[codes-ross-users] example_heterogeneous broken in doc/
Jenkins, Jonathan P. jenkins at mcs.anl.gov
Mon Dec 22 08:41:37 CST 2014
Hi Joe,
The problem is now fixed (at least for me). There were some bad arguments in the round-robin scheduler used by the "@bar" model-net configuration in the program, causing the message to short circuit and never be delivered.
Please try running again with the latest revision of codes-net, and let me know if you run into any other problems.
John
From: codes-ross-users-bounces at lists.mcs.anl.gov [codes-ross-users-bounces at lists.mcs.anl.gov] on behalf of Joe Scott [tscott2 at g.clemson.edu]
Sent: Sunday, December 21, 2014 11:19 AM
To: codes-ross-users at lists.mcs.anl.gov
Subject: [codes-ross-users] example_heterogeneous broken in doc/
Greetings,
I have been trying to wrap my head around building networks and was referring to the example_heterogeneous setup with forwarders.
Turns out, example_heterogeneous doesn't seem to work.  None of the pings/pongs get delivered.
Can anybody point out what is broken in example_heterogeneous?  I have tried tracing messages, and I can see that the initial ping gets to the bar forwarders, but when bar forwarders try to forward with 'model_net_event_annotated', something breaks and there is never a PING_RECEIVED event.
Joe Scott
Clemson University
codes-ross-users mailing list
https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
More information about the codes-ross-users mailing list
