[AG-TECH] Access Grid Sound Test Question
Klubek, Jonathan
jhklubek at buffalo.edu
Fri Oct 14 14:40:02 CDT 2011
Our group recently redesigned a room for use as an Access Grid / Video Conferencing Center. The firm we contracted with has finished the setup and we are now in the process of configuring the Access Grid software for use in the room. We have the software installed and configured from the instructions but are having an issue testing things. The machine we are running is a Windows 7 x64 machine and we are having issues doing the Sound test listed here:
http://www.accessgrid.org/node/354
Our issue is that the instructions do not match for the simple test using a packet reflector after step 2. The directions indicate that we should have 3 audio sources (our source twice and the reflector once). We only see our option once and the reflector once. Has anyone else experienced this problem? I attached a screenshot that illustrates he issue. We are pretty sure we configured things properly with adding video and audio devices from the cameras and sound card.
Jonathan
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20111014/2ce39bdc/attachment-0001.htm>
Type: image/jpeg
Desc: soundreflector_prob.JPG
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20111014/2ce39bdc/attachment-0001.jpeg>
