[cgma-dev] r2515 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Jan 7 14:48:47 CST 2009
Author: janehu
Date: 2009-01-07 14:48:47 -0600 (Wed, 07 Jan 2009)
New Revision: 2515
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added several get_mid_surface functions, not finished for getting conic type of mid-surface.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-07 17:56:19 UTC (rev 2514)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-07 20:48:47 UTC (rev 2515)
@@ -142,6 +142,7 @@
 #include <vector>
 OCCModifyEngine* OCCModifyEngine::instance_ = 0;
 #define DEBUG
+double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
 // Function   : OCCModifyEngine
 // Member Type: PUBLIC
@@ -401,7 +402,6 @@
   CubitVector v3;
   gp_Pnt pt3;
-  double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
   Handle(Geom_TrimmedCurve) curve_ptr;
   if(intermediate_point_ptr != NULL)
@@ -801,7 +801,6 @@
   OCCPoint* start = NULL;
   OCCPoint* end = NULL;
   DLIList<OCCPoint*> point_list;
   CubitBoolean new_end;
   int size = curve_list.size();
@@ -1787,7 +1786,6 @@
     return CUBIT_FAILURE;
   int fraction_remaining = 100;
   // subtract the tool body from each body in the list
@@ -1913,7 +1911,6 @@
   //list of face on from_shape that has been imprinted
   DLIList<TopoDS_Face*> from_faces;
   while( more_face)
     TopoDS_Face from_face,tool_face;
@@ -2449,7 +2446,6 @@
     double upper_bound = acurve.LastParameter();
     TopExp_Explorer Ex;
     gp_Pnt newP[2];
     for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
       TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
@@ -3452,7 +3448,6 @@
                                       CubitBoolean keep_old) const
    //compare to see if the from_shape has gotten cut.
    if(is_volume)
      GProp_GProps myProps;
@@ -3737,9 +3732,9 @@
-  double tol = 1.e-3; //hard coded for now, can be changed by application
+  double dtol = 1.e-3; //hard coded for now, can be changed by application
   TopoDS_Shape* solid = shape_list.get();
-  BRepOffsetAPI_MakeThickSolid hollower(*solid, face_shapes, depth, tol,
+  BRepOffsetAPI_MakeThickSolid hollower(*solid, face_shapes, depth, dtol,
                                         BRepOffset_Skin, Standard_False,
                                         Standard_False, GeomAbs_Intersection);
   TopoDS_Shape new_shape = hollower.Shape();
@@ -4221,7 +4216,6 @@
         CubitBoolean end_int = CUBIT_FALSE;
         if(intersect_pts.size() > 0)
           CubitBoolean non_int = CUBIT_FALSE;
           for(int i = 0; i < intersect_pts.size(); i++)
@@ -4665,7 +4659,6 @@
   v1 = point_2 - point_1;
   v2 = point_3 - point_1;
   normal = ~(v1 * v2);
   if(fabs(normal.length() - 1) > tol)
      PRINT_ERROR("The three points are co-linear, and can't be used as a cutting plane.\n");
@@ -4883,7 +4876,6 @@
   occ_crv->get_param_range(u1, u2);
   double trim_u = occ_crv->u_from_position(trim_vector);
   double keep_u = occ_crv->u_from_position(keep_vector);
   if(trim_u > u2+tol || trim_u < u1 - tol)
     PRINT_ERROR("The trim_vector is outside of the curve range.\n");
@@ -5028,7 +5020,6 @@
   CubitVector normal1 = tangent1 * tangent2;
   CubitVector normal2 = tangent2 * tangent3;
   CubitVector normal3 = tangent3 * tangent1;
   if( normal1.length()< tol || normal2.length()< tol ||
       normal3.length() < tol )
@@ -5160,7 +5151,6 @@
   CubitVector dir1( vec1, vec2 );
   CubitVector dir2( vec1, vec3 );
   // Re-adjust vec2, vec3 if radius was given
   if( radius != CUBIT_DBL_MAX )
@@ -5339,7 +5329,6 @@
@@ -5360,7 +5349,7 @@
   BodySM* tool = CAST_TO(surf, OCCSurface)->my_body();
-  DLIList<BodySM*> from_bodies, new_bodies;
+  DLIList<BodySM*> from_bodies;
   from_bodies.append(body_to_trim_to);
   CubitStatus stat = intersect(tool, from_bodies, midplane_bodies,
@@ -5370,31 +5359,236 @@
   return stat;
+// Function   : get_spheric_mid_surface
+// Member Type: PUBLIC
+// Description: Calculates a mid-surface between 2 spheric surfaces.
+// Author     : Jane Hu
+// Date       : 01/09
 CubitStatus OCCModifyEngine::get_spheric_mid_surface( Surface* surface_ptr1,
                                     Surface* surface_ptr2,
                                     BodySM* body_to_trim_to,
                                     DLIList<BodySM *>&midsurface_bodies ) const
-  PRINT_ERROR("Option not supported for mesh based geometry.\n");
-  return CUBIT_FAILURE;
+  OCCSurface* occ_surf1 = CAST_TO(surface_ptr1, OCCSurface);
+  OCCSurface* occ_surf2 = CAST_TO(surface_ptr2, OCCSurface);
+  if(occ_surf1->geometry_type() != SPHERE_SURFACE_TYPE ||
+     occ_surf2->geometry_type() != SPHERE_SURFACE_TYPE)
+    PRINT_ERROR( "Both surfaces provided should be sphere type.\n");
+    return CUBIT_FAILURE;
+  BRepAdaptor_Surface asurface1(*occ_surf1->get_TopoDS_Face());
+  BRepAdaptor_Surface asurface2(*occ_surf2->get_TopoDS_Face());
+  gp_Sphere sphere1 = asurface1.Sphere();
+  gp_Sphere sphere2 = asurface2.Sphere();
+  gp_Pnt center1 = sphere1.Location();
+  gp_Pnt center2 = sphere2.Location();
+  if(!center1.IsEqual(center2, tol))
+    PRINT_ERROR( "Spheres need to have the same center.\n");
+  double radius = sphere1.Radius()/2.0 + sphere2.Radius()/2.0;
+  BodySM* tool = sphere(radius);
+  CubitVector center(center1.X(), center1.Y(), center1.Z());
+  OCCQueryEngine::instance()->translate(tool, center);
+  from_bodies.append(body_to_trim_to);
+  CubitStatus stat = intersect(tool, from_bodies, midsurface_bodies,
+                               CUBIT_TRUE);
+  OCCQueryEngine::instance()->delete_solid_model_entities(tool);
+  return stat;
+// Function   : get_conic_mid_surface
+// Description: Calculates a mid-surface between 2 conic surfaces.
+// Date       : 01/09
 CubitStatus OCCModifyEngine::get_conic_mid_surface( Surface* surface_ptr1,
+  if(occ_surf1->geometry_type() != CONE_SURFACE_TYPE ||
+     occ_surf2->geometry_type() != CONE_SURFACE_TYPE)
+    PRINT_ERROR( "Both surfaces provided should be conic type.\n");
+  GeomAbs_SurfaceType  type1 = asurface1.GetType();
+  GeomAbs_SurfaceType  type2 = asurface2.GetType();
+  if(type1 != type2)
+    PRINT_ERROR( "Both surfaces provided should be both cylinder or cone type.\n");
+  CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
+  double height = (bounding_box.diagonal()).length();
+  BodySM* tool;
+  if(type1 == GeomAbs_Cylinder)
+    gp_Cylinder cyl1 = asurface1.Cylinder();
+    gp_Cylinder cyl2 = asurface2.Cylinder();
+    gp_Ax1  axis1 = cyl1.Axis();
+    gp_Ax1  axis2 = cyl2.Axis();
+    if(!axis1.IsCoaxial(axis2, 0.001, tol))
+      PRINT_ERROR( "Cylinders need to have the same axis of symmetry.\n");
+    double radius = cyl1.Radius()/2.0 + cyl2.Radius()/2.0;
+    gp_Ax2 axis;
+    axis.SetAxis(axis1);
+    TopoDS_Solid S = BRepPrimAPI_MakeCylinder(axis, radius, height);
+    Lump* lump = OCCQueryEngine::instance()->populate_topology_bridge(S,
+        CUBIT_TRUE);
+    if (lump == NULL)
+      PRINT_ERROR("In OCCModifyEngine::get_conic_mid_surface\n"
+                  "   Cannot create a cylinder for given radius.\n");
+    tool = CAST_TO(lump, OCCLump)->get_body();
+  else  //GeomAbs_Cone
+    gp_Cone cone1 = asurface1.Cone();
+    gp_Cone cone2 = asurface2.Cone();
+    double angle1 = cone1.SemiAngle();
+    double angle2 = cone2.SemiAngle();
+    if(fabs(angle1 - angle2) > 0.001)
+      PRINT_ERROR( "Cones do not have the same semi-angle.\n");
+    gp_Ax1  axis1 = cone1.Axis();
+    gp_Ax1  axis2 = cone2.Axis();
+      PRINT_ERROR( "Cones need to have the same axis of symmetry.\n");
+    if(axis1.IsOpposite(axis2, 0.001))
+      PRINT_ERROR( "Cones need to have the same orientation of axis.\n");
+    double r1 = cone1.RefRadius()/2.0 + cone2.RefRadius()/2.0;
+    gp_Pnt apex1 = cone1.Apex();
+    gp_Pnt apex2 = cone2.Apex();
+    double d = apex1.Distance(apex2);
+                               CUBIT_TRUE);
+  return stat;
+// Function   : get_toric_mid_surface
+// Description: Calculates a mid-surface between 2 toric surfaces.
+// Date       : 01/09
 CubitStatus OCCModifyEngine::get_toric_mid_surface( Surface* surface_ptr1,
+  if(occ_surf1->geometry_type() != TORUS_SURFACE_TYPE ||
+     occ_surf2->geometry_type() != TORUS_SURFACE_TYPE)
+    PRINT_ERROR( "Both surfaces provided should be toric type.\n");
+  gp_Torus torus1 = asurface1.Torus();
+  gp_Torus torus2 = asurface2.Torus();
+  gp_Pnt center1 = torus1.Location();
+  gp_Pnt center2 = torus2.Location();
+    PRINT_ERROR( "Torii need to have the same center.\n");
+  double major_r1 = torus1.MajorRadius();
+  double major_r2 = torus2.MajorRadius();
+  if(fabs(major_r1 - major_r2) > tol)
+    PRINT_ERROR( "Torii need to have the same major radius.\n");
+  gp_Ax1 axis1 = torus1.Axis();
+  gp_Ax1 axis2 = torus2.Axis();
+    PRINT_ERROR( "Torii need to have the same axis of symmetry.\n");
+  double radius = torus1.MinorRadius()/2.0 + torus2.MinorRadius()/2.0;
+  gp_Ax2 axis;
+  TopoDS_Solid S = BRepPrimAPI_MakeTorus(axis, major_r1, radius);
+        CUBIT_TRUE);
+  if (lump == NULL)
+    PRINT_ERROR("In OCCModifyEngine::get_toric_mid_surface\n"
+                "   Cannot create a torus for given radii.\n");
+  BodySM* tool = CAST_TO(lump, OCCLump)->get_body();
+                               CUBIT_TRUE);
+  return stat;
More information about the cgma-dev mailing list
