[cgma-dev] r6059 - cgm/trunk/util
janehu at mcs.anl.gov janehu at mcs.anl.gov
Fri Sep 6 10:28:04 CDT 2013
Author: janehu
Date: 2013-09-06 10:28:03 -0500 (Fri, 06 Sep 2013)
New Revision: 6059
Modified:
   cgm/trunk/util/DLIList.cpp
Log:
Fixed last night's build failure and r6056 check-in mistakes.
Modified: cgm/trunk/util/DLIList.cpp
--- cgm/trunk/util/DLIList.cpp	2013-09-05 17:20:53 UTC (rev 6058)
+++ cgm/trunk/util/DLIList.cpp	2013-09-06 15:28:03 UTC (rev 6059)
@@ -181,12 +181,12 @@
       break;
     if ((*iter2 == *iter1) &&   // items are the same and ...
-        (insert < listArray ||  // is the first item or ...
+        (last_insert < listArray ||  // is the first item or ...
          *iter1 != *last_insert))    // is not the same as the previous item
       *++last_insert = *iter1;
-  itemCount = insert - listArray + 1;
+  itemCount = last_insert - listArray + 1;
   reset();
More information about the cgma-dev mailing list
