[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-main-profconf-dynamic #1576
no-reply at alcf.anl.gov no-reply at alcf.anl.gov
Tue May 23 09:17:27 CDT 2023
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-profconf-dynamic/1576/display/redirect>
Changes:
Started by timer
Running as SYSTEM
Building remotely on RadixIO-CINOW-01 in workspace <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-profconf-dynamic/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
The recommended git tool is: NONE
No credentials specified
Cloning the remote Git repository
Cloning repository https://github.com/darshan-hpc/darshan.git
 > git init <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-profconf-dynamic/ws/> # timeout=10
Fetching upstream changes from https://github.com/darshan-hpc/darshan.git
 > git --version # timeout=10
 > git --version # 'git version 2.17.1'
 > git fetch --tags --progress -- https://github.com/darshan-hpc/darshan.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git config remote.origin.url https://github.com/darshan-hpc/darshan.git # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
 > git rev-parse refs/remotes/origin/main^{commit} # timeout=10
Checking out Revision 7c4e43c813e1268e737a4dd9e90f9e642cd72a21 (refs/remotes/origin/main)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 7c4e43c813e1268e737a4dd9e90f9e642cd72a21 # timeout=10
Commit message: "Merge pull request #932 from darshan-hpc/snyder/dev-no-dxt-heatmap-default"
 > git rev-list --no-walk 7c4e43c813e1268e737a4dd9e90f9e642cd72a21 # timeout=10
[x86-main-profconf-dynamic] $ /bin/bash /tmp/jenkins14187058225104019700.sh
--2023-05-23 14:17:27--  http://www.mpich.org/static/downloads/3.2.1/mpich-3.2.1.tar.gz
Resolving proxy.mcp.alcf.anl.gov (proxy.mcp.alcf.anl.gov)... 10.230.1.189
Connecting to proxy.mcp.alcf.anl.gov (proxy.mcp.alcf.anl.gov)|10.230.1.189|:3128... connected.
Proxy request sent, awaiting response... 301 Moved Permanently
Location: https://www.mpich.org/static/downloads/3.2.1/mpich-3.2.1.tar.gz [following]
--2023-05-23 14:17:27--  https://www.mpich.org/static/downloads/3.2.1/mpich-3.2.1.tar.gz
Proxy request sent, awaiting response... 403 Forbidden
2023-05-23 14:17:27 ERROR 403: Forbidden.
Build step 'Execute shell' marked build as failure
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: No test report files were found. Configuration error?
More information about the Darshan-commits mailing list
