[AG-USERS] For those participating in the SCGlobal AGVCR tutorial
Derek Piper
dcpiper at indiana.edu
Tue Nov 14 08:40:38 CST 2006
If you are participating in the SCGlobal tutorial or if you know of
people that are (get them on the AGVCR list ;)) then please bear in mind
some important information.
* If you are bridging and on a personal node, you will NOT be able to
run AGVCR alongside VIC and RAT due to the way unicast networking works.
Only one application will receive the data so AGVCR will not see the
packets since VIC and RAT will 'grab' them first. This happens on all
platforms and has been a known issue for the long time (and is in the
FAQ) but I thought it worth bringing to people's attention again in
light of the upcoming event.
If you want to still participate but have to bridge, find another
machine to run AGVCR and set it to the same host/port information as
found in the Venue Client properties.
* AGVCR_Launcher does not hand AGVCR the unicast (bridged) host/port
information either, so, again, you must be sure to configure AGVCR
manually based on the Venue Client properties.
If you are able to participate using multicast, you should not have any
problems at all (AGVCR_Launcher will configure correctly and all
Video/Audio packet data can be recorded by AGVCR)
Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
More information about the ag-users
