[cgma-dev] r2728 - cgm/trunk/test
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Thu Mar 19 14:37:38 CDT 2009
Author: janehu
Date: 2009-03-19 14:37:37 -0500 (Thu, 19 Mar 2009)
New Revision: 2728
Modified:
   cgm/trunk/test/modify.cpp
Log:
Added test for fillet and chamfer, in OCC, there's no concept of blend in chamfer, chamfer coresponds with chamfer in ACIS, and fillet corresponding to blend in ACIS. Also if fillets for two adjacent edges of a body, the third one will be automatically filleted, this is different than ACIS. chamfer behaves the same.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2009-03-18 18:53:59 UTC (rev 2727)
+++ cgm/trunk/test/modify.cpp	2009-03-19 19:37:37 UTC (rev 2728)
@@ -125,6 +125,46 @@
   OCCQueryEngine::instance();
   OCCModifyEngine* ome = OCCModifyEngine::instance();
+  //test for tweak fillet and chamfer
+  Body* body = gmti->brick(10, 10, 10);
+  Body* body2 = gmti->brick(10, 10, 10);
+  CubitVector away(11, 0 , 0);
+  gti->translate(body2,away);
+  DLIList<RefEdge*> ref_edges;
+  body->ref_edges(ref_edges);
+  DLIList<Body*> new_bodies;
+  int isize=ref_edges.size();
+  for(int i = 2; i < isize; i++)
+    ref_edges.pop();
+  gmti->tweak_fillet(ref_edges, 1, new_bodies, CUBIT_FALSE, CUBIT_FALSE);
+  ref_edges.clean_out();
+  new_bodies.clean_out();
+  body2->ref_edges(ref_edges);
+  isize=ref_edges.size();
+    ref_edges.pop();
+  gmti->tweak_chamfer(ref_edges, 1, new_bodies, 1);
+  CubitStatus rsl = CUBIT_SUCCESS;
+  DLIList<RefEntity*> ref_entity_list;
+  int num_ents_exported=0;
+  const CubitString cubit_version="10.2";
+  const char * filename = "fillet.occ";
+  const char * filetype = "OCC";
+  rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
+                                 num_ents_exported, cubit_version);
+  DLIList<Body*> bodies;
+  DLIList<RefEntity*>  free_entities;
+  gti->bodies(bodies);
+  gti->get_free_ref_entities(free_entities);
+  //delete all entities
+  gti->delete_Body(bodies);
   //bug fixing for creating arc curve.
    CubitVector vti(6.0, 0.0, 0.0);
    RefVertex* vert1 = GeometryModifyTool::instance()->make_RefVertex(vti);
@@ -152,8 +192,8 @@
        coord = tmpVertex->coordinates();
-  DLIList<Body*> bodies;
-  DLIList<RefEntity*>  free_entities;
+  bodies.clean_out();
+  free_entities.clean_out();
@@ -166,13 +206,13 @@
   //other tests
-  Body* body = gmti->brick(10, 10, 10);
+  body = gmti->brick(10, 10, 10);
   CubitVector v(15,0,0);
   BodySM* bodysm = body->get_body_sm_ptr();
   DLIList<OCCSurface*> occ_surfaces;
   CAST_TO(bodysm, OCCBody)->get_all_surfaces(occ_surfaces);
   DLIList<RefFace*> ref_faces;
-  DLIList<RefEdge*> ref_edges;
   body->ref_faces(ref_faces);
   DLIList<RefFace*> faces_to_stitch;
@@ -220,17 +260,14 @@
   //create solid from surfaces
   //GeometryModifyEngine *gme = gmti->get_engine(occ_surfaces.get());
-  DLIList<Body*> new_bodies;
   gmti->create_solid_bodies_from_surfs(face_list, new_bodies);
   //Created volume(s): 9
   //Destroyed volume(s): 2 to 7
-  CubitStatus rsl = CUBIT_SUCCESS;
-  DLIList<RefEntity*> ref_entity_list;
-  int num_ents_exported=0;
-  const CubitString cubit_version="10.2";
-  const char * filename = "stitch.occ";
-  const char * filetype = "OCC";
+  ref_entity_list.clean_out();
+  num_ents_exported=0;
+  filename = "stitch.occ";
More information about the cgma-dev mailing list
