[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-main-cc-wrapper-dynamic #830
no-reply at alcf.anl.gov no-reply at alcf.anl.gov
Sun Sep 18 17:10:29 CDT 2022
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/830/display/redirect>
Changes:
[...truncated 799.56 KB...]
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include'>
 /usr/bin/install -c -m 644 ../../../darshan-runtime/../modules/autoperf/apmpi/darshan-apmpi-log-format.h '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/lib'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/lib'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/lib'>
Making install in pkgconfig
make[1]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/pkgconfig'>
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/pkgconfig'>
make[2]: Nothing to be done for `install-exec-am'.
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/pkgconfig'>
 /usr/bin/install -c -m 644 darshan-runtime.pc '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/pkgconfig'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/pkgconfig'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/pkgconfig'>
Making install in share
make[1]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share'>
Making install in ld-opts
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/ld-opts'>
make  install-am
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/ld-opts'>
make[4]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/ld-opts'>
make[4]: Nothing to be done for `install-exec-am'.
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/ld-opts'>
 /usr/bin/install -c -m 644 ../../../../darshan-runtime/share/ld-opts/darshan-posix-ld-opts ../../../../darshan-runtime/share/ld-opts/darshan-mpiio-ld-opts ../../../../darshan-runtime/share/ld-opts/darshan-pnetcdf-ld-opts '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/ld-opts'>
 /usr/bin/install -c -m 644 darshan-ld-opts darshan-stdio-ld-opts autoperf-apmpi-ld-opts '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/ld-opts'>
make[4]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/ld-opts'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/ld-opts'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/ld-opts'>
Making install in craype-1.x
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-1.x'>
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-1.x'>
make[3]: Nothing to be done for `install-exec-am'.
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/craype-1.x/modulefiles/darshan'>
 /usr/bin/install -c -m 644 3.4.0 '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/craype-1.x/modulefiles/darshan'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-1.x'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-1.x'>
Making install in craype-2.x
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-2.x'>
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-2.x'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/craype-2.x/modulefiles/darshan'>
 /usr/bin/install -c -m 644 3.4.0 '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/craype-2.x/modulefiles/darshan'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-2.x'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/craype-2.x'>
Making install in mpi-profile
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/mpi-profile'>
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/mpi-profile'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/mpi-profile'>
 /usr/bin/install -c -m 644 darshan-cc.conf darshan-cc-static.conf darshan-cxx.conf darshan-cxx-static.conf darshan-f.conf darshan-f-static.conf '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share/mpi-profile'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/mpi-profile'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share/mpi-profile'>
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share'>
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share'>
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime/share'>
make[1]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
 /usr/bin/install -c darshan-config darshan-gen-cc.pl darshan-gen-cxx.pl darshan-gen-fortran.pl darshan-mk-log-dirs.pl '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-runtime'>
tar xjf ../../darshan-util/extern/uthash-1.9.2.tar.bz2
ln -s ../../darshan-util/../modules/autoperf/apxc/util/darshan-apxc-logutils.c .
ln -s ../../darshan-util/../modules/autoperf/apmpi/util/darshan-apmpi-logutils.c .
make  all-recursive
make[1]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
Making all in darshan-job-summary
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
make[2]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
  CC       darshan-null-logutils.lo
  CC       darshan-logutils.lo
  CC       darshan-posix-logutils.lo
  CC       darshan-mpiio-logutils.lo
  CC       darshan-hdf5-logutils.lo
  CC       darshan-pnetcdf-logutils.lo
  CC       darshan-bgq-logutils.lo
  CC       darshan-lustre-logutils.lo
  CC       darshan-stdio-logutils.lo
  CC       darshan-dxt-logutils.lo
  CC       darshan-heatmap-logutils.lo
  CC       darshan-mdhim-logutils.lo
  CC       darshan-logutils-accumulator.lo
  CC       darshan-apxc-logutils.lo
  CC       darshan-apmpi-logutils.lo
  CCLD     libdarshan-util.la
  CC       darshan-analyzer.o
  CCLD     darshan-analyzer
  CC       darshan-convert.o
  CC       lookup3.o
  CCLD     darshan-convert
  CC       darshan-diff.o
  CCLD     darshan-diff
  CC       darshan-parser.o
  CCLD     darshan-parser
  CC       darshan-dxt-parser.o
  CCLD     darshan-dxt-parser
  CC       darshan-merge.o
  CCLD     darshan-merge
  CC       jenkins-hash-gen.o
  CCLD     jenkins-hash-gen
make[2]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
make[1]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
make  install-recursive
Making install in darshan-job-summary
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
 /usr/bin/install -c bin/darshan-job-summary.pl '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Number/Bytes'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Number/Bytes'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Pod'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/lib/Pod/Constants.pm ../../../darshan-util/darshan-job-summary/lib/Pod/LaTeX.pm '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/Pod'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/share/access-hist-eps.gplt ../../../darshan-util/darshan-job-summary/share/file-access-eps.gplt ../../../darshan-util/darshan-job-summary/share/file-access-table.tex ../../../darshan-util/darshan-job-summary/share/job-table.tex ../../../darshan-util/darshan-job-summary/share/op-counts-eps.gplt ../../../darshan-util/darshan-job-summary/share/pattern-eps.gplt ../../../darshan-util/darshan-job-summary/share/summary.tex ../../../darshan-util/darshan-job-summary/share/time-summary-eps.gplt ../../../darshan-util/darshan-job-summary/share/title.tex '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/share'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/TeX'>
 /usr/bin/install -c -m 644 ../../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/TeX'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util/darshan-job-summary'>
make[3]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib'>
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libdarshan-util.la '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib'>
libtool: install: /usr/bin/install -c .libs/libdarshan-util.so.0.0.0 /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.so.0.0.0>
libtool: install: (cd /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib> && { ln -s -f libdarshan-util.so.0.0.0 libdarshan-util.so.0 || { rm -f libdarshan-util.so.0 && ln -s libdarshan-util.so.0.0.0 libdarshan-util.so.0; }; })
libtool: install: (cd /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib> && { ln -s -f libdarshan-util.so.0.0.0 libdarshan-util.so || { rm -f libdarshan-util.so && ln -s libdarshan-util.so.0.0.0 libdarshan-util.so; }; })
libtool: install: /usr/bin/install -c .libs/libdarshan-util.lai /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.la>
libtool: install: /usr/bin/install -c .libs/libdarshan-util.a /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.a>
libtool: install: chmod 644 /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.a>
libtool: install: ranlib /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/libdarshan-util.a>
libtool: finish: PATH="<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/mpich-install/bin>:/usr/local/bin:/usr/bin:/dbhome/db2cat/sqllib/bin:/dbhome/db2cat/sqllib/adm:/dbhome/db2cat/sqllib/misc:/dbhome/db2cat/sqllib/gskit/bin:/opt/ibutils/bin:/sbin" ldconfig -n /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib>
Libraries have been installed in:
     during execution
     during linking
  /bin/sh ./libtool   --mode=install /usr/bin/install -c darshan-analyzer darshan-convert darshan-diff darshan-parser darshan-dxt-parser darshan-merge '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
libtool: install: /usr/bin/install -c .libs/darshan-analyzer /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-analyzer>
libtool: install: /usr/bin/install -c .libs/darshan-convert /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-convert>
libtool: install: /usr/bin/install -c .libs/darshan-diff /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-diff>
libtool: install: /usr/bin/install -c .libs/darshan-parser /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-parser>
libtool: install: /usr/bin/install -c .libs/darshan-dxt-parser /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-dxt-parser>
libtool: install: /usr/bin/install -c .libs/darshan-merge /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin/darshan-merge>
 /usr/bin/install -c ../../darshan-util/darshan-summary-per-file.sh ../../darshan-util/dxt_analyzer.py '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/bin'>
make  install-exec-hook
make[4]: Entering directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
make[4]: Nothing to be done for `install-exec-hook'.
make[4]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
 /usr/bin/install -c -m 644 ../../darshan-util/darshan-null-logutils.h ../../darshan-util/darshan-logutils.h ../../darshan-util/darshan-posix-logutils.h ../../darshan-util/darshan-mpiio-logutils.h ../../darshan-util/darshan-hdf5-logutils.h ../../darshan-util/darshan-pnetcdf-logutils.h ../../darshan-util/darshan-bgq-logutils.h ../../darshan-util/darshan-lustre-logutils.h ../../darshan-util/darshan-stdio-logutils.h ../../darshan-util/darshan-dxt-logutils.h ../../darshan-util/darshan-heatmap-logutils.h ../../darshan-util/darshan-mdhim-logutils.h ../../darshan-util/../include/darshan-bgq-log-format.h ../../darshan-util/../include/darshan-dxt-log-format.h ../../darshan-util/../include/darshan-heatmap-log-format.h ../../darshan-util/../include/darshan-hdf5-log-format.h ../../darshan-util/../include/darshan-log-format.h ../../darshan-util/../include/darshan-lustre-log-format.h ../../darshan-util/../include/darshan-mdhim-log-format.h ../../darshan-util/../include/darshan-mpiio-log-format.h ../../darshan-util/../include/darshan-null-log-format.h ../../darshan-util/../include/darshan-pnetcdf-log-format.h ../../darshan-util/../include/darshan-posix-log-format.h ../../darshan-util/../include/darshan-stdio-log-format.h ../../darshan-util/../modules/autoperf/apxc/darshan-apxc-log-format.h ../../darshan-util/../modules/autoperf/apxc/util/darshan-apxc-logutils.h ../../darshan-util/../modules/autoperf/apmpi/darshan-apmpi-log-format.h ../../darshan-util/../modules/autoperf/apmpi/util/darshan-apmpi-logutils.h '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include'>
 /usr/bin/mkdir -p '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include/uthash-1.9.2/src'>
 /usr/bin/install -c -m 644  uthash-1.9.2/src/uthash.h '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/include/uthash-1.9.2/src'>
 /usr/bin/install -c -m 644 maint/darshan-util.pc '/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/install/lib/pkgconfig'>
make[3]: Leaving directory `/lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/build/darshan-util'>
[x86-main-cc-wrapper-dynamic] $ /bin/bash /tmp/jenkins18225185406021344647.sh
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/access-size-counter-test.sh...>
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/cxxpi.sh...>
Process 3 of 4 is on cinow-01.mcp.alcf.anl.gov
Process 0 of 4 is on cinow-01.mcp.alcf.anl.govProcess
Process 1 of 4 is on 2 of 4 is on cinow-01.mcp.alcf.anl.govcinow-01.mcp.alcf.anl.gov
pi is approximately 3.14159 Error is 8.33331e-10
wall clock time = 0.000169516
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fperf-f77.sh...>
 Access size per process =      4194304  bytes, ntimes =            5
 Write bandwidth without file sync =    3852.8659755619797       Mbytes/sec
 Read bandwidth without prior file sync =    21605.386606590113       Mbytes/sec
 Write bandwidth including file sync =    1136.4644806547910       Mbytes/sec
 Read bandwidth after file sync =    21853.647260144098       Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fperf-f90.sh...>
 Write bandwidth without file sync =    4461.0589690417146       Mbytes/sec
 Read bandwidth without prior file sync =    16273.992640532841       Mbytes/sec
 Write bandwidth including file sync =    1109.1823110504713       Mbytes/sec
 Read bandwidth after file sync =    22546.858115239986       Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fprintf-fscanf-test.sh...>
# Using stdio calls.
Error: STDIO bytes read count of 0 is incorrect
Error: failed to execute test case /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/fprintf-fscanf-test.sh>
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/mpi-io-test-dxt.sh...>
# Using mpi-io calls.
nr_procs = 4, nr_iter = 1, blk_sz = 16777216, coll = 0
# total_size = 67108864
# Write: min_t = 0.014683, max_t = 0.057718, mean_t = 0.044755, var_t = 0.000406
# Read:  min_t = 0.008708, max_t = 0.034550, mean_t = 0.015511, var_t = 0.000162
Write bandwidth = 1162.711348 Mbytes/sec
Read bandwidth = 1942.358756 Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/mpi-io-test.sh...>
# Write: min_t = 0.019117, max_t = 0.019431, mean_t = 0.019284, var_t = 0.000000
# Read:  min_t = 0.008056, max_t = 0.008216, mean_t = 0.008149, var_t = 0.000000
Write bandwidth = 3453.723073 Mbytes/sec
Read bandwidth = 8167.928287 Mbytes/sec
Done.
Running /lus/swift<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-main-cc-wrapper-dynamic/ws/darshan-test/regression/test-cases/stdio-test.sh...>
Done.
1 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
[Checks API] No suitable checks publisher found.
More information about the Darshan-commits mailing list
