPI process manager is launching the
>> Python executable. I have also tried the LD_PRELOAD mechanism with
>> Darshan 3.1.3 built by the HDF group, but I  get the same error. I was
>> wondering if anyone here has done profiling with dynamically linked
>> Python extensions, or if anyone has any advice how to approach this.
>> I invoke the application with LD_PRELOAD thus:
>> export LD_PRELOAD=/path/to/darshan/3.1.3/lib/libdarshan.so
>> aprun -n 4096 python main.py ...
>> or
>> aprun -n 4096 -e LD_PRELOAD=/path/to/darshan/3.1.3/.../lib/libdarshan.so
>> The error I get with LD_PRELOAD is the following:
>> [PE_3344]:inet_listen_socket_setup:inet_setup_listen_socket: bind
>> failed port 1371 listen_sock = 88 Address already in use
>> [PE_3344]:_pmi_inet_listen_socket_setup:socket setup failed
>> [PE_3344]:_pmi_init:_pmi_inet_listen_socket_setup (full) returned -1
>> [PE_208]:inet_listen_socket_setup:inet_setup_listen_socket: bind
>> failed port 1371 listen_sock = 74 Address already in use
>> [PE_208]:_pmi_inet_listen_socket_setup:socket setup failed
>> [PE_208]:_pmi_init:_pmi_inet_listen_socket_setup (full) returned -1
>> Thanks and best regards,
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users mailing list
