[cgma-dev] Cubit Linking Warnings
Tim Tautges tautges at mcs.anl.gov
Sun Jun 14 11:23:19 CDT 2009
I've added FAQ entries for these two warnings, and for the attribute
warnings, on the cgm wiki.
- tim
Chaman Singh Verma wrote:
> Hello Alvaro,
> I am not quire sure of the possible errors that might shown up later because of the following warnings:
> iGeom_CGMA.cc:(.text+0xa122): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
> /usr/bin/ld: warning: libstdc++.so.5, needed by /home/csv610/Software/Mesh/Cubit/lib/libcubiti19.so, may conflict with libstdc++.so.6
> If you have source code then perhaps Cubit can be compiled with libstdc++.so without the version number, so it will take available libstdc++ from the system.
> Thanks.
> csv
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
