[cgma-dev] r5872 - in cgm/trunk: . amendment geom util
janehu at mcs.anl.gov janehu at mcs.anl.gov
Fri Nov 16 11:28:13 CST 2012
Author: janehu
Date: 2012-11-16 11:28:12 -0600 (Fri, 16 Nov 2012)
New Revision: 5872
Added:
   cgm/trunk/amendment/
   cgm/trunk/amendment/AutoMidsurfaceTool.cpp
   cgm/trunk/amendment/AutoMidsurfaceTool.hpp
   cgm/trunk/amendment/CAEntitySense.cpp
   cgm/trunk/amendment/CAEntitySense.hpp
   cgm/trunk/amendment/CAEntityTol.cpp
   cgm/trunk/amendment/CAEntityTol.hpp
   cgm/trunk/amendment/CGMHistory.cpp
   cgm/trunk/amendment/CGMHistory.hpp
   cgm/trunk/amendment/CubitCompat.cpp
   cgm/trunk/amendment/CubitCompat.h
   cgm/trunk/amendment/CubitCompat.h.in
   cgm/trunk/amendment/CubitCompat.hpp
   cgm/trunk/amendment/CubitFileSimModel.cpp
   cgm/trunk/amendment/CubitFileSimModel.hpp
   cgm/trunk/amendment/CubitUndo.cpp
   cgm/trunk/amendment/CubitUndo.hpp
   cgm/trunk/amendment/GfxPreview.cpp
   cgm/trunk/amendment/GfxPreview.hpp
   cgm/trunk/amendment/LocalToleranceTool.cpp
   cgm/trunk/amendment/LocalToleranceTool.hpp
   cgm/trunk/amendment/Makefile.am
Removed:
   cgm/trunk/geom/AutoMidsurfaceTool.cpp
   cgm/trunk/geom/AutoMidsurfaceTool.hpp
   cgm/trunk/geom/CAEntitySense.cpp
   cgm/trunk/geom/CAEntitySense.hpp
   cgm/trunk/geom/CAEntityTol.cpp
   cgm/trunk/geom/CAEntityTol.hpp
   cgm/trunk/geom/CGMHistory.cpp
   cgm/trunk/geom/CGMHistory.hpp
   cgm/trunk/geom/CubitCompat.cpp
   cgm/trunk/geom/CubitCompat.h.in
   cgm/trunk/geom/CubitCompat.hpp
   cgm/trunk/geom/GfxPreview.cpp
   cgm/trunk/geom/GfxPreview.hpp
   cgm/trunk/geom/LocalToleranceTool.cpp
   cgm/trunk/geom/LocalToleranceTool.hpp
   cgm/trunk/util/CubitFileSimModel.cpp
   cgm/trunk/util/CubitFileSimModel.hpp
   cgm/trunk/util/CubitUndo.cpp
   cgm/trunk/util/CubitUndo.hpp
Log:
Rearrange the added files in geom and util directory to a new directory called amendment.
Added: cgm/trunk/amendment/AutoMidsurfaceTool.cpp
--- cgm/trunk/amendment/AutoMidsurfaceTool.cpp	                        (rev 0)
+++ cgm/trunk/amendment/AutoMidsurfaceTool.cpp	2012-11-16 17:28:12 UTC (rev 5872)
@@ -0,0 +1,908 @@
+// Filename      : AutoMidsurfaceTool.cpp
+// Purpose       :
+//   Create a midsurface of a body/volume given a thickness range. If no thickness range is given
+//   then make a educated guess at the thickness (using something like Volume/Surface Area).
+//   Create Midsurface Volume <id_list> auto [<min_thickness> <max_thickness>]
+// Creator       : Sam Showman
+// Creation Date : 05/10/2008
+#include "AutoMidsurfaceTool.hpp"
+#include "GeometryModifyEngine.hpp"
+#include "GeometryQueryTool.hpp"
+#include "BodySM.hpp"
+#include "Body.hpp"
+#include "GeometryModifyTool.hpp"
+#include "RefFace.hpp"
+#include "Surface.hpp"
+#include "Curve.hpp"
+#include "RefEntity.hpp"
+#include "SurfaceOverlapTool.hpp"
+#include "CubitPlane.hpp"
+#include "GfxPreview.hpp"
+#include "GfxDebug.hpp"
+#include "RefVertex.hpp"
+#include "ProgressTool.hpp"
+#include "AppUtil.hpp"
+#include "BoundingBoxTool.hpp"
+#include "GeomMeasureTool.hpp"
+// Constructor - nothing going on here
+AutoMidsurfaceTool::AutoMidsurfaceTool()
+// The main midsurface function
+// lower_tol, upper_tol and preview are optional
+CubitStatus AutoMidsurfaceTool::midsurface(
+	DLIList<Body*> &body_list_in,
+	DLIList<BodySM*> &body_list_out,
+    DLIList<Body*> &old_bodies_midsurfaced,
+    DLIList<double> &thickness_out,
+	double lower_limit,
More information about the cgma-dev mailing list
