[AG-USERS] Do I still need 3 servers in this day and age?
Tom Coffin tcoffin at ncsa.uiuc.edu
Wed Jan 14 15:59:59 CST 2009
hi Les
Depending upon the room (and your situation sounds like
a small room) you could get a way with a souped up personal
interface to the grid (PIG) machine. I refer to these machines as
medium size nodes because they are good for 2-5 people
basically - it's a PIG with multiple display monitors and
an echo cancelling microphone (like an accumicII)
The multiple VGA displays are the key ingredient so that
everyone can see the various video streams, and data being
shared. You amy even want one of th edisplay
to be larger (like a focal point)
_______________________________________________________
Les Rhoda wrote:
> Hello all,
> I work in Video Services at the University of Maine in Orono.
> I have been tasked with constructing a quote for building an Access Grid node. It will be a small node, not even using projectors or anything fancy, just a small room that can act as a hub for some research teams to collaborate on.
> I have scoured the net for hours trying to suss what the best and most economical way to build the node would be. I've researched all of the capture cards, cams, etc but I still have one burning question: do we reall need 3 boxes to process and
> serve, or can we pack it into one so long as we do not need multiple video input and display cards (which would require too many slots?
> Any suggestions are immensely appreciated. I'm under a deadline for grant money and since I'm new to this job there is a lot riding on this (especially given the economy, etc :)
> THANK YOU!
> Glad to be here, and glad to take part in the AG revolution! :)
> Les
> Les Rhoda
> Technician/Office Manager - Video Services Dept.
> Systems Manager - The Maine Channel
> 220 Alumni Hall / 581-2517
> IT Manager, Dept. of Communication and Journalism
> 416 Dunn Hall / 581-1281
___________________________________________________________
Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
    NCSA ACCESS / UIUC                  cel: 703-477-5948
    901 North Stuart Street, #800       tel: 703-248-0105
    Arlington, Virginia, 22203          fax: 703-248-0100
__________________________________ http://www.ncsa.uiuc.edu
More information about the ag-users mailing list
