[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-master-cc-wrapper-static #1030
no-reply at alcf.anl.gov no-reply at alcf.anl.gov
Tue Oct 12 06:03:30 CDT 2021
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/1030/display/redirect>
Changes:
Started by timer
Running as SYSTEM
Building remotely on RadixIO-CINOW-01 in workspace <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
The recommended git tool is: NONE
No credentials specified
Cloning the remote Git repository
Cloning repository https://xgitlab.cels.anl.gov/darshan/darshan.git
 > git init <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/ws/> # timeout=10
Fetching upstream changes from https://xgitlab.cels.anl.gov/darshan/darshan.git
 > git --version # timeout=10
 > git --version # 'git version 2.17.1'
 > git fetch --tags --progress -- https://xgitlab.cels.anl.gov/darshan/darshan.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git config remote.origin.url https://xgitlab.cels.anl.gov/darshan/darshan.git # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 6adce73eb8f4c3d32a193edd75ab8361719ae719 (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 6adce73eb8f4c3d32a193edd75ab8361719ae719 # timeout=10
Commit message: "Update README.md"
 > git rev-list --no-walk 6adce73eb8f4c3d32a193edd75ab8361719ae719 # timeout=10
[x86-master-cc-wrapper-static] $ /bin/bash /tmp/jenkins4812514943176294975.sh
--2021-10-12 11:03:30--  http://www.mpich.org/static/downloads/3.2.1/mpich-3.2.1.tar.gz
Resolving proxy.mcp.alcf.anl.gov (proxy.mcp.alcf.anl.gov)... 10.230.1.189
Connecting to proxy.mcp.alcf.anl.gov (proxy.mcp.alcf.anl.gov)|10.230.1.189|:3128... connected.
Proxy request sent, awaiting response... 302 Found
Location: https://www.mpich.org//static/downloads/3.2.1/mpich-3.2.1.tar.gz [following]
--2021-10-12 11:03:30--  https://www.mpich.org//static/downloads/3.2.1/mpich-3.2.1.tar.gz
ERROR: cannot verify www.mpich.org's certificate, issued by ‘/C=US/O=Let's Encrypt/CN=R3’:
  Issued certificate has expired.
To connect to www.mpich.org insecurely, use `--no-check-certificate'.
Build step 'Execute shell' marked build as failure
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: No test report files were found. Configuration error?
More information about the Darshan-commits mailing list
