[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-main-cc-wrapper-dynamic #1277
no-reply at alcf.anl.gov no-reply at alcf.anl.gov
Thu Dec 21 16:10:19 CST 2023
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/1277/display/redirect?page=changes>
Changes:
[spwalto] LDMS implementation for runtime I/O collection
[spwalto] CI: Test for LDMS Integration
[spwalto] Updating branch with main
[spwalto] moving ldms code to separate file
[spwalto] BLD: fix editable installs
[spwalto] updating github workflow
[spwalto] merging main and cleaning up ldms related code
[spwalto] removing ldms mdhim and updating ldms event fields
[spwalto] fixing ldms field values and updating jobid
[spwalto] updating timestamp code snippets
[noreply] minor syntax fix
[Shane Snyder] various small fixes
[Shane Snyder] more whitespace changes
[spwalto] removing set_meta and pulling filename from record ID
[spwalto] adding required libraries
[Shane Snyder] small changes
[Shane Snyder] lots of small whitespace changes
[Shane Snyder] more smaller whitespace changes
[Shane Snyder] couple more whitespace changes
[spwalto] fixes to json
[spwalto] fixing printf, mod checks and close counts
[spwalto] adding struct intialization
[spwalto] fixing close counter
[spwalto] fixing hdf5, rename variables and fixing spaces
[Shane Snyder] whitespace changes and other small things
[Shane Snyder] declare dC Darshan connector as extern in header
[Shane Snyder] LDMS build changes
[spwalto] test script fixes and updates to LDMS output
[Shane Snyder] try to run LDMS workflow on PRs to main
[Shane Snyder] simplify ldms workflows slightly
[Shane Snyder] more openmpi libs needed
[Shane Snyder] use darshan-parser, not darshan-dxt-parser
[Shane Snyder] first attempt at pyproject.toml [wheel build]
[Shane Snyder] consolidate pytest dependencies
[Shane Snyder] more test dependency consolidation
[Shane Snyder] more migration from setup.py to pyproject.toml
[Shane Snyder] add build_meta backend [wheel build]
[Shane Snyder] reduce setup.cfg
[Shane Snyder] extract package version in pyproject.toml
[spwalto] adding LDMS switch and fixing env checks/messages
[noreply] Update darshan_ldms_test_ci.yml
[Shane Snyder] updated runtime docs for LDMS
[...truncated 807.56 KB...]
make[1]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
 /usr/bin/install -c darshan-config darshan-gen-cc.pl darshan-gen-cxx.pl darshan-gen-fortran.pl darshan-mk-log-dirs.pl '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
tar xjf ../../darshan-util/extern/uthash-1.9.2.tar.bz2
ln -s ../../darshan-util/../modules/autoperf/apxc/util/darshan-apxc-logutils.c .
ln -s ../../darshan-util/../modules/autoperf/apmpi/util/darshan-apmpi-logutils.c .
make  all-recursive
make[1]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
Making all in darshan-job-summary
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
  CC       darshan-null-logutils.lo
  CC       darshan-logutils.lo
  CC       darshan-posix-logutils.lo
  CC       darshan-mpiio-logutils.lo
  CC       darshan-hdf5-logutils.lo
  CC       darshan-pnetcdf-logutils.lo
  CC       darshan-bgq-logutils.lo
  CC       darshan-lustre-logutils.lo
  CC       darshan-stdio-logutils.lo
  CC       darshan-dxt-logutils.lo
  CC       darshan-heatmap-logutils.lo
  CC       darshan-mdhim-logutils.lo
  CC       darshan-logutils-accumulator.lo
  CC       darshan-apxc-logutils.lo
  CC       darshan-apmpi-logutils.lo
  CCLD     libdarshan-util.la
  CC       darshan-analyzer.o
  CCLD     darshan-analyzer
  CC       darshan-convert.o
  CC       lookup3.o
  CCLD     darshan-convert
  CC       darshan-diff.o
  CCLD     darshan-diff
  CC       darshan-parser.o
  CCLD     darshan-parser
  CC       darshan-dxt-parser.o
  CCLD     darshan-dxt-parser
  CC       darshan-merge.o
  CCLD     darshan-merge
  CC       jenkins-hash-gen.o
  CCLD     jenkins-hash-gen
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
make  install-recursive
Making install in darshan-job-summary
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
 /usr/bin/install -c bin/darshan-job-summary.pl '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Number/Bytes'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Number/Bytes'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Pod'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/lib/Pod/Constants.pm ../../../darshan-util/darshan-job-summary/lib/Pod/LaTeX.pm '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Pod'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/share/access-hist-eps.gplt ../../../darshan-util/darshan-job-summary/share/file-access-eps.gplt ../../../darshan-util/darshan-job-summary/share/file-access-table.tex ../../../darshan-util/darshan-job-summary/share/job-table.tex ../../../darshan-util/darshan-job-summary/share/op-counts-eps.gplt ../../../darshan-util/darshan-job-summary/share/pattern-eps.gplt ../../../darshan-util/darshan-job-summary/share/summary.tex ../../../darshan-util/darshan-job-summary/share/time-summary-eps.gplt ../../../darshan-util/darshan-job-summary/share/title.tex '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/TeX'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/TeX'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib'>
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libdarshan-util.la '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib'>
libtool: install: /usr/bin/install -c .libs/libdarshan-util.so.0.0.0 /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.so.0.0.0>
libtool: install: (cd /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib> && { ln -s -f libdarshan-util.so.0.0.0 libdarshan-util.so.0 || { rm -f libdarshan-util.so.0 && ln -s libdarshan-util.so.0.0.0 libdarshan-util.so.0; }; })
libtool: install: (cd /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib> && { ln -s -f libdarshan-util.so.0.0.0 libdarshan-util.so || { rm -f libdarshan-util.so && ln -s libdarshan-util.so.0.0.0 libdarshan-util.so; }; })
libtool: install: /usr/bin/install -c .libs/libdarshan-util.lai /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.la>
libtool: install: /usr/bin/install -c .libs/libdarshan-util.a /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.a>
libtool: install: chmod 644 /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.a>
libtool: install: ranlib /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.a>
libtool: finish: PATH="<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/bin>:/usr/local/bin:/usr/bin:/dbhome/db2cat/sqllib/bin:/dbhome/db2cat/sqllib/adm:/dbhome/db2cat/sqllib/misc:/dbhome/db2cat/sqllib/gskit/bin:/opt/ibutils/bin:/sbin" ldconfig -n /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib>
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
  /bin/sh ./libtool   --mode=install /usr/bin/install -c darshan-analyzer darshan-convert darshan-diff darshan-parser darshan-dxt-parser darshan-merge '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
libtool: install: /usr/bin/install -c .libs/darshan-analyzer /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-analyzer>
libtool: install: /usr/bin/install -c .libs/darshan-convert /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-convert>
libtool: install: /usr/bin/install -c .libs/darshan-diff /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-diff>
libtool: install: /usr/bin/install -c .libs/darshan-parser /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-parser>
libtool: install: /usr/bin/install -c .libs/darshan-dxt-parser /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-dxt-parser>
libtool: install: /usr/bin/install -c .libs/darshan-merge /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-merge>
 /usr/bin/install -c ../../darshan-util/darshan-summary-per-file.sh ../../darshan-util/dxt_analyzer.py '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
make  install-exec-hook
make[4]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
make[4]: Nothing to be done for `install-exec-hook'.
make[4]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include'>
 /usr/bin/install -c -m 644 ../../darshan-util/darshan-null-logutils.h ../../darshan-util/darshan-logutils.h ../../darshan-util/darshan-posix-logutils.h ../../darshan-util/darshan-mpiio-logutils.h ../../darshan-util/darshan-hdf5-logutils.h ../../darshan-util/darshan-pnetcdf-logutils.h ../../darshan-util/darshan-bgq-logutils.h ../../darshan-util/darshan-lustre-logutils.h ../../darshan-util/darshan-stdio-logutils.h ../../darshan-util/darshan-dxt-logutils.h ../../darshan-util/darshan-heatmap-logutils.h ../../darshan-util/darshan-mdhim-logutils.h ../../darshan-util/../include/darshan-bgq-log-format.h ../../darshan-util/../include/darshan-dxt-log-format.h ../../darshan-util/../include/darshan-heatmap-log-format.h ../../darshan-util/../include/darshan-hdf5-log-format.h ../../darshan-util/../include/darshan-log-format.h ../../darshan-util/../include/darshan-lustre-log-format.h ../../darshan-util/../include/darshan-mdhim-log-format.h ../../darshan-util/../include/darshan-mpiio-log-format.h ../../darshan-util/../include/darshan-null-log-format.h ../../darshan-util/../include/darshan-pnetcdf-log-format.h ../../darshan-util/../include/darshan-posix-log-format.h ../../darshan-util/../include/darshan-stdio-log-format.h ../../darshan-util/../modules/autoperf/apxc/darshan-apxc-log-format.h ../../darshan-util/../modules/autoperf/apxc/util/darshan-apxc-logutils.h ../../darshan-util/../modules/autoperf/apmpi/darshan-apmpi-log-format.h ../../darshan-util/../modules/autoperf/apmpi/util/darshan-apmpi-logutils.h '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include/uthash-1.9.2/src'>
 /usr/bin/install -c -m 644  uthash-1.9.2/src/uthash.h '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include/uthash-1.9.2/src'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/pkgconfig'>
 /usr/bin/install -c -m 644 maint/darshan-util.pc '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/pkgconfig'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
[x86-main-cc-wrapper-dynamic] $ /bin/bash /tmp/jenkins13589080776813516851.sh
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/access-size-counter-test.sh...>
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/cxxpi.sh...>
/tmp/ccOeULOT.o: In function `main':
cxxpi.cxx:(.text+0x8a): undefined reference to `__wrap_MPI_Init'
cxxpi.cxx:(.text+0x16d): undefined reference to `__wrap_MPI_Bcast'
cxxpi.cxx:(.text+0x228): undefined reference to `__wrap_MPI_Reduce'
cxxpi.cxx:(.text+0x300): undefined reference to `__wrap_MPI_Finalize'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_lock'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Send'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Irecv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_all'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_ordered_begin'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Scatter'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_iread_at'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Ssend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_ordered'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Test'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_shared'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_at_all'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_iwrite_at'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_iread_shared'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Isend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Gather'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Alltoallv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_all_begin'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Init_thread'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_at_all_begin'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Alltoallw'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Scan'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Bsend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_at_all'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_close'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_iread'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Scatterv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_iwrite'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Rsend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_ordered_begin'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_start'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_all'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Accumulate'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_ordered'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Get'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Exscan'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Wait'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Issend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Probe'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_set_view'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Allgatherv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_iwrite_shared'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Allgather'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Reduce_scatter'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Gatherv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_post'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Alltoall'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_all_begin'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_complete'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_shared'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Irsend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Iprobe'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_read_at'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_fence'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_test'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Barrier'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Sendrecv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_unlock'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Sendrecv_replace'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_at'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Allreduce'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_write_at_all_begin'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Win_wait'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Ibsend'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Recv'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_Put'
<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/lib/libmpicxx.so>: undefined reference to `__wrap_MPI_File_sync'
collect2: error: ld returned 1 exit status
[proxy:0:0 at cinow-01.mcp.alcf.anl.gov] HYDU_create_process (utils/launch/launch.c:75): execvp error on file /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/scratch/cxxpi> (No such file or directory)
Error: failed to execute cxxpi
Error: failed to execute test case /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/cxxpi.sh>
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fperf-f77.sh...>
 Access size per process =      4194304  bytes, ntimes =            5
 Write bandwidth without file sync =    4008.0164138328873       Mbytes/sec
 Read bandwidth without prior file sync =    23669.271502746047       Mbytes/sec
 Write bandwidth including file sync =    1282.6733777667923       Mbytes/sec
 Read bandwidth after file sync =    24926.937363678357       Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fperf-f90.sh...>
 Write bandwidth without file sync =    2551.3485434779013       Mbytes/sec
 Read bandwidth without prior file sync =    24803.928155679943       Mbytes/sec
 Write bandwidth including file sync =    1259.7566046234986       Mbytes/sec
 Read bandwidth after file sync =    25276.129374160919       Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fprintf-fscanf-test.sh...>
# Using stdio calls.
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/mpi-io-test-dxt.sh...>
# Using mpi-io calls.
nr_procs = 4, nr_iter = 1, blk_sz = 16777216, coll = 0
# total_size = 67108864
# Write: min_t = 0.014488, max_t = 0.042048, mean_t = 0.035041, var_t = 0.000188
# Read:  min_t = 0.008112, max_t = 0.023096, mean_t = 0.012066, var_t = 0.000054
Write bandwidth = 1596.025044 Mbytes/sec
Read bandwidth = 2905.668123 Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/mpi-io-test.sh...>
# Write: min_t = 0.020927, max_t = 0.021875, mean_t = 0.021592, var_t = 0.000000
# Read:  min_t = 0.007759, max_t = 0.008241, mean_t = 0.007898, var_t = 0.000000
Write bandwidth = 3067.813721 Mbytes/sec
Read bandwidth = 8143.116841 Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/stdio-test.sh...>
Done.
1 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
[Checks API] No suitable checks publisher found.
More information about the Darshan-commits mailing list
